Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Apr 8, 2021 at 10:09 AM
    #3141
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :devil:
  2. Apr 8, 2021 at 10:11 AM
    #3142
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    DanMan611, TeecoTaco, mtip and 4 others like this.
  3. Apr 8, 2021 at 11:10 AM
    #3143
    DanMan611
    DanMan611 Well-Known Member
    Dan
    Hellertown, PA
    2021 DCSB TRD OR 6MT 4X4
    Glad you ended up with one of these, @daveeasa. That is definitely going to be a hefty knob!!! My current knob is ~450g and it feels almost too heavy for me. You'll be slamming gears in no time!
    @FloBass, how could you resist installing this on your truck? Did you have it mounted above the mantle so you could gaze upon it more often??? :drool:
    FloBass and daveeasa[QUOTED] like this.
  4. Apr 8, 2021 at 11:47 AM
    #3144
    FloBass
    FloBass Well-Known Member
    Eric
    SoFla
    Trolling for now
    :laughing: It's pretty much been a paper weight next to the work laptop on my desk. Held off installing it until I got around to installing the UDR short throw shifter, which also didn't happen before I sold the truck.
    tonered likes this.
  5. Apr 8, 2021 at 11:53 AM
    #3145
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you're picking paperweights, you could do a whole lot worse.
    DanMan611 and 907rx7 like this.
  6. Apr 8, 2021 at 11:55 AM
    #3146
    daveeasa
    David
    PNW
    Do I need to start going to the gym to prepare for this beast?
  7. Apr 8, 2021 at 12:07 PM
    #3147
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Install should go smoothly if you have an engine hoist, but after that your life actually gets easier.
  8. Apr 8, 2021 at 12:08 PM
    #3148
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So, definitely lift gate service for delivery?
  9. Apr 8, 2021 at 12:18 PM
    #3149
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I dunno it's close, best to rent a fork lift to be safe.
  10. Apr 10, 2021 at 12:01 AM
    #3150
    Alfamua
    Alfamua Well-Known Member
    Alfa
    Sacramento
    17 TRD OR
    Fox 2.5 coilovers dsc. Fox 2.o with dakar. SSO slimline stage 1 and 2
    Well since I can't get on the list for the last batch. I scored myself a near perfect condition knob on the used market. Looks awesome
    Aqualoon, Watkinseli91, mtip and 5 others like this.
  11. Apr 11, 2021 at 8:39 PM
    #3151
    daveeasa
    David
    PNW
    OK, I kind of get it now. This thing is nicer than my truck. I can see not wanting to install it and make it look bad due to the enclosure not holding up.
  12. Apr 12, 2021 at 3:24 PM
    #3152
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Update #4. Not bad for being away for a week. Most of the parts made, with the exception of a few aluminum hybrid cores, and a SS collar.
    So. Many. Parts.
    DJFriar, LandoLakes, Afilao and 5 others like this.
  13. Apr 12, 2021 at 3:31 PM
    #3153
    daveeasa
    David
    PNW
    Someone catch me up on the thinking behind choices of spec? Aluminum lighter than stainless and titanium expensive but in between?
    tonered likes this.
  14. Apr 12, 2021 at 3:36 PM
    #3154
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  15. Apr 12, 2021 at 3:37 PM
    #3155
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Weight, bling factor, and some go aluminum purely to get the pocketed shift patterns. Those are the primary 3 reasons I'd say.
    daveeasa[QUOTED] and tonered like this.
  16. Apr 12, 2021 at 3:40 PM
    #3156
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Heat is also an issue with AL. Hot in the summer, cold in the winter, which you don't have to worry about.
    daveeasa[QUOTED] likes this.
  17. Apr 12, 2021 at 3:56 PM
    #3157
    daveeasa
    David
    PNW
    Oh, I just watched the install video, Not sure but it sort of looks like the collar is something extra I need to buy? And maybe some shims so I can get a just-right tightness?
  18. Apr 12, 2021 at 4:01 PM
    #3158
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    The pc that has TRD on it is the collar, you need to remove it to install.
    tonered and daveeasa[QUOTED] like this.
  19. Apr 12, 2021 at 4:17 PM
    #3159
    daveeasa
    David
    PNW
    And pocketed shift patterns are the top engraving of R-6? But mine, being stainless, has that so it would have just been an extra cost/hassle with stainless vs aluminum?
    Ah, found it:
    The pocketed option is only available for shift patterns on aluminum, and costs no extra.
    If I understand that right, it's the difference between fully machining a trough (pocketed) vs an outline (engraved?). I'm sure I'm butchering that terminology but I think I see it in the photos now. It was rather hard to see without some serious scrutiny.
    So, really I just need anti-seize for the threads once I figure out if my core is Al or SS and then some sort of shim which can probably be anything roundish and non-binding-ish and a zip tie to hold the boot to the new collar. I think I got it now. A small set screw makes so much more sense than that twist-on thingy but I guess that saves them a little bit of installation time.
    Gosh, I feel like I'm just starting to learn about this magical unicorn thing.
    Thanks for helping me come up to speed, I thought I actually knew most of the details on this but apparently not.
    TeecoTaco likes this.
  20. Apr 12, 2021 at 4:41 PM
    #3160
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Shims...don't forget shims for alignment
