Curious:
Discussion in 'Suspension' started by bigmooze, Oct 21, 2010.
  1. Oct 21, 2010 at 6:50 AM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Can 5100's be installed in the rear with no AAL i.e. stock leaves), and can they be set to 0" and be used in the front with stock coils?
    Let's say you wanted no lift but wanted to improve the ride.
  2. Oct 21, 2010 at 7:03 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    It's my understanding that the rear 5100's are not adjustable.
  3. Oct 21, 2010 at 7:08 AM
    bigmooze
    Richard
    Belle River, ON
    That's correct. Only the fronts are adjustable. But can I install the rear 5100s without having to add a leaf/block?
    And can the front ones be set for 0" lift and be used with the stock coils?
  4. Oct 21, 2010 at 7:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not sure about the rears but I believe you can run the 5100's in the front and set them at 0 with your stock coils. There was a thread about this talking about ride improvement and I remembered reading that. If I can find the thread to verify I'll post it.
  5. Oct 21, 2010 at 2:19 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes and yes....no problems doing either.
  6. Oct 21, 2010 at 3:47 PM
    bigmooze
    Richard
    Belle River, ON
    Thanks guys. I was faced with the growling front diff after lifting ~2.5" in the front. Wanting to keep the improved ride of the 5100's, I have just finished swapping out the 1.6" Eibach coils for the stock coils. I set the front 5100's to 0" lift.
    I will re-install my stock UCAs and see whether the growl stops. I'm planning to leave the 1.5" AAL and 5100's in the back, but if I have too much vibration then the leaf will also be removed. I'll keep the 5100's back there.
    It might just be me, but I thought I could still notice a bit of lift up front even at 0" on the 5100's... but they are set at stock height.
  7. Oct 21, 2010 at 5:00 PM
    bigmooze
    Richard
    Belle River, ON
    I didn't try. The diff drop doesn't sound too enticing to me since it alters the driveline angle for the front drive shaft. I rather not screw with the angles too much. If I can maintain close to the lifted ride quality and chop up the dirt with stock ride height then I'll be happy. Only thing missing will be the better stance, which everyone has loved.
  8. Nov 30, 2010 at 8:56 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    Did you get your truck growl/vibes fixed?
    What was your solution?
  9. Nov 30, 2010 at 9:05 AM
    bigmooze
    Richard
    Belle River, ON
    I just dropped the truck down to stock height.
  10. Nov 30, 2010 at 10:19 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    thanks for the reply. Did you ditch the front lift first and keep the AAL and Billy 5100s on back?
    Or did you go back to all stock susp?
    Just wondering if you think it was caused by lifting the front or the back or both?
  11. Nov 30, 2010 at 3:35 PM
    bigmooze
    Richard
    Belle River, ON
    I kept the billies on all four corners. The ride is improved in my opinion, compared to the stock shocks. It feels somewhat more dampened when hitting bumps etc., more controlled.
    I originally kept the 1.5" AAL in the back, but was concerned about a driveline vibration at take off from stop lights. I removed the AAL and the vibe stopped.
    I have Firestone Ride-Rites ready to be installed when I get the time and the weather's cooperation. These will give the stock AALs some support, and also keep the truck level when towing/hauling my ATV.
  12. Dec 1, 2010 at 8:14 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    thanks again for the reply.
    Most of the new vehicles without any mods are still getting the take off vibration. I too have become concerned, but havent tried shims or a CB drop.
    My AAL definately raised my rear significantly, i just wasnt sure if Im getting the vibration/ drone at various speeds when foot is on the accelerator due to the front or rear lift. My front wasnt raised as much as the rear and I never noticed the vibes until it started getting colder. i might try the 3*shims and see if that helps improve the driveline angles.
    I only have 7,000 miles on my truck and would hate to have to replace my U joints!
  13. Dec 1, 2010 at 5:24 PM
    bigmooze
    Richard
    Belle River, ON
    Yeah since I got the truck two years ago I had a minor vibe at lower speeds. I brought it to the dealership's attention and the couldn't find anything wrong.
    This summer, while the truck was in for a problem with the binding drive shaft slip yoke, they noticed the vibe during a test drive and applied TSB #3018 (a Canadian TSB number?), in which the transmission mount was replaced. The take off vibe is now undetectable.
