Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Jun 8, 2021 at 6:31 PM
    #3561
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    For sex
    tonered likes this.
  2. Jun 8, 2021 at 6:34 PM
    #3562
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Your words, not mine. LoL!
    tonered and TeecoTaco[QUOTED] like this.
  3. Jun 8, 2021 at 6:35 PM
    #3563
    TeecoTaco
    SW Ontario
    Actually stole that from Tony
    tonered likes this.
  4. Jun 8, 2021 at 7:32 PM
    #3564
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    This was my first thought, and definitely going to try it. I'm not tapping the Ti(big nope), so that will be clearance and delrin only threaded. Main worry here is the delrin lifts away and creates a gap due to the pressure from the set screw. At a smaller diameter like this, though ... it'll probably be strong enough. It's not an idiot proof solution by any means, but will be fine for those who understand physics.
    Thread milling the Ti is the obvious solution, theoretically ... but the backlash compensation on my budget mill is pretty jarring and would break such a small tool.
    tonered likes this.
  5. Jun 8, 2021 at 7:36 PM
    #3565
    lapoltba
    CT - 06076
    Tough to do on a BP, but form taps are your friend in shitty materials. Threaded Delrin is a no-go IMHO, especially in small pitch. Anything more than the right torque and the therads are gone.
    TeecoTaco likes this.
  6. Jun 8, 2021 at 7:48 PM
    #3566
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    A form tap in Ti could work if I had a rigid tapping feature, but no spindle encoder on my mill unfortunately and doing it by hand is like trying to make "fetch" happen.
    4-40 would strip fairly easy, but 6-32 is pretty strong in Delrin believe it or not. V2 collars have a 10-32 and to my knowledge not 1 has been stripped. I'm using 6-32 for the V3 core to hold the collar cover, absolutely no worries.
    lapoltba[QUOTED] and TeecoTaco like this.
  7. Jun 8, 2021 at 7:50 PM
    #3567
    TeecoTaco
    SW Ontario
    This is a Ti radio knob thread now!
    tonered and mtip like this.
  8. Jun 8, 2021 at 8:00 PM
    #3568
    lapoltba
    CT - 06076
    Form taps can work with hand feed or a floating holder since they will self feed once started, but it's definitely not ideal.
  9. Jun 9, 2021 at 2:07 AM
    #3569
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Yeah, if I had to do that I'd just not make them. If the clearance hole idea doesn't work out it's back to the drawing board.
    I need that new HAAS, solves every issue and even gives me options.
  10. Jun 9, 2021 at 6:28 AM
    #3570
    douglas_ngo
    douglas_ngo Well-Known Member
    2018 Tacoma TRD 4x4 6MT
    We need the handbrake. I am not aware of any aftermarket company who makes one. Plus you will use it every time you drive your truck especially for us manual guys. Can't say that about the radio knobs. haha
    Plus you don't need to make different version as I believe it is the same for both manual and auto
  11. Jun 9, 2021 at 4:02 PM
    #3571
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    You could put a hidden dickbutt on the bottom of every handbrake you make. That way every time someone uses it, they finger your dickbutt. Just saying....
  12. Jun 9, 2021 at 4:23 PM
    #3572
    TeecoTaco
    SW Ontario
    Ughhh...what have I done?
    Law of unintended circumstance I suppose
    tonered likes this.
  13. Jun 9, 2021 at 4:30 PM
    #3573
    513Mugsy
    Cincy
    Well you couldn't have exposed dickbutts on radio knobs. How would you explain that to the children?
  14. Jun 9, 2021 at 5:02 PM
    #3574
    TeecoTaco
    SW Ontario
    Creatively
  15. Jun 13, 2021 at 7:52 PM
    #3575
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    I got around to installing it today. So easy that even a guy with a broken collarbone can do it! Instead of using the included zip ties I used thread, overlapped it a bunch of times, then triple knotted it. I did that to avoid any sort of bulge from the zip tie.
    C41n, mtip, tonered and 5 others like this.
  16. Jun 13, 2021 at 8:37 PM
    #3576
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Um, I’d like to to sign up for the ti radio knobs. It is an actual need, not just a want. Where am I am signing?
    tonered and TeecoTaco like this.
  17. Jun 14, 2021 at 5:29 AM
    #3577
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just send a kidney or appendage to @7r41lbr34k3r . That will reserve your spot.
  18. Jun 14, 2021 at 6:20 AM
    #3578
    douglas_ngo
    I also painted my chrome trim to body match color while installing my shift knob.
  19. Jun 14, 2021 at 7:14 AM
    #3579
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    So…. I’ve got this pen, it’s a one of a kind, and
  20. Jun 14, 2021 at 7:16 AM
    #3580
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Do you have all the pieces? Will pay to have this in my life!
    Lung, liver, big toe?
