Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Oct 30, 2018 at 12:47 PM
    #781
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You left the door wiiiiddddee open there. Just sayin'. . .
    Your knob looks great in pics though.
    TD90S likes this.
  2. Oct 30, 2018 at 1:10 PM
    #782
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    WIDE open!
    tonered likes this.
  3. Oct 30, 2018 at 1:58 PM
    #783
    Tonche
    Tonche Well-Known Member
    Tony
    2018 Tacoma TRD OR ACLB
    On a completely serious note, this thing is really badass. The quality is so far beyond what I could have imagined.
    I recommend everyone read the shimming instructions. I was lazy and just started cutting shims. Went through more than half of the yellows. Which was a pretty thick shim. Probably went around more than one turn.
    7r41lbr34k3r[OP] and tonered like this.
  4. Oct 30, 2018 at 2:06 PM
    #784
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    My package isn't small ... IT'S THIN!
    TD90S and tonered like this.
  5. Oct 30, 2018 at 3:56 PM
    #785
    Rzilla80
    Rzilla80 Active Member
    Ralph
    2018 Taco Trk SR5
    Definitely worth the wait!! It's a Masterpiece!! :bananadance:
  6. Oct 30, 2018 at 5:12 PM
    #786
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I release them into the wild, and they come back digitally ...
  7. Oct 30, 2018 at 5:13 PM
    #787
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    No shit eh, it's like herpes simplex III
  8. Oct 30, 2018 at 5:25 PM
    #788
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you like something, set it free. If it doesn't return, hunt it down.
    TeecoTaco and 7r41lbr34k3r[OP] like this.
  9. Oct 30, 2018 at 5:50 PM
    #789
    TeecoTaco
    SW Ontario
    And kill it with fire
    Beemaster and tonered[QUOTED] like this.
  10. Oct 30, 2018 at 6:08 PM
    #790
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nuke it from orbit. It's the only way to be sure.
    TeecoTaco[QUOTED] likes this.
  11. Oct 31, 2018 at 10:26 AM
    #791
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Orientation/Installation instructions
    When you screw your new shift knob onto your truck, there is a good chance that it will become tight at an incorrect orientation. I couldn't use the same orientation method of the stock knob, because there would be too high a risk of galling the threads (further explanation here). Outlined below is my shim method.
    Note the yellow square at the bottom of the thread (pics below) ... that is where the supplied shim(s) go. I supplied enough of each color for you to cut a few of each to proper size. Reference the chart below for thickness of the color coded shim stock.
    The thread pitch for all versions is 0.0492125 per turn, so if you place a yellow shim (.020 thick) down there it will net to a little less than half of a turn difference. Two yellow shims and two blue (.005) shims will get you right back where you started, if that makes sense ... because their thickness will add up to just above the pitch of the thread.
    Whatever solution you end up with, prep a blue shim and keep it in your cup holder, because the shaft on your truck will compress/settle the shims about that much over the first couple days.
    Here are the colors and their thicknesses of the shim stock that I use. I don't always send the same colors, so here are all of them.
    **Warning**, do NOT use tools to tighten the knob as overtorquing can cause damage(same goes for folks with great hand strength). It is better to play it safe by taking a few seconds to re-shim than it is to force orientation and risk damaging your truck.
  12. Oct 31, 2018 at 10:27 AM
    #792
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Updating the orientation info just so I can use a single link. It can always be found in my signature, and if you are on mobile make sure you are viewing in landscape mode to see it. My old links are too wordy anyway.
    tonered likes this.
  13. Nov 1, 2018 at 4:59 PM
    #793
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Action shot of the sphere finish pass.
  14. Nov 5, 2018 at 7:08 PM
    #794
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Batch update. 11/9 ship date is my goal for these, just need engraving and collars.
    TD90S, alimjr, beergeek and 2 others like this.
  15. Nov 6, 2018 at 11:29 AM
    #795
    Cough*Strawberry
    Cough*Strawberry Active Member
    Traveler
    2018 Tdr Sport 4x4 MT
    You have seriously mastered your craft man. This level of prideful professionalism make me happy! Glad to give you my hard earned money sir.
    7r41lbr34k3r[OP] and TeecoTaco like this.
  16. Nov 7, 2018 at 6:56 AM
    #796
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I see myself more as the eternal student, hard for me to swallow that ... but I do appreciate it!
    The pride part is dead on, though ... couldn't be happier how all of this transpired right here on the boards. This shift knob project has come a long way, and hasn't even been year yet. Still open to tweaking more design features out of it, too ... just haven't been able to think of anything worthy.
    tonered likes this.
  17. Nov 7, 2018 at 7:03 AM
    #797
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Well . . .
  18. Nov 7, 2018 at 7:09 AM
    #798
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Haha, I was actually spending time on something like that a few mos ago with @WulfmanX (who had some really good ideas how to integrate it).
    Could surely do that, but it would result in a knob that rests much taller than stock height. Can't tell you how many times I've been asked if I could drop the height of the knob, but the shaft itself is the limiting factor that prevents us from getting it where they usually want to be.
    tonered[QUOTED] likes this.
  19. Nov 7, 2018 at 7:23 AM
    #799
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's hilarious. I'd vote for either lasers or oil slicks.
    That is what I like about the knob you made for me. It's as low as possible.
    It sounds like you are getting into the short shifter business? If so, :spending:. Hahaha!
    Here's the idea that I think will NOT work. Our saab had a pretty long throw for a car and was a linkage operated shifter. Some genius put the SSer on threads. You could adjust it to your liking. After dropping it down so far, you had to delete the reverse lockout function (key removal only) which was a big positive for anyone not familiar with driving saabs. I made the mistake of not hammering on the exhaust tunnel a bit to drop it even lower. Still, it was neat mod.
    Given the odd feedback about the URD SS and that there are no 3rd Gen specific instructions even though it is different, it sounds like there is room in the market for something even cooler?
  20. Nov 7, 2018 at 8:01 AM
    #800
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I vote for every single knob sold, when the button is pushed it triggers @TeecoTaco 's radio to play Enya's Sail Away.
    Yeah, URD really seems to have mailed that in for 3rd gen ... somebody needs to do it properly. If I had better inspection equipment I would do it myself. We ship everything out to Iowa that needs that level of probing. Crappy QC dept where I work, but we really don't need one at all.
    TeecoTaco and tonered[QUOTED] like this.
