Custom LED Map and Dome lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 28, 2017.
  1. Sep 23, 2021 at 4:27 PM
    #7421
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Mine is doing the same thing. Driver side one press changes color. Passenger side is a two press every now and again to change color.
    At first install passenger side was staying on red , flipped the plug around and swapped it to the drivers side and it was the same thing.
    Said the hell with it and just installed it and would deal with it later. Popped everything back up and then it started flipping from red to white :notsure:
    Both work , and change colors. So I can deal with the two presses from time to time.
    :101010:
    Tacospike and jaymz25 like this.
  2. Sep 23, 2021 at 4:36 PM
    #7422
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I get yelled at all the time for my code needing two clicks when the client only wants one. I am not about to complain about it myself.
    Oddly I think dual brightness might be my pick for maps. Low (2 LED’s) for normal use and high if needed. But max bright up front just doesn’t seem important once you have the dome. I’d probably go for full rgb color choice with everything on low brightness as the ultimate. Maybe random order even.
    I honestly may revert to stock with chintzy led bulbs. I think I liked that the best overall. This is one spot where the lens makes sense as a diffuser.
    my wife laughed at me last night when I took her out for fancy dinner. I guess she knows I’m still 12 years old.
    I love the dome though, it’s perfect.
  3. Sep 23, 2021 at 4:41 PM
    #7423
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Sneaky bug in the system. I gotcha. The main time I need to switch to white from my default of red is when I check my Taco Bell orders in the drive-thru so I'll survive :anonymous:.
    daveeasa likes this.
  4. Sep 23, 2021 at 4:44 PM
    #7424
    Frsh2df
    I just figured out what was going on with my passenger side.
    When they come on the drivers switches back and forth as it should.
    When I go to switch the passenger side , it switches to red and stays red. I have to actually press the light to the “ on “ position then the dual color will work.
    Not sure if you have seen this issue yet , but wanted to give you a heads up Meso
  5. Sep 23, 2021 at 6:43 PM
    #7425
    jaymz25
    jaymz25 Well-Known Member
    Edward
    2020 Midnight Black Metallic Tacoma TRD Pro
    mines does this too. wonder why? well my dome light had the same issue but Meso told me to turn in a ticket for it. got replaced and never have the same problem. i think it's more of a bad switch
    Frsh2df[QUOTED] likes this.
  6. Sep 23, 2021 at 7:02 PM
    #7426
    Frsh2df
    Yeah it’s definitely a weird issue. I submitted a ticket on his site.
    Took me a minute playing with it to find out that I had to press the light to get the dual function out of the passenger side.
  7. Sep 24, 2021 at 6:03 AM
    #7427
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Yes, mine does that also. just part of the awesomeness of the duals!:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
    tonered likes this.
  8. Sep 24, 2021 at 12:35 PM
    #7428
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I finally got to drive the Taco today. Even though the weather is epic, I couldn't wait any longer. The lighting was absolutely killer and perfect. Thanks a ton!
    :hattip:
    BTW on the double pump, the DC dome did it yesterday, but not the maps. :rofl::rofl: I think it is just a feature.
    12? Geez. I've matured a lot in the last year or so. I'm just about up to 5.
    daveeasa[QUOTED] and Tacospike like this.
  9. Sep 24, 2021 at 2:22 PM
    #7429
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    Same happening with my dual color maps, I have to double tap to change color, unless I switch right back after changing color. Not a big deal, just wanted to pass on the info for the purpose of R&D. Very happy with @MESO products. ✌
    MESO[QUOTED][OP] likes this.
  10. Sep 25, 2021 at 3:37 PM
    #7430
    06toyoboy
    06toyoboy Well-Known Member
    I cant seem to switch between colors when the truck is completely off. Is this a recurring problem i knew there was an issue on others before
  11. Sep 25, 2021 at 3:38 PM
    #7431
    Frsh2df
    Try pressing the actual map light on , then press the dual color button.
    That’s similar to what happened to my passenger side light.
    Tacospike likes this.
  12. Sep 25, 2021 at 3:43 PM
    #7432
    06toyoboy
    Sorry i did not clarify. This is for my dome light i am still trying to install my map lights
    BOMBS and Frsh2df[QUOTED] like this.
  13. Sep 25, 2021 at 4:04 PM
    #7433
    06toyoboy
    What is the easiest way to remove the map lights
  14. Sep 25, 2021 at 4:07 PM
    #7434
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Send me a PM with order number. Had some domes that had voltage tolerance where they were finicky under ~11.5V. Which is why it works when truck is running(12+Volts). But when off it’s less voltage. I have one that will work for you!
    tonered, mtip and BOMBS like this.
  15. Sep 25, 2021 at 4:07 PM
    #7435
    Tacospike
    Two Trucks
    I just pop the lenses off. I use a tiny eye glasses flat head
  16. Sep 25, 2021 at 4:10 PM
    #7436
    06toyoboy
    What did you use to remove the original light bulb in the map lights?
  17. Sep 25, 2021 at 4:14 PM
    #7437
    Tacospike
    Two Trucks
    My headphones wires lol. It was small and gripped. I looped it around the bulb and pulled it out. This was over 5 years ago
    I would suggest pulling the whole console off to get the bulb. Way easier.
    BOMBS and Frsh2df like this.
  18. Sep 25, 2021 at 4:32 PM
    #7438
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Go to about 38 seconds into this video to learn how to pull down the overhead console:
    All: for those who reconnect the battery, but no maps or dome lights, make sure to open/shut the door. The lights will timeout after disconnecting the battery, and the only way to get them active again is to open/shut the door. That, and make sure the switches are on of course! (Including the push switch on the actual map lights).
    MAD777, BOMBS and Tacospike like this.
  19. Sep 25, 2021 at 4:36 PM
    #7439
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Just a little tape to grip the bulb
  20. Sep 25, 2021 at 4:43 PM
    #7440
    06toyoboy
    Already got the map lights on. Thanks for the help. Just have to fix the dome one now
