Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Oct 9, 2018 at 5:57 AM
    #661
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Haha, neither can I!
    tonered likes this.
  2. Oct 9, 2018 at 11:13 AM
    #662
    Tonche
    Tonche Well-Known Member
    Tony
    2018 Tacoma TRD OR ACLB
  3. Oct 9, 2018 at 6:52 PM
    #663
    wahudiditagain
    wahudiditagain Well-Known Member
    Wes
    Central Ohio
    2017 TRD OR DC 4x4 Inferno
    I will second that. However, please post what you are working on so we can begin saving money.
    7r41lbr34k3r[OP], tonered and TD90S like this.
  4. Oct 10, 2018 at 7:28 AM
    #664
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    @Rooster OG
    Is that the stock length boot? I see Redline Goods makes them in different lengths.
    The stock boot seems to long to me.
    tonered likes this.
  5. Oct 10, 2018 at 9:22 AM
    #665
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    Huh, I only see auto and manual on their site when I select the taco. When I had the oem boot off, they were the same size fwiw. When you get the boot on, with the v2 knob, you can fold down as much material as you want when you zip tie the boot to the knob. That’ll let you make the boot as tight or loose as you want. I hope this helps!
    TD90S[QUOTED] and tonered like this.
  6. Oct 10, 2018 at 9:25 AM
    #666
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Once the parts are in the cart, they give you some options like boot length, armrest height, and mounting brackets. So, it sounds like you got the stock length boot then. That helps.
    I'm thinking of going at least -2.5in since I am using a plain ball from @7r41lbr34k3r with the grommet mod.
    TD90S likes this.
  7. Oct 10, 2018 at 9:28 AM
    #667
    TD90S
    GA
    ‘18 TRDOR 6MT
    Thanks for the tip!
  8. Oct 10, 2018 at 12:02 PM
    #668
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I'm planning to update the V1.0 MT to something like this (similar to AT concept), so I should probably also have a version to do the work of a grommet.
    Fiddling with this dimension has been killing me (@TeecoTaco 's knob for reference) , might have to go full V2 if I don't like the V1.1 setup.
    TeecoTaco and tonered[QUOTED] like this.
  9. Oct 10, 2018 at 12:10 PM
    #669
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! Put me down for a grommet delete piece when you get to that point. Either black durocoat if you happen to be doing some or unfinished? An I.D. the same as the trim ring or larger would work for me. I like where the boot is sitting with the grommet mod.
    Friggin' @TeecoTaco . Never making it easy. :p
    Just working on the tip, huh?
    What is seen, can't be unseen.
    TeecoTaco likes this.
  10. Oct 10, 2018 at 12:20 PM
    #670
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I do plan to print them, simply because it has always bothered me putting metal into plastic for a twist lock. It's just a bad idea and a big reason that the V2 was even developed.
    I was thinking o-rings on a taper like @duckytw did, just so it doesn't rattle around.
  11. Oct 10, 2018 at 12:24 PM
    #671
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahahaha! :laser:
    That works for me.
    I'm ready whenever you are but am not in a rush. Once I painted the chrome ring, it is mostly out of my mind.
  12. Oct 10, 2018 at 12:27 PM
    #672
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Have anything direct-thread for 2nd Gen 5spd? Without a collar?
  13. Oct 10, 2018 at 12:46 PM
    #673
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  14. Oct 10, 2018 at 1:02 PM
    #674
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Are you keeping the factory 2nd Gen collar? It wouldn't be very predictable for me to make something with that collar still in place, because there would certainly have to be a gap to leave room for final orientation.
    I could also make a custom core for the hybrid listed for sale in the OP. It would be significantly cheaper without the titanium part, and it's already engraved for 5sp.
  15. Oct 10, 2018 at 1:05 PM
    #675
    dirty deeds
    Nick
    Eastern KY
    OE knob just spins till "good enough". I've never quite cranked it til it stopped 100%, afraid to ruin the threads of whatever poly insert is in it.
    Far as the collar, I hate chrome, so maybe losing it isn't so bad. Mentally, I dread the thought of removing my center console to get to the boot's collar (4-day clutch install BS :rolleyes: )
  16. Oct 10, 2018 at 1:06 PM
    #676
    dirty deeds
    Nick
    Eastern KY
    tonered[QUOTED] likes this.
  17. Oct 10, 2018 at 1:07 PM
    #677
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Excellent! :cheers:
  18. Oct 10, 2018 at 1:09 PM
    #678
    dirty deeds
    Nick
    Eastern KY
    The black delrin, engraved with 5spd markings would be sweet! I don't really know what weight does for me, or even what the OE weighs.
    7r41lbr34k3r[OP] and tonered like this.
  19. Oct 10, 2018 at 3:36 PM
    #679
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    FML, I go to prison for a nite and All kinds of skullduggery takes place in my name...
    Ti collar v2.1 to v1.0 knob with penis insert...its this what were talking aboot ?
    He hasn't even bought me dinner yet!
  20. Oct 10, 2018 at 4:02 PM
    #680
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I can do it. Diameter of Tony's knob is close to 2.5", so we can go with that shape if you like big ... Knobs.
    This design has no phallus, but here is its butthole.
