Curved light bars? Yay or Nay?
Discussion in 'Lighting' started by Jrunr619, May 5, 2022.
  1. May 5, 2022 at 8:21 AM
    Jrunr619
    Jrunr619 [OP] Well-Known Member
    Does anyone here run a curved light bar anywhere on their truck? Is there really an advantage to it, or is it just a gimmick? Reason being, is I am looking at the Baja Designs ONX6+ curved light bar, and it is so much more expensive than the straight bar.
    Does it really make that much of a difference?
  2. May 5, 2022 at 9:48 AM
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
    I would think its mostly for aesthetics. With those baja open bucket optics your getting alot of light bleed already, i wouldnt say its worth it. Although ive never used/seen a curved bar in person.
  3. May 5, 2022 at 9:54 AM
    Tacospike
    Two Trucks
    I think it does spread light several degrees more to the side and also what beam pattern used.
    I would think saving the money for the straight bar and add some ditch lights (or side lighting) might be a better solution.
    Like above, I have never used curved bars, only straight. mostly going on what I've seen from here and youtube videos.
    Key-Rei likes this.
  4. May 5, 2022 at 12:27 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    if you are racing its nice, but other then that i would say a normal bar setup is perfect, add in some side lights and you are right there.
  5. May 5, 2022 at 12:33 PM
    Jrunr619
    I guess adding side lights would offset the cost of the curved bar and give you more placement flexibility…
  6. May 5, 2022 at 12:42 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    With the quality of optics currently on market, the difference in beam spread is marginal at best.
    Going with a curved bar severely limits your mounting options.
    Key-Rei likes this.
  7. May 11, 2022 at 12:04 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    ARC bars are an aesthetic improvement to fit a certain look. They are not a performance improvement.
    Straight from the BD team HERE:
    Key-Rei and Baja Designs like this.
  8. May 12, 2022 at 11:03 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Memario is correct, the curve in the bars is more for aesthetics as well as fitment and less of a performance upgrade.
    Best,
    Brock Brunkhorst
    Key-Rei likes this.
  9. May 17, 2022 at 3:23 AM
    Jrunr619
    Awesome. Thank you.
  10. May 22, 2022 at 1:47 PM
    yota4r
    yota4r Well-Known Member
    Tacoma/4runner
    I have a straight 40" onx6 bar on my 4runner, and another buddy has a curved...never noticed a difference in the light spread/output between the two
