Current 2008 & 2009 TSB's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, Jul 1, 2009.
  1. Jul 1, 2009 at 6:34 AM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    These are titles only, but thought I'd post them up. A lot of us have been looking hard for these. TSB's are for 4x4 4.0V6's.
    2008:
    TSB Number & Issue Date TSB Title
    SB0345-08 NOV 08 Tires - Inflation Pressure Compensation/Adjustment
    SB0326-08 OCT 08 Engine - Oil Leaks From The Timing Cover
    SB0301-08 SEP 08 Engine - Serial Number Locations
    SB0260-08 SEP 08 A/T - Remanufactured Transmission Serial Number Location
    SB0258-08 SEP 08 Restraints - Seat Belt Tongue Plate Stopper Replacement
    SB0200-08 AUG 08 A/T - Location Of Serial Numbers
    SB0144-08 JUL 08 Vehicle - Certification Label Information
    SB0138-08 JUL 08 Body/Frame - Protective Wax Coating Information
    SB0132-08 JUL 08 Drivetrain - Driveline Vibration Between 15 - 25 MPH
    SB0129-08 JUL 08 A/T - Fluid Level Inspection/Temperature Ranges
    SB0076-08 MAY 08 Drivetrain - Rear Differential Whine/Howl At 50-70 MPH
    SB0073-08 MAY 08 Body - Front Fender Liner Pin Hold Clip Procedure
    SB0071-08 MAY 08 A/C - Condenser Line Bolt Installation
    SB0053-08 MAY 08 A/T, M/T - Alignment Pin Service Precaution
    SB0040-08 APR 08 Body - Paint Stained Under Rapguard(R)
    SB0038-08 APR 08 Engine - Cylinder Head Cover Baffle Precautions
    SB0020-08 MAR 08 ABS/TCS - Zero Point Calibration Information
    BO001-08 MAR 08 Restraints - Seat Belt Extender Availability
    PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
    BO018-07 NOV 07 Body - Truck Bed Tailgate is Bent
    EL010R-07 NOV 07 Keyless Entry - Remote Transmitter Programming Guide
    EL009-07 NOV 07 Keyless Entry - Programming Remote Transmitters
    AX004-07 OCT 07 Interior - Driver/Passenger Floor Mat Installation
    PG005R-03 OCT 07 Wheels/Tires - Spare Tire Carrier Operation Information
    SS006-07 AUG 07 Battery - Absorbed Glass Mat Battery (AGM) Information
    SS004-07 AUG 07 Restraints - SRS Component Disposal
    PD079-07 JUL 07 Instruments - Compass Calibration Procedure
    PD084-07 JUL 07 Tire Monitor System - Initialization Procedure
    TC010-07 JUN 07 A/T - 'World Standard' Transmission Fluid Information
    EG034-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor identification
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    CRIB122 FEB 03 Body - Body Sectioning
    2009:
  2. Jul 1, 2009 at 6:37 AM
    FL4x4Taco
    Does anyone know what the tire pressure compensation/adjustment entails?
    I'm also curious of the 2009's are victim of the bent tailgate.
  3. Jul 1, 2009 at 6:45 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    awesome post, thanks duder
  4. Jul 1, 2009 at 7:10 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    All links are requiring paid registration to look at the bulletins.
  5. Jul 1, 2009 at 7:23 AM
    FL4x4Taco
    I know that. This is so we at least know what is going on. better than nothing.
  6. Jul 1, 2009 at 7:25 AM
    EricT
    Arizona
    Ah, okay. The info is definitely appreciated, I just wasn't sure if I was doing something wrong. They charge to look at these! What a racket.
  7. Jul 1, 2009 at 7:27 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    I'm not certain how something like "compas calibration procedure" wouldn't apply to 4x2's as well as 4x4's.
    Is there no list available for the 4x2 4.0L Tacos?
  8. Jul 1, 2009 at 7:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It'd be nice to have all the TSB's for 05's and up....
    Is there a link somewhere like this? This is a nice list..... it'd be even better with all the 05's + listed in it.
    THanks for posting!
  9. Jul 1, 2009 at 7:58 AM
    jla888
    jla888 Well-Known Member
    pdf's can viewed from here.
  10. Jul 1, 2009 at 8:10 AM
    FL4x4Taco
    You have to select your truck from the list. I selected a 4x4 4.0. So yes some items pertain to more than just the 4x4 4.0.
