Custom 35 gallon gas tank for 09 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adreenaleen, Feb 13, 2012.
  1. Feb 14, 2012 at 10:39 AM
    Adreenaleen
    Adreenaleen [OP] Active Member
    Texas
    Speedway Blue 4x4
  2. Feb 14, 2012 at 10:47 AM
    badger
    badger Well-Known Member
    07 SR5
    The difference in weight between stock and this when full is about 85# for gas and maybe 40-50 for the tank itself. Presumably you wouldn't be filling it most of the time unless you were heading out for a long trip. In that case you could plan your added load to put heavier items on the right side. It gives you the OPTION of carrying more fuel, not the mandate. I would not want a tank where my spare goes because...., that's where my spare goes.:D
  3. Feb 14, 2012 at 10:52 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I'd rather put a slip tank in the back of my truck. At least then if need be I can refuel other vehicles as well if need be.
  4. Feb 14, 2012 at 10:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    YES! I'm in.
  5. Feb 14, 2012 at 11:26 AM
    Adreenaleen
    Texas
    Speedway Blue 4x4
    X2
  6. Feb 14, 2012 at 11:32 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    My 78 Bronco has a 32 gallon tank, it was a factory option back then, I can tell ya one thing though, I have maybe filled it all the way four times since I have had it! Last summer I topped it off for a long wheeling/camping trip and it cost like $120 dollars.
  7. Feb 14, 2012 at 11:49 AM
    PCarnathan
    PCarnathan Member
    Pat
    2011 Tacoma Access Cab 4x4 V6
    I'm very interested in this project as well. OP, I realize there are privacy concerns, but how can we let this gentlemen know if we're interested?
    Pat in Menifee, CA
    http://www.patcarnathan.com
  8. Feb 14, 2012 at 11:50 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    want.... now i can make it to new orleans from houston and back without filling up :D
  9. Feb 14, 2012 at 11:52 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Dont know the position of the spare off the top of my head, but if that position is behind the rear axle and you put a fuel tank there, enjoy burning to death when you get rear ended
  10. Feb 14, 2012 at 12:49 PM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    How is it any different if you got t-boned? Inside the frame is inside the frame. Lots of trucks have tanks behind the rear axle. Lots of trunks have tanks by the frame. I'd like to see data supporting crash worthiness either way.
  11. Feb 14, 2012 at 12:49 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    a la Ford Pinto? the only car to be made of flint and steel
  12. Feb 14, 2012 at 12:51 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    The Magnesium and water option was too expensive.
  13. Feb 14, 2012 at 1:03 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    google ford crown victoria fuel tank issue. Many cops have died because of the location of the crown vic's fuel tank
  14. Feb 14, 2012 at 1:29 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  15. Feb 14, 2012 at 2:05 PM
    #35
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Interesting project. I would not do this to my truck. Instead I would go for a second 20 gallon tank that refuels the primary stock tank using it's own pump. After reading about the problems with the Ford Panther platform I'd put it somewhere... but not where the spare tire is now. That way the truck can be easily returned to factory configuration. Also, the fuel system has an emissions leak test circuit. That adds an additional layer of complexity to the whole project of replacing the stock tank.
    Pirhett likes this.
  16. Feb 14, 2012 at 3:19 PM
    #36
    badger
    07 SR5
    This guy is building the tank fully compatable with the factory leak check system. He's really doing it right it seems to me. He's designing it to use all the factory connections and appliances. It's not really something I need, but I think he is doing it well.
  17. Feb 14, 2012 at 4:35 PM
    #37
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    That thing looks like a mini city skyline almost haha.
  18. Feb 14, 2012 at 4:48 PM
    #38
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Looks like it has many seams to crack, burst and leak.... not to mention the PITA it is to fill all the pin-holes while its being pressure tested..
  19. Feb 14, 2012 at 7:36 PM
    #39
    dually
    dually Low and slow
    Depends on the method you are using to weld. Mig will require atleast 1 inch overlap on every start and stop. I've done a lot of welding involving pressure testing. The less start and stops or weld the better it will turn out
  20. Feb 14, 2012 at 7:44 PM
    #40
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
