Custom Maching
Discussion in 'Suspension' started by durf4694, May 10, 2011.
  1. May 10, 2011 at 6:17 PM
    durf4694
    durf4694 [OP] giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    I am going to be maching some 1.25 -1.5 lift blocks for my truck and was wondering if anyone could help me with an idea. to prevent any driving vibrations can i machine the top or bottom of the block on an angle to act as axle shims???? :confused:
  2. May 10, 2011 at 8:37 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    yep my 3.5" blocks has a taper on the bottom side.
  3. May 12, 2011 at 5:44 PM
    durf4694
    ny
    06 tacoma sport
    thanks for the help on this post as well as my other one guys lol shoulda put them together. Which way would the taper go on the bottom of the block? small end facing front of truck would by my guess........? since its a 1.5 block ill try 3 degrees? maybe
  4. May 12, 2011 at 5:45 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    machining :D
  5. May 12, 2011 at 5:48 PM
    durf4694
    ny
    06 tacoma sport
    o hell yes!
  6. May 12, 2011 at 5:49 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    id go with machining the top
  7. May 12, 2011 at 5:53 PM
    durf4694
    ny
    06 tacoma sport
    why not the bottom like he says his blocks are ? VVVVV
  8. May 12, 2011 at 6:20 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    i would think it wouldnt matter just so long they a faced the correct way .
  9. May 14, 2011 at 10:03 AM
    durf4694
    ny
    06 tacoma sport
    right right. so are the axle shims are usually placed on the top of the block? do you know what direction there supposed to go ? i did some searching and didnt get anywhere
  10. May 14, 2011 at 5:20 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    Ibelieve the thick end is the rear
