Custom Headache Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2680, Oct 3, 2013.
  1. Oct 3, 2013 at 4:32 PM
    2680 [OP] Member
    Cincinnati, Ohio
    2013 Tacoma Double Cab Ext Bed
    I just got done building a headache rack for my truck. This website has been extremely helpful in the design and fabrication process. This is my first project with welding and was a good learning experience. Just wanted to share my project to hopefully help others with their plans.
    I needed the rack to protect the rear windows, hold ladders above the cab, and still be able to slide long material through the back window when needed. I think this will work out great.... I will report in after a few weeks on the job!
    JD Hog likes this.
  2. Oct 3, 2013 at 4:36 PM
    BUB_IROC_Z
    BUB_IROC_Z Well-Known Member
    Anthony
    North Eastern Ohio
    2010 4x4 4.0 Taco
    3 inch OME, Rear diff breather mod, Aeroforce Interceptor Gauge and custom gauge pod, Yellow Wire Mod, Avid Off-road bar, Bud built Skid Plates,
    Looks good
  3. Oct 3, 2013 at 5:49 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    x2 :)
  4. Oct 3, 2013 at 6:08 PM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    looks real good, and aside from that part where you said you could slide materials above the roof, i would have said its tall enough where you could put a 30" led bar in the middle, and maybe a square pointed back for bed lights on each side.
    good lookin headache rack though bud
  5. Oct 3, 2013 at 6:55 PM
    2680 [OP] Member
    Cincinnati, Ohio
  6. Oct 3, 2013 at 8:39 PM
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Do you have any photos of how you have it attached to the bed? I'm currently brain storming ideas for a future project.
    Nate
  7. Oct 3, 2013 at 8:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job OP , but why are you hauling long material through the back window and not on the headache rack ? I've hauled 20's on mine
  8. Oct 3, 2013 at 9:12 PM
    2680 [OP] Member
    Cincinnati, Ohio
    I get alot if sheet vinyl in 12ft rolls.... slide it in the window and only sticks out of the bed a few feet... pretty heavy and akward stuff.
    I'll get pics of how i attached it tomorrow.....
  9. Oct 3, 2013 at 9:13 PM
    OZ-T
    Peter North
    British Columbia
    Oh , that makes sense , I thought you were referring to lumber
  10. Oct 4, 2013 at 4:20 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  11. Oct 4, 2013 at 1:54 PM
    2680 [OP] Member
    Cincinnati, Ohio
    ok, so it is mounted with two different setups. for the front rail, i used 1/2" hex bolts, grade 8, 1.5" long. you can slip the bolt head into the rail, but you need to remove the bolt holding the rail on so the hex bolt can slide past, then reinstall the rail bolt.
    then for the side on the angle iron, i used 3/8" grade 8 bolts and screwed them into unistrut nuts. the nuts work great but are too tall. after taking off about 1/8" on the bench grinder they slip in real nice..... ;)
    and here she is with a ladder.... i had to use my temporary roof rack thing cause the bed liner coating hasn't fully cured yet, but it looks like it will work real well! i like rear ladder racks if it's a full time deal, but i only move ladders a couple times a month, so i'd rather have the headroom for loading and unloading the bed....
  12. Oct 4, 2013 at 2:30 PM
    OZ-T
    Peter North
    British Columbia
    Why not just go from the top of the tailgate and up over the headache rack ?
  13. Oct 4, 2013 at 3:00 PM
    2680 [OP] Member
    Cincinnati, Ohio
    not sure, never thought of it. wouldn't it stick way up in the air? just figured level was better.
  14. Oct 4, 2013 at 3:16 PM
    09DC4X4
    09DC4X4 Night In The Ruts!
    Brian
    Southern Maryland
    09 Double Cab 4X4 V6 Auto
    Too much, thanks TW.
    Nice job man. i like having mine on. Can always take it off when you don't need it. I like the cab protection and extra hold down points for straps and stuff. Good job.
  15. Oct 4, 2013 at 3:21 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Nice!!! I have been thinking some thing like that!!!
  16. Oct 4, 2013 at 4:53 PM
    OZ-T
    Peter North
    British Columbia
    That's how I used to haul long lumber , sure it sticks up above the cab but it doesn't matter unless you are trying to get into a parking garage , if you had long lumber in the same way you have your ladder , you could get a whip effect onto the roof , been there , done that ( on my last truck )
    This timber is approx 14' IIRC to get the idea
  17. Oct 4, 2013 at 5:23 PM
    2680
    2680 [OP] Member
    Cincinnati, Ohio
    damn dude, that's one hell of a house!!! what kind of tires are those? they look really nice!
  18. Oct 4, 2013 at 5:27 PM
    OZ-T
    Peter North
    British Columbia
    Yeah that was a big house I built for a client , those tires are 265/70/17 Hankook Dynapro MT's and that's before I lifted my truck
  19. Oct 4, 2013 at 7:31 PM
    2680
    2680 [OP] Member
    Cincinnati, Ohio
    sweet, thanks! i'll have to put them on my short list when it's time for new tires!
  20. Dec 17, 2014 at 12:18 PM
    Chrisco1997
    Chrisco1997 New Member
    05 Tacoma SR5
    What are the dimensions of that rack?
