Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Jan 23, 2019 at 9:20 AM
    #1161
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what Rick did for me. I enjoy every shift with it.
  2. Jan 23, 2019 at 9:22 AM
    #1162
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Catching me at a bad time as I just started a batch, so I won't be able to take an order for a few weeks yet.
    I did just make one for @RieOrDie 2nd Gen, V2 with a new collar ... still waiting for him to have time to install it to get confirmation on my collar design. He was kind enough to send me the OEM collar to inspect, so I'm 99% it'll be good.
    If you don't want the collar replacement, I'd just need to know the shaft diameter at a particular length (it is tapered). Won't know the length until you pick a ball diameter and then I'd need to model it up and such.
    tonered and Livinserene like this.
  3. Jan 23, 2019 at 9:31 AM
    #1163
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    oh yeah, be sure to check the first post again (this for anyone confused at the offerings) ... I updated with many more renderings yesterday to show parts of all the main configurations.
    dirty deeds and tonered like this.
  4. Jan 23, 2019 at 9:35 AM
    #1164
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I know that I've talked in the past at simplifying the first post into preconfigured options, then burying that huge wall of information for those who wish to see it.
    BUUUUT, I decided against that. My target market is technically minded individuals who have experience modding their trucks, so catering to a lowest common denominator kinda takes away the spirit of what I am doing.
    For now I will just keep adding more and more information to that first post until it breaks or something.
  5. Jan 23, 2019 at 9:44 AM
    #1165
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'd love to replace the boot's collar. It's some kind of material and chrome colored YUCK :puke: But I'm afraid I'd have to modify the boot material itself to remove and reinstall. Remember, the 2nd gen MT knob doesn't "lock" into the boot, knob just threads down on the shaft and tightens against the boot collar. When I did my clutch install, I noticed there's a step/ledge on the shift lever where that collar rests, before the threads for the knob.
    I'll measure from the collar to end of lever for total depth, lever diameter below threads, on the threads, and the thread length. I'll measure the stock knob's diameter and round up to the next whole inch size likely, it's a bit small.
  6. Jan 23, 2019 at 9:55 AM
    #1166
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    The collar for @RieOrDie 's 2nd Gen was held in with sewing thread (3rd Gen uses zip tie). His could have been altered at some point, unless he is original owner ... not sure about that part.
    The total length of the V2 should be about the same as stock, and my collar ID is 1" ... which will go over the step even if there is interference.
    Stock 3rd gen averages out to 2-1/8" diameter, and I rounded up to 2-1/4" ... because this is no Subaru! The TRD ball is this size, and many seem to like it, so I went with that and stuck with it ever since.
    You can always grab a proper billiard ball to see if you like it, pretty sure those are the same size as what I am making.
    dirty deeds[QUOTED] and tonered like this.
  7. Jan 23, 2019 at 10:15 AM
    #1167
    dirty deeds
    Nick
    Eastern KY
    2-1/4" sounds perfect, like a billiard ball and TRD knob. Felt both many times ;)
    Just went to lunch and checked it. The collar doesn't sit on a lip, just forces itself down the taper of the lever when the knob is screwed on. Not something I feel like worrying too much about right now, I can always pick up the collar later I feel.
    I'll get the measurements when I get home this evening. Even snap a pic or two for us of the stock. Aside from those pending numbers...
    Here's what I want @Chelle94 and @7r41lbr34k3r
    All black delrin, no inlays or other materials, 2-1/4" diameter, with knurling. All one piece, like the stock one. No top or other engraving. Pretty much what @tonered has/had at some point, know I saw this in one of his pics.
  8. Jan 23, 2019 at 10:23 AM
    #1168
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    I apologize that cellphone pics are not doing this justice, in the way that the Entune screen is not as dirty as it appears. I promised Rick that I'd get him something much better.
    Eight months of use / rosy palm polishing. Redlinegoods boot (ordered 2in shorter than stock). De-chromed boot collar. And, a bit of somethin', somthin' from the bottom of the OP.
  9. Jan 23, 2019 at 10:29 AM
    #1169
    dirty deeds
    Nick
    Eastern KY
    Clean. Simple. Elegant. Sexy.
    All the things a boy wants in his first knob
    tonered[QUOTED] likes this.
  10. Jan 23, 2019 at 10:35 AM
    #1170
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You said it! Thanks!
    Rick's other knobs are absolutely killer, but the round ball with my fingers curled under . . . It is just slick shifting.
    For the 3rd Gen'ers, that somethin', somethin' creates the perfect gap and a big step up from the grommet mod.
  11. Jan 23, 2019 at 10:53 AM
    #1171
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    It does make quite the intimate connection with the stock collar.
  12. Jan 23, 2019 at 10:59 AM
    #1172
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl::rofl:
    :bananadead:
    Tab P into Slot V?
  13. Jan 23, 2019 at 11:40 AM
    #1173
    dirty deeds
    Nick
    Eastern KY
    Does look good, just won't work on the 2nd gen
    tonered likes this.
  14. Jan 24, 2019 at 6:58 PM
    #1174
    calenatar
    calenatar Well-Known Member
    Ohio
    2019 Tacoma TRD off road, 6mt, magnetic grey metallic
    none so far
    Got my knob a couple days ago, seriously nice machine work. Got it installed earlier. LOVE IT. So much better than the factory garbage
  15. Jan 24, 2019 at 7:09 PM
    #1175
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Side by side, great perspective ... Nice knob.
    tonered likes this.
  16. Jan 25, 2019 at 7:48 AM
    #1176
    calenatar
    Ohio
    none so far
    Things a man should never say to another man lol. It is a really nice knob though
  17. Jan 25, 2019 at 7:50 AM
    #1177
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think everyone here has a firm grasp on their manhood?
    Besides, knob jokes are hilarious. What do I rage about, you ask? Fucking ball kicking for laughs in shows / movies. :mad:
    TD90S likes this.
  18. Jan 25, 2019 at 8:24 AM
    #1178
    calenatar
    Ohio
    none so far
  19. Jan 25, 2019 at 10:20 AM
    #1179
    dirty deeds
    Nick
    Eastern KY
    I know, truck is dirty. That's high quality eastern Kentucky clay dust!! Good stuff!
    @7r41lbr34k3r if you need anymore info than what I wrote down, let me know. I couldn't find my mics so I used a good tape measure. I can run to HF and pick up another set if you need more precision. Should be proper measurements for all 2nd gen 5spd MT knobs and shafts
    7r41lbr34k3r[OP] and tonered like this.
  20. Jan 25, 2019 at 10:25 AM
    #1180
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dirty Deeds, dirty truck. Seems legit?
    dirty deeds[QUOTED] likes this.
