Custom 4X4 and 4X2 hub bearing assemblies! Order them here!
Discussion in 'Marion Bumper2Bumper' started by BamaToy1997, Aug 27, 2013.
  1. Aug 27, 2013 at 9:38 AM
    BamaToy1997
    BamaToy1997 [OP] ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    [​IMG] IN STOCK! [​IMG] Supplies on order.
    I've been working for a while now with Toyota, Timken, National, and Dorman. We all know the front wheel bearings are a common failure for both the Pre-runner, AND the 4X4 (ESPECIALLY the 4X4!) and trying to find a quality replacement is a pain. Then you have to get the parts together, drive to a shop, pay anywhere from $25-$50, and PRAY that the shop doesn't break something in the process!
    Have you wanted to be able to buy the entire bearing, ready to bolt on, with quality parts without breaking the bank? My work is your gain. I have obtained contracts with suppliers and now am able to make pre-assembled FULL units, ready to bolt on. EVEN THE PRERUNNER 6 LUG 4X2!
    Here is what you will get:
    For the 4X4 Tacoma:
    • National brand bearing (Timken, GMB, or Koyo available)
    • Dorman wheel hub
    • Timken bearing seal
    • Toyota bearing installation bolts
    • Toyota o-ring seal
    The price of this bearing unit, pre-assembled and ready for install is: $170 each. This includes shipping to the lower 48. Canadian orders see bottom of this post.
    These will fit the following 4 wheel drive vehicles:
    2005 - 2013 Toyota Tacoma
    2003 - 2013 Toyota 4runner
    2007 - 2013 FJ Cruiser
    2003 -2013 Lexus GX 470
    For the Pre-runner:
    • FACTORY Toyota wheel hub
    • FACTORY Toyota hub nut
    • Toyota Bearing installation bolts
    The price of this bearing unit, pre-assembled and ready for install is: $275 each. This includes shipping to the lower 48. (Canadian orders see bottom of this post)
    These will fit the following 2 wheel drive vehicles:
    All Tacoma Prerunners
    2003 and up Toyota 4Runner
    2007 and up FJ Cruiser
    All assemblies are built in a fully ASE certified shop, by an ASE certified Master Technician using a 20 ton shop press.
    I was finally able to upload my own photos. Below you will see the components as well as the assemblies.
    Above you will see the Toyota o-ring, Timken bearing seal, Toyota hub bolts, and the National hub bearing assemblies.
    Also you can see the Dorman hub for the 4X4 setup, as well as the Toyota hub for the 4X2 setup.
    Assembled 4X4 hub unit:
    Assembled 4X2 hub unit:
    Here is the proper way to press these units together.
    Some people place the hub and bearing assembly directly on the lower plate. This is not the correct way as it applies force to the bearings themselves on the inside. This can cause chipping of the bearings or races, resulting in premature bearing failure. By using a press sleeve underneath the assembly, and directly on the center bearing support it forces the pressure only on the inner races of the bearings, pressing the two races together, and pressing the wheel hub into place. This applies NO pressure to the bearing itself. How can you tell? Check out this short video I made that demonstrates this.
    http://www.youtube.com/watch?v=BhHbOe5SSZc&feature=youtu.be
    [​IMG][​IMG]
    The process will include:
    • Proper full greasing of the new bearing
    • installation of bearing seal
    • installation of mounting nuts
    • pressing of wheel hub into bearing
    • installation of hub backing nut and torque to spec.
    I have a new system I designed to pack these wheel bearing FULL with the appropriate high pressure grease. Most bearings, including Koyo, Timken, National, and all of the others, come with an inadequate amount of lubrication. I pack these bearings properly.
    ***WARRANTY***Now included for free!!
    I offer a 12 month/12,000 mile warranty (Whichever comes first)
    Please photograph your odometer when you install the hubs.
    Again these are professionally built units, assembled by an ASE certified master technician (ASE identification number ASE-1923-5640) and are assembled in a licensed automotive repair shop.
    Please note that in order to make sure I am doing this legally, I have to charge sales tax to any orders shipped within the state of Alabama. Not what I want to do, but it is the only legal way to do this. All states require sales, even online, to charge sales tax if sold within the same state, so if you live in Texas, and buy them from a seller in Texas, you are required by law to pay sales tax.
    Shipments to Canada are available, but due to weight limits of 20lbs as designated by the USPS, I cannot combine shipping to reduce costs for 2 hub assemblies. Each hub is 12 lbs, so I have to ship in two separate flat rate boxes at $41 each
    . I will be researching alternative shipping. I am open to suggestions.
  2. Aug 27, 2013 at 9:40 AM
    BamaToy1997
    Bill
    Navarre, FL
    Would you like to see how they are assembled? Check it out right here on a pair of 2WD Tacoma/4Runner/FJ Cruiser assembly!
    After several people have suggested it, I have decided to create a thread showing how I build the 2WD hub bearing assemblies for the Tacoma, PreRunner, and 4Runner trucks.
    Some people have asked WHY they should use a full unit like this, instead of pressing out their original hubs and reusing them. The answer is pretty simple. While the original hubs may be perfectly fine to reuse, getting the entire assembly saves time and as we all know, time is money. Sure, you could save yourself some money and buy the bearings and seals yourself, then take them down and get the old hub pressed out and the new bearing and seal pressed together. What you do have to concern yourself with is the condition of the wheel hub itself.
    The seal contact surface must be clean and smooth (this applies to the 4WD wheel hub as well) because any pitting or wear at this location will quickly ruin the new seal, allowing water and foreign material to enter the bearing. This results in premature bearing failure, and another trip to buy a replacement bearing, seal, and of course a new hub unless you want to do this again soon. If you look at the photo below you will see a brand new Toyota factory wheel hub.
    Note the silver tipped pointer. This is where your hub needs to be inspected. Many of the 2WD and 4WD hubs wear here. The reason for this is that as the bearing fails, it allows the wheel hub to wobble, putting it in contact with the metal part of the seal. This then causes damage to the wheel hub. If this damage goes unnoticed then you are going to be having bearing failure again in the near future, as this damaged area will destroy a new seal in short time.
    Now that we have shown WHY you should replace the entire unit, I will show how it is assembled so that you get a quality part, at a good price.
    First thing of course is to obtain and inspect all of the parts needed to build these units. The following are all of the items:
    Genuine Toyota 2WD wheel hub assembly:
    then 4 genuine Toyota hub mounting bolts:
    Originally I was using National brand hub seals, but I have found that the Timken seals are a faster supply for the demands. I have been ordering these in lots of 20.
    And of course you will need the genuine Toyota hub nut for the 2WD models.
    Lastly you can use your bearing of choice. Here I use either National or Koyo/Timken based on current supply. National bearings have become harder to locate with the official National stamp on them. While any bearing assembly with the same part number uses the National bearing, not all of the places that make the entire bearing/housing assembly obtain their bearings from a supplier. Many buy them direct from the bearing manufacturing plant. I have obtained a contract directly with a Koyo bearing manufacturer plant, and will be using them as my primary supplier. Once the National bearings that I have in stock are used up, I will be shifting to exclusive Koyo brand bearings except when I may run into shipping delays which will force me to order the National or NSK bearing units.
    Once I have all of the parts together I first press on the seal to the bearing unit. This guarantees 100% uniform mounting with no dimples. As of this posting, I am the ONLY company that has picture proof that I install the seals in this way, which is the best way to ensure uniformity and proper installation.
    After the seal is installed I lubricate the lip of the seal with bearing grease. This is an important step, as it ensures that the seal is not dry when the hub begins to rotate. Imagine a dry seal against a piece of metal turning at 50+ MPH! Not pretty, and not good for the seal.
    Once the seal is lubricated I place the bearing onto the adapter for the press as explained in the opening post of my thread on the bearing assemblies. This MUST be done to protect the roller bearings and the bearing cages. If pressed together improperly the bearings can chip, causing premature failure. The below video shows how to tell that the bearings are not under load when pressing in the hub. (Note that the mounting bolts are already inserted. This is because once the assembly is pressed together, the bolts are locked in)
    http://www.youtube.com/watch?feature=player_embedded&v=BhHbOe5SSZc
    Once the hub is properly pressed into the bearing assembly you can remove the unit and install the hub nut. I am not sure where some of the information has been gathered from, but according to Toyota, the proper torque of the hub nuts on the 2WD assemblies is 203 Lbs-ft. The proper SST tool MUST be used to protect the assembly.
    After the nut is torqued, then I locate the small indentation tab on the wheel hub and using a small drift punch I stake the edge of the nut. This is done to prevent the nut from possibly backing off during use. Also note that a properly pressed in assembly will only have one thread of the nut showing once it is torqued down. If more than one thread is showing, then something was not pressed together properly.
    And there you have it! A 2WD hub assembly ready to be installed in your Tacoma, or 4Runner! Any questions feel free to ask! I hope this was informative to those who wanted to know.
    Get yours here!!!
    2005 and up 2WD and 4WD front bearing complete assemblies!
  3. Aug 5, 2014 at 1:43 PM
    ramonortiz55
    ramonortiz55 Official Bro
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Do you only have hubs for Toyotas listed above?
    What about other Toyota vehicles?
  4. Aug 6, 2014 at 12:04 PM
    BamaToy1997
    Bill
    Navarre, FL
    Forgot all about this particular thread since I have my main one now. What other Toyota vehicles are you needing front hub bearings for? PM me and I will see what I have.
  5. Aug 15, 2014 at 9:48 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    How about 1998 through 2000 4x4s??
  6. Aug 15, 2014 at 9:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    The 1995.5 through 2004 Toyota trucks do not have a "hub bearing" bolt on assembly. Those bearings are pressed directly into the spindle assembly. This means that the entire steering spindle assembly will need to be removed and taken to a press. Sorry!
  7. Aug 15, 2014 at 3:34 PM
    skeezix
    Colorado
    1998 Limited
    I'm not familiar with the process. The first wheel bearings I greased were on a 1953 Ford back in 1960, and the last ones I greased were on a 1972 Chevelle back in 1984 or so. I've looked around this site and others for information on redoing the wheel bearings on my 1998 Tacoma 4x4 but haven't found anything. Is the construction similar to that back in the olden times?? Where one removes a spindle nut and the brake drum pops out? Or will I need to yank the front differential??? :eek:
  8. Aug 16, 2014 at 6:37 AM
    BamaToy1997
    Bill
    Navarre, FL
    The old systems you are familiar with were basic caged bearings. You pretty much don't have those anymore for quite a long time now. They use a sealed bearing unit. Your 1998 Tacoma has these:
    And in order to replace them you have to remove the steering spindle assembly and take it to a shop (Unless you have your own press) and have them press out the old one and press in the new one.
    The units that I sell are preassembled, but the bearing itself is this:
    As you can see, two totally different designs. Gone are the days where you could regrease your wheel bearings. Now they are pregreased and sealed units.
  9. Jan 19, 2015 at 11:56 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Just installed a a set of these on my 2009 Tacoma
    It came well packaged to the house, the assembly appears to be made of quality parts
    and put together nicely. Basically remove the brake caliper, remove the rotor, remove the dust cap, remove the shaft nut, remove the 4 main bolts. The hardest part is getting to the 4 main bolts, I used a breaker bar and 17mm crows foot to loosen.
    The best part about this is not having too remove the assembly, then wait having to get the bearing pressed out and new one in, hoping the do it right. Order ahead of time and do the job all at once. Did both sides so truck feels new again!
    Highly recommend !
  10. Feb 16, 2015 at 11:52 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs had to make rear shock extensions, FJ manual TC
    Do you know the size and pitch of the four flange bolts? It would be super helpful!
    Thx
  11. Feb 17, 2015 at 8:49 PM
    BamaToy1997
    Bill
    Navarre, FL
    Sorry, I don't. I buy mine directly from Toyota and never really had an interest in finding out. lol
  12. Mar 10, 2015 at 11:37 AM
    jfannin
    jfannin Member
    Ohio
    Tacoma
    265/75/16's Cooper Discoverer STT Tires.
    are you still doing the Front Wheel Hub bearing kit for the 2009 Tacoma 4x4?
    I tried calling the numbers you have listed and i get no answer.
  13. Mar 16, 2015 at 1:17 PM
    hartluck
    hartluck New Member
    Leighton
    So.Cal
    PreRunner
    Hey... bill this is the Thread that shows the $284
  14. Mar 20, 2015 at 12:30 PM
    BamaToy1997
    Bill
    Navarre, FL
    Fixed....
  15. Mar 20, 2015 at 2:02 PM
    hartluck
    hartluck New Member
    Leighton
    So.Cal
    PreRunner
    Shipped? Lol
  16. May 1, 2015 at 10:22 PM
    datwyl01
    datwyl01 Member
    Kapolei Hawaii
    06 PreRunner SR5 DBL
    Aloha, looking to replace the wheel bearings on my 06 PreRunner DC. Interested in your full assembly. Would you or do you ship to Hawaii? If that's possible, I would be interested in total cost with shipping for both sides. Zip code is 96707.
  17. May 17, 2015 at 5:14 PM
    BamaToy1997
    Bill
    Navarre, FL
    Missed the last post. I do ship to Hawaii. Same cost as the standard orders. Just see the thread in my sig
  18. Jun 10, 2015 at 10:43 PM
    oledragoon
    oledragoon Well-Known Member
    Don
    Oklahoma City
    06 Super White Tacoma TRD Off Road 4x4
    Super White Grille, and rear bumper on Off Road, TRD Intake System, TRD Exhaust System, Custom bed bar for Emergency light bar, Overhead Console Temp/Compass Fix,rcbs Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Jumpers LED's in cab, computer desk, Cobra 29 CB & Scanner on custom dash pad, Autometer gauges(oil press, oil temp, trans temp, Batt/amp), Front bushguard, Rear bumper guard, BamaToy1997 4x4 Custom Hubs,
    Your operation looks great, I will be looking to replace my hubs (312,343 miles on 06 Off Road 4x4) Still running originals.
    I will be traveling to GA from OK this summer, are you in Marion AL?
    Do you normally have some hubs in stock or build 'em on order?
    Thanks in advance for your answer. dc
  19. Jun 13, 2015 at 3:27 PM
    BamaToy1997
    Bill
    Navarre, FL
    I am in Navarre, Florida now. Just let me know when you plan to order them. Thanks!
  20. Jun 13, 2015 at 7:01 PM
    oledragoon
    Don
    Oklahoma City
    Wilco. thanks for the fast reply.. dc
