Custom LED Map and Dome lights
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Nov 28, 2017.
  1. Dec 5, 2017 at 1:41 PM
    #81
    trd_kevin
    trd_kevin Well-Known Member
    Kevin
    2017 White Tacoma TRD 4x4
    Too much
    I upgraded mine but different brand, definitely worth it
  2. Dec 5, 2017 at 7:03 PM
    #82
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Okay.. Here are some output pictures. I made another batch, so I will update the first post with purchase buttons.
    I will keep the purchasing open, just keep in mind there may be a delay as I make them as ordered.
    THREE versions will be available
    -CLEAR
    -SMOKED
    -RED
    You can also MIX/MATCH colors if desired.
    White(left) Smoked(middle), red(right)
    SMOKED LENS:
    CLEAR LENS:
    RED:
    Here you can really tell the difference (clear left, smoked right)
  3. Dec 5, 2017 at 7:10 PM
    #83
    Jchmelo
    Jchmelo Well-Known Member
    Jon
    17 TRD OR DC
    Awesome thank you @mesojdm when I go to order the option is only for clear ones.
  4. Dec 5, 2017 at 7:12 PM
    #84
    MESO
    State of Jefferson
    standby workin on it
    Jchmelo[QUOTED] likes this.
  5. Dec 5, 2017 at 7:12 PM
    #85
    Jchmelo
    Jon
    17 TRD OR DC
    Ordered thank you!
  6. Dec 5, 2017 at 7:18 PM
    #86
    DrDaveTaco
    DrDaveTaco Well-Known Member
    Gaithersburg, MD
    2016 Black TRDORDC4x4
    Purchased. You’re the man.
  7. Dec 5, 2017 at 7:20 PM
    #87
    MESO
    State of Jefferson
    okay. Original post updated with links and new pics. Should be good to go
    Jchmelo likes this.
  8. Dec 5, 2017 at 7:24 PM
    #88
    RandyRiot
    RandyRiot Well-Known Member
    Randy
    Los Angeles, CA
    2016 Tacoma TRD Sport
    Ordered the smoked!, thanks a lot for answering our requests for more!
  9. Dec 5, 2017 at 7:28 PM
    #89
    BenSando
    BenSando Well-Known Member
    2017 Silver DCSB OR
    Ordered a smoked set!
  10. Dec 5, 2017 at 8:15 PM
    #90
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    Paid for a smoked set! Likely in for a matching dome light if you end up making one.
    Thanks again for the badass work!
  11. Dec 5, 2017 at 8:20 PM
    #91
    MESO
    State of Jefferson
    Oh... I've got something pretty trick for the dome. Should have a prototype in hand next day or 2
    RobP62, KTJO 4x4, RandyRiot and 5 others like this.
  12. Dec 5, 2017 at 8:24 PM
    #92
    Jchmelo
    Jon
    17 TRD OR DC
    Well go ahead and count me in for the dome
    RobP62 and KTJO 4x4 like this.
  13. Dec 6, 2017 at 3:19 AM
    #93
    DrDaveTaco
    Gaithersburg, MD
    Count me in
    RobP62 likes this.
  14. Dec 6, 2017 at 5:25 AM
    #94
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    Grabbing the smoked (and a dome when they're done). Ease of install on these? Any step by step needed?
    RobP62 likes this.
  15. Dec 6, 2017 at 6:22 AM
    #95
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    Sub'd for dome light...
    KTJO 4x4 likes this.
  16. Dec 6, 2017 at 7:04 AM
    #96
    Ro_Ja Boy
    Ro_Ja Boy Well-Known Member
    Pull down on the overhead panel at the corners near the lights. You feel like you're going to break something, but you won't. Then twist the sockets out and pull the bulbs out of the sockets. Set sockets aside. Get a pencil (I took a punch and put painters tape around the end) to push the plastic light out from inside. They will fall out. Feed the wires through the hole where the socket goes, plug into the socket, pop the new panel in and twist the socket back in. MESO said it's possible to have installed the connector from the new light backwards into the socket, so if it doesn't work, try turning the socket around and re-twist into place.
    RobP62 and dead.fm13[QUOTED] like this.
  17. Dec 6, 2017 at 7:18 AM
    #97
    MESO
    State of Jefferson
    ^ correct.
    You can do the swap without taking the overhead panel down, but it's easier if you do. Making more today!
    RobP62 likes this.
  18. Dec 6, 2017 at 7:19 AM
    #98
    Ro_Ja Boy
    I'm always the first to break something on my cars when I work on them, so if I can do it without breaking, you can. :D
    Now I pull the panel off just for fun. :p
  19. Dec 6, 2017 at 8:19 AM
    #99
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Watching!
  20. Dec 6, 2017 at 10:51 AM
    #100
    zuPROc_TRD
    zuPROc_TRD Well-Known Member
    SoCal
    2017 Tacoma TRD Pro named CeCe
    I'll wait for the map/dome light kit, hoping soon:fingerscrossed:
    As usual @mesojdm doin' great thangs for TW!! Keep up the great work brother!:cheers:
    Tacos4ever15 and MESO[OP] like this.
