Custom driveshaft vs traction bars?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by icky crane, Apr 21, 2020.
  1. Apr 29, 2020 at 8:21 PM
    #61
    Slum Lord
    Slum Lord Well-Known Member
    As far as the CalTracs goes...
    I get that it has heims so it allows some twist. I agree with that but I'm sorry it is a poor truck traction device. Maybe for something that has one job of hooking up in straight line only.
    One, it works in acceleration only unless that shackle is supposed to hit the frame when the pinion goes down.
    Two, it probably has harsh engagement unless it is preloaded against the spring. Both of which is bad.
    Three, it is pushing all of the axle force onto the leafsprinf in a way that the spring isnt really designed to handle. It is pushing against the part where only maybe the primary and secondary leafs are. That force is being absorbed by the spring and hanger. It should really be separated out and pushed into the frame or crossmember further away from the axle.
  2. Apr 30, 2020 at 1:09 PM
    #62
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Thank you @White lightning boosted and everyone for the good info.
    Apologies for kinda hijacking the thread there for a second.
  3. Apr 30, 2020 at 6:06 PM
    #63
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    no problem man.
