Curved vs. Straight LED Light Bar Mounts?
Discussion in 'Lighting' started by shockinyall, Feb 12, 2016.
  1. Feb 12, 2016 at 7:48 PM
    shockinyall
    shockinyall [OP] White Lightning Enthusiast
    West Virginia
    '06 SR5 DCSB SUPER WHITE
    Traded to '17 Tundra
    So I am going with a 50" curved LED light bar, and now I have to figure out the mounts. Basically my question is, How much difference is there between the curved light bar mounts and the straight light bar mounts? Only reason I am asking is I found a good deal on some straight led bar mounts and wondering if they will work (even if I have to do some light bending and whatnot to make it happen). Thanks in advance.
  2. Feb 12, 2016 at 9:52 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Depends on the mounts I think. Most curved mounts I've seen are low profile. Which means if you were to mount a straight bar on it, the center would be touching the windshield. If the mounts are raised a bit, then it might work, after slight bending.
    Got a pic of the mounts?
  3. Feb 13, 2016 at 7:01 AM
    shockinyall
    West Virginia
    I don't have a picture of the exact mounts but he said they came off of Amazon, and these are the only ones I can find on there that he would be giving up this cheap. So basically if I mount a curved bar on straight mounts more than likely it will be higher up than if I had the curved bar mounts?
  4. Feb 13, 2016 at 2:09 PM
    NightProwler
    Harlan
    Maricopa, Az
    Well, yeah. If the mounts aren't low profile. Of they are low profile, the curved bar will be hugging the curve of the windshield closely all the way across. So if you mounted a straight bar there, it wouldn't mount. Because the middle of bar would be touching the windshield, and the ends would be too high to mount.
    If they are like the pic you posted, then thatd probly work with both bars as the mount arms are extended out and up a bit. I'll see if I can find a photo of a curved bar low pro mount ffrom the side to show you..
  5. Feb 13, 2016 at 2:42 PM
    NightProwler
    Harlan
    Maricopa, Az
    So if they are mounts like this, a straight bar most likely won't work.
    Versus this, which is probably your only option. Getting straight bar mounts, and putting the curved bar on it, after slight bending of the mounts.
    Basically, you can mount a curved bar on straight mounts, but not a straight bar on curved mounts. Unless those mounts are extended out/up enough to clear the windshield.
    shockinyall[OP] likes this.
  6. Feb 16, 2016 at 10:42 AM
    shockinyall
    West Virginia
    Thanks for the info, its what I needed. I think I am gonna pass on the original mounts I seen and try to fab my own. Will post back if I get them done soon.
  7. Nov 27, 2016 at 8:51 AM
    Timothyjason9
    Timothyjason9 New Member
    Tim
    2014 Toyota Tacoma
    can you use straight bar brackets for a curved light bar?
  8. Nov 29, 2016 at 9:05 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    @devinzz1
  9. Nov 29, 2016 at 12:42 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    All i know is straight and curved mounts are listed separately so no. BUT im sure you could just bend the mounts and theyl work fine. mount to mount is the same but curved bars have angled ends.
  10. May 27, 2017 at 9:25 PM
    Fromthe541
    Fromthe541 Member
    Alex
    Medford Oregon
    Did you end up fabbing your own? I'm looking at the same straight bar mounts on Amazon you were, they're a great deal and look solid but I have a 50" curved light bar as well.
  11. Jun 12, 2017 at 1:32 PM
    shockinyall
    West Virginia
    Sorry for the delayed response, I traded my Tacoma in on a Tundra, and spend most of my time over on tundras.com but to answer your question, I did fab my own mounts out of an old road sign I had laying around (insert you might be a redneck joke here). They worked but were a little too flimsy for what I wanted, plus I ended up making them too low to the windshield and the wipers would hit on occasion. I ended up buying some Relentless mounts that fit perfect and were well worth the money, however, I can't find them on their site anymore. Might check with @RelentlessFab and see if they are still making them. I mounted them over top of the rubber strip and they still worked perfectly.
  12. Jun 12, 2017 at 1:40 PM
    shockinyall
    West Virginia
    By the way, these are the Relentless mounts that I bought, just in black. Trying to bend the straight mounts will put the lightbar pretty high on the roof, which I would recommend against due to wind noise.
    Fromthe541[QUOTED] likes this.
  13. Jun 17, 2017 at 4:43 PM
    Fromthe541
    Fromthe541 Member
    Alex
    Medford Oregon
    Thanks for the input man! If I don't make my own I will have to go with those, i've heard a lot of good things about them.
