Custom Intakes for 4 cylinder engines
Discussion in '4 Cylinder' started by 08pretaco, Apr 21, 2011.
  1. Apr 21, 2011 at 1:28 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Anyone made a custom intake for their 2.7L? I was looking and I came across Airraid composite intake tubing:
    http://www.autopartsdealer.com/aira...ium=cse&utm_campaign=u75&utm_content=featured
    It comes with a lot of bends and a pretty decent amount of tubing to work with. I was going to possibly try doing something over the summer, trying to come up with some idea's to work with. Maybe some sort of cold air draw from outside the engine bay incorporated with a ram air of some sort.
    Show me what you got going on!
  2. Apr 21, 2011 at 1:38 PM
    08pretaco
    Oliver
    az
    Well I plan on using the factory air box instead of dealing with the issue of connecting the MAF to the new intake tube.
    I want to route something to the front of the truck, behind the grill or someplace in front that might be able to create a decent pressure while driving at speed while being located outside the engine bay.
    Its more because I want something to do this summer and see if there is anything I can do that will benefit the engine
  3. Apr 21, 2011 at 8:42 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    If you have a second gen and are not using your fog light holes, you could use one of those holes to route your cold air intake tube to.
    Either way you won't see a HP gain, unless you're going 140+ MPH at the North Pole.
  4. Apr 21, 2011 at 9:01 PM
    08pretaco
    Oliver
    az
    I was going to do the fog light hole as its a huge pressure zone but I am no longer running the stock front bumper.
