Curious if anyone had bought larger wheels for their boat trailer?
Discussion in 'Boating & Fishing' started by SpeedwayTaco160, Jan 28, 2019.
  1. Jan 28, 2019 at 3:02 PM
    SpeedwayTaco160
    SpeedwayTaco160 [OP] Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    I am looking to ditch the 13in wheels that are on my 17 Ft G3 boat trailer. I am looking to upgrade to a 15in wheel but get a low profile ish looking tire. It would have to be a passenger tire. Curious if anyone here has done it. I have a wheel and tire in mind that but just wanted to get some opinions.
    Ray
  2. Jan 29, 2019 at 10:40 AM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    I didnt change rim size, i just went up in tire size. I went from a 4.80x12 to a 5.3x12. Not a huge differnce, just didnt look right with the smaller tire. I only have a 16ft MFG though. I thought about doing passneger tires also, not sure how different it would be.
  3. Jan 29, 2019 at 11:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    I made a utility trailer out of a small tilt boat trailer in the 70's.
    Went from 8" boat to 13" Vega wheels. Bolt pattern was same but hub opening was too small, so I ground them out.
    Did not have studs and lugnuts, had bolts into a threaded backing plate. Worked fine.
    Put new inner seals, bearings and buddy bearings in place. Bored holes in centers of hubcaps (dog dish) and added OE trim rings.
    Always used used 13" passenger tires. Have had it loaded enough springs reverse bowed, tires were fine.
    Still in use 45 years later.
    Point to my rambling post? Passenger tires are fine as ling as the meet the load rating of what you haul.
    Rolling dia needs to consider fender clearances, wheel offset for frame clearance, and if additional ht creates any launch/loading issues assuming you are not a float on.
  4. Jul 11, 2019 at 6:59 PM
    jrain904
    jrain904 Well-Known Member
    Do you mean tires? If so be careful cause the weight of your boat empty may be fine but once you fill with gear and ice for fishing the springs will compress and can lead to your larger tire rubbing on the fender.
