Custom Billet Shift Knob for Toyota Tacoma (2-1/4" diameter). ***Utilizes factory boot.***
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 7r41lbr34k3r, Feb 15, 2018.
  1. Feb 24, 2019 at 2:41 PM
    #1361
    7r41lbr34k3r
    7r41lbr34k3r [OP] Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Excellent, you fellas sure made page 69 one to remember.
    @Wtsmith
    Those stainless knobs really are heavy. Protip, mind your right knee when going over train tracks, haha.
    tonered likes this.
  2. Feb 24, 2019 at 2:58 PM
    #1362
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    That's a Delrin knob, V1 AT (w/ aluminum core).
    LamzTaco[QUOTED] likes this.
  3. Feb 24, 2019 at 4:25 PM
    #1363
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    Alright, alright, alright.. The wifey headed out to her sisters so I had enough time to install my new knob! I’m planning on going to hobby lobby soon to get some liquid paint so I can fill the engraving.
    C4417068-CA5E-40BE-B568-39E244E00A59.jpg 2FDD3B78-1452-4005-9D64-5C95D7F61D7E.jpg C9723B24-37CF-49AA-9D41-5D1AF883CE37.jpg
  4. Feb 24, 2019 at 4:31 PM
    #1364
    BlueDevilPharmD
    BlueDevilPharmD Well-Known Member
    Nashville
    2017 Tacoma TRD Off Road
    What configuration is this? It is exactly what I want just with different engravings.
  5. Feb 24, 2019 at 4:44 PM
    #1365
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    TeecoTaco, TD90S, CoastieRon and 3 others like this.
  6. Feb 24, 2019 at 4:46 PM
    #1366
    D.A.R.
    D.A.R. Well-Known Member
    2015 TACOMA TRD PRO
    Sorry sir late to the posting,are you making these for the 2nd gens also?
  7. Feb 24, 2019 at 5:02 PM
    #1367
    Daddy_Firebird
    Colorado
    Honestly, @7r41lbr34k3r will be able to tell you exactly what I got. I went back and forth on a couple things and lost track. All I know is I went with aluminum, knurled delrin around the aluminum, and delrin boot collar. BTW, Install was super easy. Took me a half hour to install not knowing wtf I was doing.
  8. Feb 24, 2019 at 5:17 PM
    #1368
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
  9. Feb 24, 2019 at 5:20 PM
    #1369
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Yep, V2 is what you want for 2nd Gen. If for automatic I may need a few shaft dimensions as I haven't had any to make for that yet. MT is proven though.
    Yup, V2 AT with those features mentioned.
  10. Feb 24, 2019 at 5:21 PM
    #1370
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    I also have this one. There are tons out there, but these two were my favorite.
  11. Feb 24, 2019 at 5:29 PM
    #1371
    D.A.R.
    2015 TACOMA TRD PRO
    Yes it is a automatic trans. V2 knob would that be the aluminum knob with knurled delrin center and collar?
    is this a V2. Any specs or measurements needed will be happy to supply.
    Daddy_Firebird likes this.
  12. Feb 24, 2019 at 5:57 PM
    #1372
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Yup, and the collar would be altered to give a tapered transition to the exposed shaft (unless you added a boot to yours).
    I drop the order form tomorrow at noon Eastern time. If you are in the next group I'll send you a simple blueprint of the dimensions I need.
  13. Feb 24, 2019 at 6:15 PM
    #1373
    D.A.R.
    2015 TACOMA TRD PRO
    yes will be using a boot.
    7r41lbr34k3r[OP] likes this.
  14. Feb 24, 2019 at 6:23 PM
    #1374
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Perfect. No worries then, it will work as is with no modification .
  15. Feb 24, 2019 at 6:24 PM
    #1375
    D.A.R.
    2015 TACOMA TRD PRO
    great thanks
  16. Feb 24, 2019 at 6:54 PM
    #1376
    D.A.R.
    2015 TACOMA TRD PRO
    will the RedlineGoods boot work with your collar?
  17. Feb 24, 2019 at 7:21 PM
    #1377
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Should work for any boot really unless it is super short. Even if the collar doesn't fit through the small hole on the end you just need to invert it until the opening is big enough. Then position optimally, zip tie it from the inside. This is exactly how the 3rd gens come from the factory.
  18. Feb 24, 2019 at 7:32 PM
    #1378
    D.A.R.
    2015 TACOMA TRD PRO
    Perfect thanks
  19. Feb 25, 2019 at 9:00 AM
    #1379
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Here is the link to order form, as promised.
    https://goo.gl/forms/zxG91FGgJkd0nxeW2
    If the link fails it probably means that I have reached maximum capacity and closed it. It will be closed immediately after 10 deposits have been received. Said deposits are fully refundable until I begin machining, so some of the spots may open up again rather soon. Plenty of notice will be given before I open the form link again if that is the case.
    There is a chance that more than 10 orders will make it through before I close down ... naturally I will try to accomodate everyone to the best of my ability.
    There may also be room for more than 10 if custom engraving/feature demand is very low. Either way, I will communicate in here as things play out.
  20. Feb 25, 2019 at 9:07 AM
    #1380
    D.A.R.
    2015 TACOMA TRD PRO
    HRbkAtc.jpg AWSOME -Just ordered.
