Custom bug out camper tricks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Namdnil, Feb 28, 2019.
  1. Feb 28, 2019 at 11:42 PM
    Namdnil
    Namdnil [OP] New Member
    2017 Tacoma crew cab 4x4
    I run an unmodified engine and trans,, living in California, I found the stock gearing along with the multy speed automatic is a great setup. i run an agressive 35 \17 A\Tire, Iperdonally opted to put an alloy wheel that was aftermarket,"A slightly more positive center mount bolt to hub " , is what I replaced them with... I did replace suspension,"complete spring reark both front and rear... Any ok You boys and girls travel into Kern county, Look up by buddy David Hayes,,,, he owns A.1 spring ... Tell You what, You take the truck, or the springs off the truck,,, I don't care!!! Dave will make the springs that rock crawlers to Indy cars,. Dave is the best inhis field... And REASONABLE!!! lol, I don't advertise forr anyone,,,dave at. A1. Is an honestspring Makin fool,, make sure You bring at least a six pack at the time of negotiating.. so that's the truck.
    What custom camper she'll mods have been done.. I'm starting on a bug out off grid unit.. one of a kind.. 12v solar with 110 inverter tie, battery backed, water system with pressure tank pvc, along frame Raul
    ...,bed,table,lights, tool section, battery bank... building it all in my shop.. Any ideas that may have worked well for You send my way.. I will post pictures as I go...
  2. Mar 1, 2019 at 3:59 AM
    s.e.charles
    s.e.charles Well-Known Member
  3. Mar 1, 2019 at 4:01 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Your one of a kind build sounds like everyone else's on TW.
    GoGoGadget likes this.
