Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Feb 15, 2018 at 7:33 AM
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Etsy
    Instagram
    ______________________________
    SOLD OUT! No more being made for the foreseeable future as my new job has too much demand for my time.
    ___________________________________________
    **Copolymer/Delrin (black-colored material) is temperature resistant and provides a safe-touch area to hold. Basically, not only does it look cool, it is offered so you don't burn the shit out of your hand during the summer!**
    These are the most overbuilt shift knobs that you will ever see. Dozens of material combinations designed to meet your shifting needs.
    Build examples:
    Copolymer/Delrin:
    -Animate- V2 - Hybrid (Brass core) [350g] (MT example) (AT example)
    6061 Aluminum:
    -Animate- V1 AT - Hybrid (Aluminum core)(example)
    -Animate- V2 AT/MT - Solid [270g] (MT example)(AT Example)
    -Animate- V3 MT - Hybrid (Brass core) [430g] (example)
    316 stainless steel:
    -Animate- V2 AT/MT - Hybrid (Copolymer core) [540g] (MT example)
    -Animate- V3 MT - Hybrid (Copolymer core) [550g]
    6AL-4V Titanium:
    -Animate- V2 AT/MT - Solid 6AL-4V [430g](MT example)(AT example)
    (V1, V2, V3? HUH? U Wot M8?) Click here.
    Installation Instructions:
    - Shimming for orientation
    - V2 MT 3rd Gen (video. By @Electric Shepherd)
    - V2 MT 2nd Gen
    - Additional .pdf instructions for V2 knobs.
    **All machined aluminum threads will require the upkeep of Permatex #81343, #80208 (or equivalent) anti-seize lubricant. All machined stainless and titanium threads will require the upkeep of Permatex #77134 (or equivalent) nickel anti-seize lubricant. I will ship them with the proper lubricant applied, but for added insurance, the buyer should apply the appropriate lubricant to the shifter shaft threads on their truck prior to installation. Brass or Copolymer threads do not require anti-seize lube.**
    **All knobs sold are raw material, no coating or color fill is applied. If you wish to coat the product I strongly recommend that all threads and polymer components be masked. Coat at your own risk.**
  2. Feb 15, 2018 at 7:23 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Any chance of one for an automatic? It doesn't look too much different.
    KOTOC79 and Modkingz like this.
  3. Feb 15, 2018 at 8:01 PM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I just need a stock knob to take measurements from, and it can happen.
    Slickwhenwet likes this.
  4. Feb 15, 2018 at 8:02 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
  5. Feb 15, 2018 at 9:41 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Nice machining. Looks like Fusion360 too:thumbsup:
    OG_Tacoma, corgimas, Modkingz and 4 others like this.
  6. Feb 16, 2018 at 2:18 AM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Thanks! Yep, all of my personal projects are done with fusion.
    For company stuff, I have to use mastercam. This has to do with documentation sharing, and it is also frowned upon to tie up the network licenses for levels 3+ unless absolutely necessary.
  7. Feb 16, 2018 at 9:44 AM
    El Taco Blanco
    Stock (for now)
    @7r41lbr34k3r here is a pic of an automatic knob just to give you an idea. I'll work on getting an OEM knob stop send you.
  8. Feb 16, 2018 at 10:03 AM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Definitely some challenges to be faced here. The boot collar for this is epitrochoid-shaped. I would have to make a transition from milling that shape ... then blend into a simpler (i.e. machinable on a lathe) profile. Otherwise, milling the entire thing would price it quite a bit away from what any reasonable person would pay.
    Edit: or, I could make the collar itself ... change the OD feature to a more blend-able shape. Then we would have to figure out the feasibility of swapping that out without damaging the boot.
  9. Feb 16, 2018 at 10:53 AM
    El Taco Blanco
    Stock (for now)
    Yeah seems like a lot of work. They are some great looking knobs though!
    TeecoTaco likes this.
  10. Feb 16, 2018 at 11:39 AM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ugh, I really need to up my vocabulary...epitrochoid?
    Hmmm, that chicks ass looks a little epitrochoidal...
    corgimas, Denteen, JPNess and 6 others like this.
  11. Feb 21, 2018 at 2:03 PM
    TeecoTaco
    SW Ontario
    Rick, awesome workmanship...awesome feel, looks incredible. Thanks very much again!
    Edited for better picture
  12. Feb 21, 2018 at 2:18 PM
    Slickwhenwet
    Slickwhenwet Well-Known Member
    2017 Tacoma TRD offroad
    I would like to see one for an automatic
    El Taco Blanco likes this.
  13. Feb 21, 2018 at 4:21 PM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    The only one in Canada, looks great! Definitely keep your tongue away from that for at least a few more months.
    I might tackle this project, but I don't think a similar boot connection is going to be achievable at this price point. I might just have to make a regular knob.
  14. Feb 21, 2018 at 4:37 PM
    TeecoTaco
    SW Ontario
    Triple dog dare me?
    Lol crappy pics, I'll try to get some better light angles for less glare.
    As a side note, I didn't chamfer the lug and I didn't put an insert for a tortion fitting either. I was just putting it on to see how it all worked and it snugged up real nice in the perfect alignment. Then I thought what the hell lemme try the collar and it clicked right it place and is firm and snug. Will have to see if temps fluctuations loosen anything up but for the moment its perfect as is.
    For the auto knob engineering...would it not be easier to fashion a shifter boot fitting to your biĺet and 86 the plastic collar altogether?
    Again, many thanks
    @69TACO16 lookey what I got!
    69TACO16 likes this.
  15. Feb 21, 2018 at 5:25 PM
    mulage
    mulage Well-Known Member
    Bryan
    Central, North Carolina
    2020 TRD off-road
    could you make these out of black or gray delrin?
    or coat these with a coating like the flossy knobs so they don't get hot in the summer?
    corgimas likes this.
  16. Feb 22, 2018 at 2:47 AM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    *gasp* Triple? That is srs business.
    Yes, that would be ideal if the boot collar was easy enough to remove. I don't think the product would go over well if the installation was too involved.
    I wouldn't make them out of delrin, simply because the nature of making this eccentric design means that I must do my work-holding on visible features. I must be able to perform a final polishing operation to remove any superficial scratches. With delrin, the chances of it looking like shit by the end of the process is pretty high. I wouldn't want to sell anything that is less than what I call "perfect". Delrin does not polish well, at all.
    If the threads and sphere were on the same centerline, I would be able to make a fixture that would allow me to skim scratches from the outer profile on a lathe, all in one simple operation. I could technically still make a fixture for the eccentricity, but it would be a real pain in the ass to set up. So it's 2 parts of me worried that the knob will scratch/need a coating to protect it, to 1 part pure laziness.
    EDIT: I can make delrin knobs with the hybrid MT design discussed later in this thread.
    As far as the flossy coating, I'd be offering that for sure if I knew what the heck they were doing ... and it wasn't too much trouble.
    The beauty of raw aluminum and stainless is that you can just file/sand/scotch brite any kind of imperfections that may develop.
    Some of you may also have noticed that just by driving you are slowly polishing it to a shiny finish. You may even have to hit it with some scotch brite from time to time, just to keep from blinding yourself.
  17. Feb 22, 2018 at 4:49 AM
    69TACO16
    69TACO16 Well-Known Member
    Rick
    Caledon, Ontario
    16 MGM DCSB TRD 4x4 SPORT
    de-badged, tint front windows, led interior lights, door sill protectors, led b/up lights, 5" factory step rails, yellow turn signal bulbs, added 4 D ring tie downs. Took off the black vinyl stripes between the doors. Changed the grill - from Custom Car Grills, Finally got a tonneau cover put on. 31" light bar ( white & amber ), tailgate light bar, sunvisor covers ( to hide warning labels ), new bedside decals - still too cold to put them on tho. Flag decals to go on too, again too cold still. Got a 2 switch, switch plate to replace that useless cubby hole to the left of the steering wheel.. still to be installed ( hopefully this weekend ). Upgraded the tires to G/Y Duratracs... loving them, no plowing the driveway !!
    That looks awesome !!! Definitely keep your tongue off it.... LOL
  18. Feb 23, 2018 at 6:35 AM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    A couple side engrave options for the retro offerings. The second side would be mirrored, of course ... so they both flow the proper direction.
    mtip and El Taco Blanco like this.
  19. Feb 24, 2018 at 4:53 AM
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Also, thanks to @MarcosBalderas, I expanded his SR bed side decal side engrave request/idea to the rest of the trims.
    I might have to replace mine with this configuration, but I'll wait until the end. You fellas have some great ideas.
  20. Feb 24, 2018 at 8:38 AM
    El Taco Blanco
    Stock (for now)
    Looks great! I have the same, but an SR5.
    7r41lbr34k3r[OP] likes this.
