Custom front bumper for '96 2wd 5 lug Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by BarnBoy, Nov 15, 2018.
  1. Nov 15, 2018 at 5:48 PM
    BarnBoy
    BarnBoy [OP] Well-Known Member
    96 Tacoma 2wd
    Curious if anyone has ever made or installed a front bumper on a 1st Gen 5 lug Tacoma? Considering building my own. Would be a frame of 1x1" 1/8" wall square tube, covered in 3/32" steel sheet. Would also want a hoop on front to protect the grille/rad/headlights. Thinking of something similar to the ARB bull bar, but a bit lighter. This is not for offroad, mainly for protection of the front end here in deer central. And it'd be a cool project because I have never seen anyone build one for a 5 lug before.
    Goal would be to keep it below 75lbs if at all possible, I dont think that extra weight would be a problem. But feel free to weigh in with thoughts. Also curious on mounting points.....how do most bumpers mount to the frame on 1st Gen Tacos?
  2. Nov 15, 2018 at 9:27 PM
    UnderFire
    UnderFire Well-Known Member
    1x1 1/8th is pretty small, something like 2x2 3/16ths would work much better.
    BikerinBlak909 likes this.
  3. Nov 16, 2018 at 1:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am not sure if the 2wd has the same front end hardware as the 4x4.
    Then my bumper was made for a Solid Axle 83-85 Toyota Pick up so was not just a bolt on project
    I mounted my bumper to the 4 bolts where the front hooks were.
    replaced the front of the frame with end caps with M12x1.25 welds nuts and also caught the front cab mount bolts
    that gave me 4 bolts on each side .
    Never fails though those evil deer run into the side of the truck never the front
    BarnBoy[OP] likes this.
  4. Nov 16, 2018 at 5:50 AM
    BarnBoy
    96 Tacoma 2wd
    Yes....and also weigh 4x as much. 2x2 is pretty stinking heavy stuff. The truck frame is only @ 1/8" thick though. The frame made of tubing would be then plated with steel, I think braced and mounted properly it should be plenty strong. Don't need the nose dragging on the ground lol.
  5. Nov 16, 2018 at 5:51 AM
    BarnBoy
    96 Tacoma 2wd
    Do the end caps usually come with a nut welded in from the factory or do you have to custom make that? Haven't looked yet.
  6. Nov 16, 2018 at 2:15 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Most often you make them yourself or the last owner did
