Custom LED Map and Dome lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 28, 2017.
  1. Mar 13, 2018 at 11:08 AM
    #2041
    Vortaku
    Vortaku Well-Known Member
    Ross
    Got mine in, pull the roof console off for map lights?
  2. Mar 13, 2018 at 11:17 AM
    #2042
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I think if you go a page or two back there is a video and discussion on this.
  3. Mar 13, 2018 at 12:28 PM
    #2043
    maverick42
    maverick42 Well-Known Member
    2018 red TRD Off Road
    I didnt need to do that. I took a very small flathead screw driver, got between the light and the console on the inside section of the light and applied a small amount of outward pressure and the cover popped off with out any issue.
  4. Mar 13, 2018 at 12:54 PM
    #2044
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I didn't forget about you 2nd GEN guys!
    It's a little more complex than ours
    Jerez, 1bad2k, H3ATH3N2016 and 3 others like this.
  5. Mar 13, 2018 at 3:24 PM
    #2045
    Bridge4
    MA
    Just installed my ultimate red maps. I like it, but I'm not sure, never had red lights inside. Going to order a set of the smoked v1's when they come back and then I will put whichever ones I don't want back in the pool here for cost.
    RobP62 likes this.
  6. Mar 13, 2018 at 4:17 PM
    #2046
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    I'll send you my V1's... if you like them send me the Reds... if you don't... send back the V1's. cool?
    RobP62 likes this.
  7. Mar 13, 2018 at 4:30 PM
    #2047
    Vortaku
    Ross
    Broke a tab on my dome light assembly trying to get it off the roof, crap
  8. Mar 13, 2018 at 6:44 PM
    #2048
    MESO
    State of Jefferson
    Tab on the Ultimate dome, or the stock housing?
    RobP62 likes this.
  9. Mar 14, 2018 at 5:44 AM
    #2049
    farley34
    farley34 Member
    Brad
    Ambler
    2018 Silver DCLB TRD OFF-ROAD
    installed dome yesterday...........holy hell its bright! Nice work!
    RobP62 and 12taco like this.
  10. Mar 14, 2018 at 6:30 AM
    #2050
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Pics or it didn't happen. :D JK.
  11. Mar 14, 2018 at 6:47 AM
    #2051
    fredfarmer
    fredfarmer Well-Known Member
    DFW
    2016 TRD Off Road AC
    I was unable to pull out the stock bulbs when trying to install my map lights last night. Now the dome and map lights are not working. I think it's a fuse after searching this thread so I will try that next.
    Any tips on getting the map lightbulbs out?
  12. Mar 14, 2018 at 6:55 AM
    #2052
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Pull the whole panel out and get them from the back side. Also, make sure the switch is set to OFF so you don’t blow another fuse. Or even better, pull the fuse, replace the bulbs, THEN replace the fuse
    Post 1991 of this thread
  13. Mar 14, 2018 at 8:29 AM
    #2053
    pepto90
    pepto90 Well-Known Member
    Preston
    2017 White Tacoma TRD OR 4x4 AT DCLB
    Window tint (30/5 front/rear), mud guard delete, hood lift system, and debadged.
    Would it be possible to get map/dome lights that can be switched from white to red(a dimmer red to save night vision) for night ops?
    WulfmanX, Bravisimo and RobP62 like this.
  14. Mar 14, 2018 at 8:33 AM
    #2054
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Version 1 Reds are not as bright as Version 2 aka Ultimate Maps.
  15. Mar 14, 2018 at 8:35 AM
    #2055
    pepto90
    Preston
    I do not want constant red though. I want to be able to alternate between white and red depending on what I am doing.
    Bravisimo and RobP62[QUOTED] like this.
  16. Mar 14, 2018 at 8:37 AM
    #2056
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Not a thing, unless you buy one of each color.
  17. Mar 14, 2018 at 8:38 AM
    #2057
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    my ultimate reds are en route now. once they get here I'll have some ultimate whites for sale if you're still interested.
    ElTacomaJoel[QUOTED] and RobP62 like this.
  18. Mar 14, 2018 at 8:39 AM
    #2058
    pepto90
    Preston
    Which is why I am asking @mesojdm if it would be possible to make this product.
    RobP62[QUOTED] likes this.
  19. Mar 14, 2018 at 8:41 AM
    #2059
    H3ATH3N2016
    H3ATH3N2016 Soul Stealer
    Bren
    Jones County, Ga
    2016 DCSB TRD SPORT 4x4
    9"+/- Lift, 20" Dropstars, 35x13.50x20 Toyo Open Country M/T, Predator Tube Rails, Ultimate LED signal lights, Much Much More
  20. Mar 14, 2018 at 8:55 AM
    #2060
    Vortaku
    Ross
    stock housing
