Custom LED Map and Dome lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 28, 2017.
  1. Sep 25, 2020 at 1:07 PM
    #6681
    Tacospike
    Two Trucks
    It's power on/off comes from the truck switch itself. I see what you're saying, but without some internal truck modification it won't work that way. The light is on the back end of the supply, you would have to jump it to do that. If that makes sense? I'm trying to word it right but not coming out that way..
    The dome works just as the dome does now just switches colors or brightness.
  2. Sep 25, 2020 at 1:11 PM
    #6682
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Oh I am well aware of what would need to be done. Thats why I said "any chance you would make another version that has a button on a different power wire". Thus suggesting that I would run a additional power wire that would run the red led.
    Tacospike[QUOTED] likes this.
  3. Sep 25, 2020 at 1:12 PM
    #6683
    Tacospike
    Two Trucks
    Gotcha ;)
  4. Sep 25, 2020 at 1:12 PM
    #6684
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    So, you want the Red light to default to White after use? You can have it your way if you leave it switched to White every time. :notsure: And, vice-versa
  5. Sep 25, 2020 at 1:13 PM
    #6685
    5nahalf
    Erik
    Minnesota
    I think it would be a nice feature, but that just because when I have dome, and both maps lights, but 1 map is set to red, 1 is set to white, and the dome is set to what ever my kids pushed on it. Then I turn on all the lights hoping for white, but get a techno rave instead.
  6. Sep 25, 2020 at 1:18 PM
    #6686
    5nahalf
    Erik
    Minnesota
    No no, I want white, white only and you turn on the overhead switch or open the doors. Then if you push just the button on the dome, it turns on red. As it sits now, I would turn on the lights via opening the door, then If the lights turned on red, but I wanted white, I have to push the dome light switch to change it to white.
    The switch on the dome light I think should be independent of the white light. There would be a keyed on power wire run into the headliner (you install that) that wire is connected to the switch in the dome, and only controls the red. The white light is controlled by either the door open, or the "all lights on" button in the overhead console.
  7. Sep 25, 2020 at 1:25 PM
    #6687
    RyanDCLB
    4/19 DCLBOR
    Got it. What about this idea, when @MESO releases the overhead panel with the hex pattern, you buy red "hex" lights that pop-in, and have them on a separate switch? :devil:
    5nahalf[QUOTED] and Tacospike like this.
  8. Sep 25, 2020 at 1:27 PM
    #6688
    RoostrC0gburn
    RoostrC0gburn Well-Known Member
    Oregon
    2017 Super White DCLB TRD Sport 4x4
    you're gonna need a relay for that...
  9. Sep 25, 2020 at 1:27 PM
    #6689
    Tacospike
    Two Trucks
    BOOM!! That's it!
    On my list of things I've been waiting on. That HEX 9
    RyanDCLB[QUOTED] likes this.
  10. Sep 25, 2020 at 1:27 PM
    #6690
    5nahalf
    Erik
    Minnesota
    But I already have a overhead panel :)
  11. Sep 25, 2020 at 1:29 PM
    #6691
    5nahalf
    Erik
    Minnesota
    A relay for the dome light? No, I dont think so. The dome light doesnt pull nearly enough power to need a relay... its a dome light, not a 300 watt light bar.
  12. Sep 25, 2020 at 1:33 PM
    #6692
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I hear what you guys are saying.
    As of right now, the dome light uses a mechanical relay(made in Japan:)) which will toggle between the 2 colors. The relay will stay latched to its last set position. Regardless if it has power coming into it or not.
    In order to “default” back to white upon turning the truck off(cutting power) I would need to come up with a way for the relay to revert back to the “white” position. Haven’t really thought about it, but I’ll look into it. I just don’t want to create an issue for everyone else that wants it to stay in the last mode they set it to.
    ryanbitt, BOMBS, skyking3 and 2 others like this.
  13. Sep 25, 2020 at 1:39 PM
    #6693
    5nahalf
    Erik
    Minnesota
    @MESO im not talking about default back to white with what I said, How others got that idea when I didnt even say it is beyond me.
    Here is what I am saying
    You have your dome light, just like your old one. It turns on and off in white, just like it always has.
    Now, you add the red leds to the center like your new one, but they are not connected in anyway to the white ones. The red lights have a dedicated power wire run from the dash to the headliner. Now, you plug that dedicated power wire to the switch, and the switch controls the red and only the red.
    I open my doors, its white, I push the "all on" button in the overhead center console, its white.
    If I push the button (your button) on the dome light itself, regardless of the status of the white lights, the lights turn on red.
    2 lights, 2 separate circuits, 2 separate buttons to turn each of the 2 different lights on. Neither the red or white will ever have any impact on turning on or off the other color.
    Whites on? push the button on the dome light, white stays on, but red turns on also(I cant see any situation where you having the white lights on you would need to turn on the red also). Whites off? push the button on the dome light and red turns on. The button on the dome light controls turning red on and off only, it doesnt do anything involving white.
    Usually you would use white to see everything, and you would use red for better night time vision. It just makes sense especially if you have maps lights and dome lights that can all change from red to white, that turning all lights on would do all white, but when turning on just a single light should make it red.
  14. Sep 25, 2020 at 1:51 PM
    #6694
    RyanDCLB
    4/19 DCLBOR
    That was my bad. Sorry! You clearly said you'd like a separate switch, and I can definitely see how that could come in handy. :thumbsup:
    5nahalf[QUOTED] likes this.
  15. Sep 25, 2020 at 2:08 PM
    #6695
    Tacospike
    Two Trucks
    :tumbleweed:
    How about some more pics of those DOMES!
    Big Gulps huh?
    Rock Lobster likes this.
  16. Sep 25, 2020 at 2:19 PM
    #6696
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  17. Sep 25, 2020 at 2:21 PM
    #6697
    Tacospike
    Two Trucks
    Hang in there, I’m on the same boat
    Rock Lobster[QUOTED] likes this.
  18. Sep 25, 2020 at 4:41 PM
    #6698
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Monday for me :D
  19. Sep 25, 2020 at 5:57 PM
    #6699
    White2018g
    White2018g Well-Known Member
    White 18 sport
    Stock
    Tuesday for me to!!
  20. Sep 25, 2020 at 10:24 PM
    #6700
    waltuo
    waltuo Well-Known Member
    Toyotas
    Lucky, mine says Wednesday.
