Custom Double Cardan Driveshaft Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unixadm, Jul 23, 2018.
  1. Jul 23, 2018 at 8:11 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Oh, tip on installing buy yourself, ratchet straps across the frame to do rough placement :)
    SR-71A and jross20 like this.
  2. Jul 24, 2018 at 5:59 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Axle wrap
    in 4x4 the fronts help remove the load
    my 88 toy 4x4, 99 taco ACLB 4x4 did it too in 1st gear
    my 09 does it even more if I floor it
    There is a rod you can attach to the diff and frame to help or some get ladder bars that can reduce it
  3. Jul 25, 2018 at 8:40 PM
    bren5279
    bren5279 Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    I wonder if they'd consider doing a group buy for cheaper.
    Im second guessing the single driveshaft as now Ill be at 4.88s and probably not able to go above 80 : /
    lordetaco likes this.
  4. Jul 25, 2018 at 8:58 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    ??????? Why not be able to go above 80??? Geared right, should be no problem??? what size tires?
    Are we talking 80 on speedometer or actually 80MPH???
  5. Jul 25, 2018 at 9:04 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    If you want to go the slip yoke/double cardan route, and keep center bearing, you could always buy a rear driveshaft from a long bed tacoma that has the slip in it, bring it to local shop, have them cut the shaft and add double cardan. Driveshaft prob run you $300, shop prob charge you another $300 or so.
  6. Jul 27, 2018 at 4:19 PM
    bren5279
    Brendon
    new bern NC
    actually 80, and its because the critical speed RPMs with 4.88s is right around there with 37s. yes I know most people don't have gears that low, I do because of the 37s.
    huh, why would you need the long bed one? my short bed shaft has a slip joint at the base by the Diff, just not a CV joint by the carrier bearing
  7. Jul 29, 2018 at 2:07 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    I did the same but with a 1350 CV and a 3/4 chevy carrier bearing. Had to mod the crossmember. Ive got pics but havent uploaded them yet
    Key-Rei, canadian bum and Biscuits like this.
  8. Sep 29, 2018 at 8:08 PM
    unixadm
    unixadm [OP] Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Just a quick update after having this driveshaft on my truck for a couple of months and ~1,000 miles. I don't drive the Tacoma every day, and when I do, my commute is short. I was still getting a slight hint of shudder with this new driveshaft, but it was nothing like the OEM unit. I decided today to first try dropping the CB using an OME drop spacer. Doing that made it worse, so I removed it and flipped the CB upside down. ZERO shudder now.
    The rear leafs are simply wrapping too much and I would have been better off removing some of my axle shims, but right now, my setup is perfect. No shudder or vibrations at any speed.
    Not a cheap fix, but I cannot tell you how nice it is to take off and it's 100% smooth. I plan to upgrade the leafs at some point in the future, but for now, I'm happy.
    jross20, EDDO and Biscuits like this.
  9. Sep 30, 2018 at 10:19 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
  10. Sep 30, 2018 at 10:21 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Your thread has been instrumental in developing my Plan B if my current remedies don't solve my vibration issues. Thank you for the detailed post and information.
  11. Sep 30, 2018 at 10:44 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I got under my truck & looked @ rotating the CB 180°. It appears this would make zero difference but I've read several people having luck just flipping it over. What does flipping it do?
  12. Sep 30, 2018 at 10:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The CB tabs are slightly offset from the center. flipping it will raise the shaft ~3/4of an inch.
  13. Sep 30, 2018 at 10:58 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I couldn't tell that by just looking @ it. Thanks!
  14. Sep 30, 2018 at 10:59 AM
    nd4spdbh
    SoCal
    its not much at all. 3/8ths or so offset, but multiply that by 2 when you rotate it makes a bit of a difference.
    MolonLabeTaco[QUOTED] likes this.
  15. Oct 2, 2018 at 8:12 AM
    #35
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Could we get some part numbers used for this? The only way I've seen to do it use 1310 joints. Keeping 1330s would be great.
  16. Oct 2, 2018 at 10:09 AM
    #36
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I flipped my CB & it definitely made it worse. Flipped it back over, added the OME spacers plus an additional thick washer (as the CB drop spacers didn't make much of a difference before) & now I'm down to almost no vibes. VERY little. I'm going to get longer CB bolts & add another washer. I'd imagine that'll make it GTG. Thanks!
    Biscuits likes this.
  17. Oct 3, 2018 at 3:51 AM
    #37
    dreadedyota
    dreadedyota Well-Known Member
    Ernest
    Ontario Canada
    2008 Black Tacoma TRD.SR5.Sport
    Camburg UCA,Cowl Induction, ECGS, Exhaust Reroute.
    Thanks for the write up OP, just baught my truck a few months ago and already hating the shutter and shake. how is the shaft holding up now?
  18. Oct 4, 2018 at 11:02 AM
    #38
    unixadm
    The driveshaft is great and no issues at all. Most of my issues are caused by using the OE springs and the progressive AAL without the overload. I believe this allows for a lot of axle wrap, which screws up the driveshaft angles. When the axle wraps that much, it's hard to shim it correctly.
    I have a set of upgraded 2017 TRD OR springs, which are 1MM thicker per leaf, compared to the 2015 TRD OR springs. I'm debating swapping springs and swapping the AAL over to them. That would certainly help the wrapping a bit.
    For now, it's largely 100% vibration free. I only notice a little shudder if I'm aggressive with the throttle. That also happened when 100% stock.
  19. Oct 4, 2018 at 11:43 AM
    #39
    nd4spdbh
    SoCal
    Dont even freaking bother with the stock leafs of any kind. I had original 2+1 leafs on my 2013, which a TSB upgraded to 3+1, still had axle wrap issues, then a single 2in aal to make it a 4+1, which made axle wrap worse, then 500 bucks for a bud built traction bar which still didnt cure everything.
    350 bucks for some dakar mediums, no traction bar and things are far better than everything i have done in the past.
    Went and did some doughtnuts in my buddies bone stock 2018 TRD OR 4x4.... and i could feel the axle wrapping / hopping.... stock leaf springs are just noodles.
  20. Oct 25, 2018 at 11:10 AM
    #40
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    Was it driveline services in west sac that you passed on OP?
