Custom Fuse cover- Extended Height
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 11, 2017.
  1. Nov 11, 2017 at 4:55 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Up for sale is a specialty fuse cover I designed and made. This solves the issue when you add any accessory power taps off the fuse box and the original cover not fitting, leaving the fuse box exposed.
    It will clear all "add-a-tap" fuse holders. There are 3 knockout channels per side, so you can choose where you want your wire exiting. Color coded Fuse label, and much stronger than the stock plastic one. Stealth and a must have for a clean look:D
    Designed and made in the USA :oldglory:
    Fits all 2016+ Tacomas
    $20 + S&H
    So you don't have to do this!(thanks @ACinOR for picture ;) )
    Height compared to stock
    You can see how high the Add-a-fuse sticks out
  2. Nov 11, 2017 at 4:56 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Fits 2017 off road 4x4?
  3. Nov 11, 2017 at 5:00 PM
    MESO
    State of Jefferson
    Yes. All 2016-up Tacos. Updated first post:)
  4. Nov 11, 2017 at 5:24 PM
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    That's pretty cool. :thumbsup:
    Lucifer1 and MESO[OP] like this.
  5. Nov 11, 2017 at 6:23 PM
    Mattchew
    Mattchew Well-Known Member
    Coquitlam, BC, Canada
    2017 tacoma TRD sport
    Toytec boss lift Ultralight racing adjustable UPC K&N cold air intake Magnaflow Catback exhaust All LED lights Oemassive headlights with HID LED pods in rigid fog light mounts 50" curved windshield LED Caliraised side shooter ditch mount LED Behind grill 30" LED SSO slimline bumper with LED bar and smittybilt x20 synthetic winch TED PRO taillights with diode dynamics brake as turn controller LED bed lights LED running board lights LED under hood light Line-x trifold hard tonneau cover Switchpros system Yaesu vhf radio
    @mesojdm is there more than one or miss out
    Lucifer1 likes this.
  6. Nov 11, 2017 at 6:26 PM
    MESO
    State of Jefferson
    If there is a PayPal purchase button, you are good to go.
    Lucifer1 and solscooter like this.
  7. Nov 11, 2017 at 6:28 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    DUDE. I swear man I was about to go get a copy of the panel laminated and stick it under there with a little velcro dot.
    This is gonna help when I go to install my switch-pros.
    Chipskip, Lucifer1 and MESO[OP] like this.
  8. Nov 11, 2017 at 6:32 PM
    MESO
    State of Jefferson
    You lost me at Velcro and photocopy :cookiemonster:
    This is a much better solution :thumbsup:
  9. Nov 11, 2017 at 6:34 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    You know me though, I'm enough of a compulsive nerd that I rummaged around in TIS and found the PDF of the label, but yeah this is a much better solution.:D
  10. Nov 11, 2017 at 8:00 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Purchased.
    Thanks for another awesome solution.
  11. Nov 11, 2017 at 8:05 PM
    Friedtacolover
    Travis
    Ontario, Ca
    Awe mannn i wanted the only one :angrygirl:
  12. Nov 11, 2017 at 8:08 PM
    solscooter
    Brian
    Minnesota
    I think he's making these.... More than one im sure.
    I'll be installing my switch-pros next week. This is exactly what I needed.
    @mesojdm when do you plan on making your own dual battery set up for purchase. I'm there if it happens
  13. Nov 11, 2017 at 8:21 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    But where's that mesojdm LED work? J/k
    Cool product
    Lucifer1, MESO[OP] and solscooter like this.
  14. Nov 11, 2017 at 8:24 PM
    solscooter
    Brian
    Minnesota
    If it lit up it would be that much more awesome
  15. Nov 11, 2017 at 8:25 PM
    krytikel
    krytikel Well-Known Member
    California
    2017 Tacoma TRD Inferno sport 4X4
    OME lift
    Just like that...PayPal sent:bananadance:!
  16. Nov 11, 2017 at 8:26 PM
    MESO
    State of Jefferson
    Do most guys tap the fuse box for switch-pro install?
    And I am actually working on a dual battery kit for my truck.. but idk if I'll make it into a kit. We'll see.
  17. Nov 11, 2017 at 8:29 PM
    solscooter
    Brian
    Minnesota
  18. Nov 11, 2017 at 8:42 PM
    MESO
    State of Jefferson
    Gotcha. Well for ACC power, I like to tap off the P.OUTLET1(cig lighter) which has a high rated 15a and is switched power. My fuse box cover notch happens to line up perfect if you tap that circuit. You can also go even more custom and make your own holes in the side of the fuse cover If need be.
  19. Nov 11, 2017 at 8:46 PM
    solscooter
    Brian
    Minnesota
    I have a 3rd tap I was thinking of using the cig lighter for. Too many taps
  20. Nov 11, 2017 at 11:45 PM
    Acivichb
    Acivichb Well-Known Member
    Jordan
    Maui hawaii
    Suzuki Sammy. 3rd Gen tacoma
    Just ordered one...
