Curiousity Question (Chris)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanGer, Sep 14, 2009.
  1. Sep 14, 2009 at 6:21 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I have heard multiple times that the injectors shut off when no throttle is applied but the truck is left in gear, until the engine winds down to about 1k rpms.
    My question is how can the rpms remain high with no fuel being delivered?
    This question is not about driving habits, just my curiosity to how the engine works. Thanks!
  2. Sep 14, 2009 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    When driving down a hill, or grade. :)
  3. Sep 14, 2009 at 6:22 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    I think it has to do wit the trucks momentum. It keeps the engine spinning at speed.
  4. Sep 14, 2009 at 6:26 PM
    DanGer
    Ok, so the engine is still pumping due to the momentum of the truck? I guess I don't understand how the truck can continue running with no fuel, much less at higher RPMs.
    I guess this is how we start up old tractors when they stall.
  5. Sep 14, 2009 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Momentum of the moving vehicle can keep the engine turning when no fuel is being pumped into it.
  6. Sep 14, 2009 at 6:30 PM
    DanGer
    Gotcha, so when I am on a moderate hill where I could either coast in neutral and maintain speed, or coast in gear and maintain speed, I would rather leave it in gear. Correct?
    I don't have the pre-reqs done to take internal combustion engines so thanks for the lessons! :)
  7. Sep 14, 2009 at 6:30 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Imagine lifting the truck off of the ground with all four wheels off of the ground with a car lift. Then imagine grabbing the rear wheels at the same time and spinning them forward real fast with the truck in gear. If you did the same thing with the truck in N gear, than the engine would not spin and only the trans would spin and the rear diff,.
    When it's in gear or D gear (drive gear), than it will grab onto the engine and spin or turn over the engine.
  8. Sep 14, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Better to leave it in gear.
  9. Sep 14, 2009 at 6:32 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Leave it in gear. If you put it in N too much, you'll burn the tranny fluid out cause it's pumped to the cooling via the truck being in gear and moving.
    Or something to that effect.
    Either way moving + N too much = :( truck
  10. Sep 14, 2009 at 6:32 PM
    DanGer
    Ok thanks for the explanations!
  11. Sep 14, 2009 at 6:34 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Wait... the injectors shut off? That actually might explain why there's a lag sometimes in kicking in... almost like it was dropping out of OD but it's not. Now how to shut that off :/
  12. Sep 14, 2009 at 6:35 PM
    DanGer
    Got it! So it is (simplified) much like when we hook one tractor up to a dead one and get the engine to start by towing it and poping the clutch?
    Alright. I asked this question with my manual tranny in mind but that is good info for the others reading this!
  13. Sep 14, 2009 at 6:43 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    My bad. I looked and saw the 4x4 and the 4 cyl but totally missed the manual.
    My bad.
  14. Sep 14, 2009 at 6:51 PM
    DanGer
    No problem at all, I love learning about anything to do with our trucks, even if it doesn't pertain to mine.
    SJ-do you think cruising in neutral has the same affects on the manual tranny oil? The reason I ask is on interstates, no matter the grade around here, if you coast in gear, you will lose speed. Sometime on interstates (especially leaving my school in the mountains) I coast in neutral since I cant afford to lose my momentum in gear. Sometime I can get up to 3 miles coasting in neutral with the engine at idle, as opposed to 5th gear around 2300 rpms
  15. Sep 14, 2009 at 6:51 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
  16. Sep 14, 2009 at 6:52 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    i've never heard of this before.i'm realy curious of how that system works or why they did it.if anyone has a link of where this is exsplained let me know.this is something i would like to know more about.
  17. Sep 14, 2009 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Efficiency. Its not new, and has been around in most all fuel injected vehicles. Why should fuel be injected into the engine, if there is no load on the engine? nWhen going down hill, and you let off the throttle, the engine returns to an "Idle" state, but when the computer sees the engine still turning 3000 rpm (for example), it cuts fuel. Fuel is returned when the RPM gets to 1200 on the 1GR-FE
  18. Sep 14, 2009 at 6:55 PM
    DanGer
    Looks like we are in the same boat. I understand much better now after the responses in this thread. Basically (in engineering terms) the work done by the spinning tires travels through the drive train and provides enough work on the engine that it can continue to run without the added energy of fuel combusting
  19. Sep 14, 2009 at 7:04 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    It kinda sounds as if you already knew all of this lol.
  20. Sep 14, 2009 at 7:08 PM
    DanGer
    Nope I just never put two and two together until you all provided enough of an explanation to make it click in my head!
