Custom Extended Brake Brackets
Discussion in 'Suspension' started by mh.meier, Aug 12, 2012.
  1. Aug 12, 2012 at 3:01 PM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front 3-hoop bumper(soon to be single hoop CM) -Rigid 20" SR series light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB 6' Awning -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -Icons Ext Travel front CO's -King 700# coils -Camburg Uni-ball UCA's -Sway-A-Way 2.0 rear shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Flare-less mod -AFE ProForce Magnum CAI (went back to stock) -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I wasnt sure where to post this but here goes.
    I lifted my Tacoma a while back and noticed my brake lines didnt have enough play. So I went to the local Lowes home improvement store and bought a 1/2" X 1" X 4ft steel flat for like 8$
    I bent it using unusual methods to about a 90 degree angle, drilled two small holes in it and painted it black. I removed the rear brake brackets and placed my new bracket in between the old bracket and the axle. I used the factory bolt to mount the new bracket and an appropriate sized bolt to mount the new bracket and old bracket. I had a few extra inches of play in my brake lines even at full flex. I repeated this process for the front brake lines, but only bent the new brackets about 30 degrees. A cheap simple way to increase thelength of your brake lines without having to purchase new lines.
    Here are some photos for refrence.
  2. Aug 12, 2012 at 3:05 PM
    Texoma
    Texoma Well-Known Member
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Poweraid TB spacer, a bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA 2035s headers and dey are perty, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, LR UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, 5 factory 16" steels wit Pep Boys special Dakota Definity MT's in 285/75/16, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more but it's alre
    That's one way to avoid having to buy extended brake lines. Nice ingenuity.
  3. Aug 12, 2012 at 3:09 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    My front brake lines have plenty of slack left at full droop. Not sure that was needed.
    This'll work for mild suspension changes. If you really change things around in the rear to up your travel, you're gonna need extended brake lines.
  4. Aug 12, 2012 at 3:18 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Well my brake lines did not have plenty of slack, especially in the front. So this was a cheap way for now to fix that. Not to mention super easy. Took all of 10 min.
  5. Aug 12, 2012 at 3:19 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Thanks amigo
  6. Aug 13, 2012 at 7:38 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Super easy, super cheap. I will eventually buy new brake lines after the SAs but right now this will do.
