Custom LED Map and Dome lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 28, 2017.
  1. Oct 18, 2019 at 9:01 PM
    #6081
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    By fake dome light, do you mean the festoon adapter?
    Dark505 likes this.
  2. Oct 19, 2019 at 12:43 AM
    #6082
    Tmaloy
    Troy
    2019 SR DC LB
    The lady wants me to mount my extra SMDs in her car, I just need to figure out if it is plug and play and if I can hide them under the factory diffusers. Once she sat in the truck she freaked when she saw how bright the interior was.
  3. Oct 20, 2019 at 6:28 AM
    #6083
    acarp520
    acarp520 Well-Known Member
    Andrew
    2017 Tacoma TRD OR
    Yes, the festoon adapter was too large. I just removed the spring and then it fit perfectly.
  4. Oct 20, 2019 at 6:34 AM
    #6084
    acarp520
    Andrew
    2017 Tacoma TRD OR
    Did you ever get this resolved? Mine is doing the same thing now.
  5. Oct 20, 2019 at 7:04 AM
    #6085
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Check if the push button accidentally got pushed maybe it got clicked and needs to be unclicked?
  6. Oct 20, 2019 at 8:53 AM
    #6086
    acarp520
    Andrew
    2017 Tacoma TRD OR
    What push button?
  7. Oct 20, 2019 at 8:59 AM
    #6087
    Tmaloy
    Troy
    2019 SR DC LB
    Go back to post #6091 and there is a Youtube video that has some troubleshooting tips for the lights.
  8. Oct 20, 2019 at 1:29 PM
    #6088
    acarp520
    Andrew
    2017 Tacoma TRD OR
    Went back and read through a few other forums. Apparently this is a very common issue, not just with MESO interior lights, but other aftermarket LED's. When your interior light 7.5A fuse blows, it doesn't fully protect the circuit (as it is a slow blowing fuse). Doesn't sound like there is a clear smoking gun solution for this, but some have had to replace the body ECU ~$650.
    Really wish I would have read up on this before purchasing!
    https://www.tacomaworld.com/threads/dome-lights-wont-turn-off.402358/
  9. Oct 22, 2019 at 11:19 AM
    #6089
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    Just patiently waiting on that v2 dome and map:bored:
  10. Nov 15, 2019 at 6:41 AM
    #6090
    txranger83
    txranger83 Well-Known Member
    Colby
    Republic of Texas
    2020 Tacoma TRD Off Road
    Are the Map lights that are for sale right now, V1 or V2?
  11. Nov 15, 2019 at 6:45 AM
    #6091
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    V1
  12. Nov 15, 2019 at 6:58 AM
    #6092
    Tacospike
    Two Trucks
    idk. The first ones Meso had were domes
    they are still on the first page
  13. Nov 18, 2019 at 8:37 PM
    #6093
    BradsTaco
    BradsTaco Well-Known Member
    Texas/Montana/Florida
    2014 TRD 4x4 DCLB
    Anyone know what years the 2nd gen dome lights will fit? 2012-2015??
  14. Nov 18, 2019 at 9:09 PM
    #6094
    J_Anthony_
    Naomi, Lana
    They aren’t even in stock I thought.
    Everyone’s waiting on some new ones.
  15. Nov 30, 2019 at 6:01 AM
    #6095
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    @MESO Will the Dome and Map light listed under 3rd gen Tacoma also work on 5th gen 4Runner?
    Ordered a set for the Tacoma and would like to get it for the 4R.
  16. Nov 30, 2019 at 7:10 AM
    #6096
    xconaty
    xconaty Well-Known Member
    Ash
    Pinehurst, NC
    2017 Silver Taco TRD Off Road
    TRD Pro Fox Suspension TRD Pro Skid Plate Katzkin Leather Interior 17" TRD Pro Wheels BFG KO2 Tires
    Treated myself to this setup! Pretty stoked to do the install.
  17. Dec 4, 2019 at 6:23 PM
    #6097
    J_Anthony_
    Naomi, Lana
    Got my new setup !
    went to install... saw the red light for the map lights working however.... it wasn’t turning off, so I pushed the little button in the corner of the housing... then it turned off... tried to re wire it again,, because I thought I had done something wrong. and then noticed my rear dome light was not working either.
    Now both front and rear will not come on...
    Blown fuse ?
    @MESO
  18. Dec 4, 2019 at 6:39 PM
    #6098
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    That’s the first thing I’d check. Look under the dash for DOME(7.5 IIRC)
    So the maps worked but then you went to install the dome and then all didn’t turn on?
    Inferno__Taco likes this.
  19. Dec 4, 2019 at 6:50 PM
    #6099
    J_Anthony_
    Naomi, Lana
    I had installed one MESO map light, and it worked. However it would not turn off. So from the YouTube video I saw, there’s a little black button inside the housing of the light, you push this button and it fixes the “map lights being constantly on” problem.
    After I hit this button the new light turned off.
    .. I fiddled around with the new map light wondering why I couldn’t get it back on again ... I then turned around and noticed my original stock dome light was not working now.
    @MESO
  20. Dec 4, 2019 at 7:02 PM
    #6100
    MESO
    State of Jefferson
    Yeah the little button inside the map home is the stock “push on/off” button. Sometimes it can get pushed when changing out the maps, not a big deal. But with nothing turning on I’d look under the dash at the DOME fuse. Did you disconnect the battery Before plugging in? Also of fuse is good, unplug the dome at the black connector and flip around- test again.
