Custom Aluminum Popup Camper $5800
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Yota_Explorer, Mar 29, 2018.
Thread Status:
Not open for further replies.
  1. Mar 29, 2018 at 10:21 AM
    Yota_Explorer
    Yota_Explorer [OP] Well-Known Member
    San Diego
    2015 Tacoma TRD Off-road
    I have a new custom made aluminum Popup Camper to serve all your overland or camping needs. It is made from 100% aluminum all the structural is 1/8" thick and the aluminum siding is .035. I made a Camper thread you can see all the progress from beginning to end. If you own a Prinsu Rack it was design to clear it. Serious buyers only- Cash only no trades - San Diego, CA pick up only - willing to ship at buyers expense. I own a fork lift so the the Popup will be installed at my shop, I will wire 3rd brake light.
    -It will fit 05-15 5' bed only
    -Roughly 350 lbs
    -Closed height 83" Open height 139" (will vary depending on suspension)
    -Dual locking rear latch T handle keyed alike
    -2x 15"x30" Mirage sliding/locking side windows with sliding and removable screen
    -Roof will support 70lbs when popped up
    -Roof vent by Ventline powered exhaust fan
    -2x Dual Led interior lights with high/low on/off
    -58x91" 3 Panel moveable sleeping platform. High pressure plywood with aluminum sheeting on top for easy cleaning when cooking inside.
    -2" high density foam with removable fabric
    -Main tent material 18oz Vinyl coated polyester waterproof/scratch resistance/ all stitching is sealed with waterproof HH66(Material is Fully removable Velcro and snaps)
    -3 panel window on driver side Heavy duty screen material/ 20oz clear vinyl/ 18oz privacy vinyl with heavy duty Velcro.
    -Roof is insulated with 1" thick Rmax and removable headliner. Aluminum sheeting with EPDM Superflex membrane fully sealed on top.
    -2x Lockable canopy latches
    -LED 3rd brake light
    -All doors and seams are sealed with 3m weather stripping/ shell to bed seal Truck Capper Seal dual bulb seal
    -Exterior paint Sherwin Williams ATX
    If you want a roof rack install, extra lights, or anything else I have no problem doing at buyers expense. Windows can't be installed on aluminum main back door or cab rear window.
    There is no whistling/ or wind resistance noise even when driving 80mph. The camper was built with intended use to be used and abused outdoors, using heavy duty materials. Camper was tested in winds up to 40mph, I would not recommend Popping up the camper anything over that.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Mar 29, 2018 at 10:27 AM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    This thing is a masterpiece.
  3. Mar 29, 2018 at 10:36 AM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    How many for sale threads does one need???
    Twizted likes this.
  4. Mar 29, 2018 at 12:49 PM
    Yota_Explorer
    San Diego
    I didn't mean to double post originally, and I figured I'd post it in a different section
  5. Mar 29, 2018 at 12:53 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
  6. Mar 29, 2018 at 12:54 PM
    Yota_Explorer
    San Diego
  7. Mar 29, 2018 at 1:31 PM
    nano99
    nano99 Well-Known Member
    Fred
    San Francisco
    2008 WHT DCSB 4X4 SPORT
    workin on it
    Beautiful!!! If only I had Rich parents.:annoyed:
    Yota_Explorer[OP] likes this.
  8. Mar 29, 2018 at 2:02 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  9. Mar 30, 2018 at 1:44 PM
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Only if you were on the East Coast :facepalm:
  10. Apr 5, 2018 at 4:21 PM
    Yota_Explorer
    San Diego
  11. Apr 8, 2018 at 9:03 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I think it will fit the 1st gen as well. If you get me measurements of the bottom exterior and how wide the sides are where it sits on the bed rails I can verify on my 2003.
    The 2ng gen beds taper from front to back whereas the 1st gen is a rectangle.
    Also, what is he height of the bottom to the underneath of the overhang? The bed sides are lower on the 1st gen, so the overhang will sit closer to the cab.
  12. Apr 9, 2018 at 11:23 AM
    Catfish80
    Catfish80 Active Member
    Carlos
    BUMP for a camper I wish I could buy. Great work! :thumbsup:
  13. Apr 9, 2018 at 2:32 PM
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
  14. Apr 9, 2018 at 9:55 PM
    ERod87
    ERod87 Well-Known Member
    Edgar
    Pacoima, CA
    2013 Black TRD Baja
    Bump for a sweet setup
  15. Apr 10, 2018 at 1:07 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Great setup.
Thread Status:
