Custom Kicks...
Discussion in 'Audio & Video' started by TurboGT, Sep 30, 2010.
  1. Sep 30, 2010 at 7:05 PM
    TurboGT
    TurboGT [OP] Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    I pick up my new (used) Taco Saturday morning, and first thing planned is setting out on a set of custom kicks for a set of Diamond Audio S500s Hex's...
    But the truck is an AT, and I can't stand the ebrake pedal where it is...
    Anyone know if the ebrake can be moved to where it would be in a MT Taco?
  2. Sep 30, 2010 at 7:40 PM
    supersuk
    supersuk Well-Known Member
    Honolulu, HI
    2010 Dcab TRD Sport Magnetic Gray
    Sounds!
    If I were you, i'd stay away from the kicks. I just made some and the sound stage is pretty low even with the tweeters mounted high up on the pillars. It does sound nice, just wish the stage was higher. Right now its at chest height.
    Should you choose to put the speakers in the kicks, then it can be done with the ebrake in place. Check out my build.
    Just to warn you, the wires in the kick panel area will get in the way. You will have to either move them or push them further into the kick panel area. This is from my experience.
  3. Sep 30, 2010 at 7:44 PM
    supersuk
    Honolulu, HI
    Sounds!
    Also, I don't see why your suggestion can't be done. I would think you just have to get the gear from the MT trucks and install it into the AT truck. The only thing you'd lose is the storage compartment. When I was doing my stereo install I tore apart my truck and I noticed that there was less room under the center console for the AT due to the large shifter assembly. However, there seems to be enough room for the cable...must be since there already is a cable there. hahaha
  4. Oct 2, 2010 at 9:23 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Your tweeter should actually be within a few inches of your midwoofer for best sound.
    On the op's question. Your e-brake is just a cable so I think you should be able to move it fairly easily once you have the parts. If you don't want to build kicks, q logic sells them for a pretty decent price and you can keep your e-brake where it is
  5. Oct 4, 2010 at 9:19 AM
    rscecil007
    rscecil007 Well-Known Member
    Seattle
    06 4x4 TRD Sport Access Cab
    Goodyear Duratracs 265/70R17's, Bed mat & extra d-rings, Weathertech floor liners, Husky Liner for rear seat area, Biceman Illuminated 4x4 Switch, Pioneer 800 PRS, Hybrid Audio L6 and L1V2, JL 13TW5 in a Mr. Marv box, JL HD900/5
    Not turning out that well? Where did you cross them over at?
  6. Oct 6, 2010 at 2:16 PM
    supersuk
    Honolulu, HI
    Sounds!
    It actually sounds really nice so far. I still haven't made the a-pillars yet, but had the XT25's mounted on the pillars for a little while to see how they sound on & off axis. I like them on axis. Right now I have them crossed pretty high, around 5k.
  7. Oct 11, 2010 at 6:52 AM
    rscecil007
    Seattle
    I don't think that's 100% true all the time however. If you get a mid that can play a wide enough band of freqs to be a point source speaker, you should have no problem putting the mids in the kicks and the tweets up high in the pillars. There are ALOT of guys on the Hybrid Audio forums running their systems this way, or very similar. Where the mid in the kicks sees ~200hz anywhere up to 8khz, 10khz, or even more.
    Hybrid Audio L4's can cover an insane range, and some guys running them in the kicks on-axis don't even run tweeters. IIRC the L4's can play up to 14khz on-axis.
    But if the mid can't play that large a range, then having the tweets right there next to them is def a good idea. Otherwise you are getting vocal cues from 2 different locations.
