Custom MagnaFlow advice..??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scottyd, Nov 30, 2015.
  1. Nov 30, 2015 at 6:02 PM
    Scottyd
    Scottyd [OP] Former Raptor Owner.
    Scott
    2016 LB TRD Sport
    TOYTEC suspension Nitto Terra grappler Diamond stitch leather
    Im going to a custom muffler shop tomorrow morning. The manager said he is recommending a MagnaFlow muffler and custom install etc. He said it will be about $500.00. My goal is to get a little more throaty sound and gain some performance. Is this realistic with what he is suggesting. I really appreciate any advice. BTW, I had a Borla several years ago and it looked like good quality but it was a little to loud for my liking and I did not notice any performance gains or fuel economy increase. I did install a TRD drop in filter a few days ago for my 16 Tacoma. Again, any opinions or suggestions on what to ask or to do or not do would be appreciated. My "plan" was to do a side exit exhaust similar to the stock one. Thanks!
  2. Nov 30, 2015 at 6:09 PM
    Scottyd
    Scott
    2016 LB TRD Sport
    Yes, maybe I misunderstood? I know he said he would be increasing the tube size and bending everything to exact fit. Other then the price which I will clarify in the morning, can a MagnaFlow give a slight increase in throat sound and also "some" performance gains over stock or is it just pure sound these day and zero increase in performance. Thanks, I'm not a gear head and do not know the true answer...
  3. Nov 30, 2015 at 6:17 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    You may get 1 horse power from a new exhaust system on this truck?
    Scottyd[OP] likes this.
  4. Nov 30, 2015 at 6:17 PM
    DragNasty
    DragNasty Well-Known Member
    2016 Blazing Blue Pearl Limited V6 4X4
    I don't think you'll gain much from just a muffler.. With a new pipe and a cold air intake you would need to do a tune to get real performance gains...
  5. Nov 30, 2015 at 7:23 PM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    If I am not mistaken the couple of members that did exhaust mentioned a loss of mpg which make sense. Just as an fyi
  6. Nov 30, 2015 at 7:29 PM
    Scottyd
    Scott
    2016 LB TRD Sport
    Geez. I don't want that! Maybe I should wait until more research is done and more options are available. Thanks! Scott.
    Wonder why loss in mpg? Atkinson cycle engine??
  7. Nov 30, 2015 at 7:52 PM
    Scottyd
    Scott
    2016 LB TRD Sport
    Thanks. That makes sense. I guess what I'm really wonder is "if" a dyno test would show gains? The TRD Website says that there drop in filter is dyno tested for HP and torque gains. Wonder if a cat-back system would also show gains? Or with the high tech engine, would there be losses or zero performance gains and just better sound?
  8. Nov 30, 2015 at 8:09 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    they may get getting the low end torque they need with less fuel due to the back pressure
  9. Dec 1, 2015 at 12:23 AM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Lose of mpg is from lose of back pressure.
    If your looking for sound only yea it will help. But it's still a v6 your not going to get the deal deep sound like an 8.
    Scottyd[OP] and Wraith600 like this.
  10. Dec 1, 2015 at 3:29 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    We already have a good exhaust, you'd be better off just swapping out the muffler itself. I doubt you'll
    gain anything other than a different sound....but for most that's worth the change-out.
  11. Dec 1, 2015 at 6:00 AM
    Wraith600
    Loss of back pressure as GSXXR mentioned is the reason. I am going to bet that do a system it will need a tuner as well to keep things in check because of how specifically tuned these truck are now.
  12. Dec 1, 2015 at 6:13 AM
    DragNasty
    I'm pretty sure these engines are tuned back for longevity.
    There's so much room in the engine compartment you could easily throw in a big supercharger or even twin turbos... Question is how durable are these engines.
  13. Dec 1, 2015 at 6:26 AM
    gsxxr
    Tuning doesn't mean putting in a forced induction system.
  14. Dec 1, 2015 at 6:31 AM
    Scottyd
    Scott
    2016 LB TRD Sport
    Thanks. I've decided to wait. Maybe it's too early. Would want to do it when specific data and dyno specs are released to improve HP etc. Maybr when TRD does one, I'll check into it...
  15. Dec 1, 2015 at 6:33 AM
    Scottyd
    Scott
    2016 LB TRD Sport
  16. Dec 1, 2015 at 6:40 AM
    gsxxr
    The difference when trd does something vs aftermarket is huge. The have access to all the compute data where other have to figure it out on they fly.
    An air filter is different because the engine will only take oin as much as it can. Plus you have the maf sensor to monitor it and adjust the fuel. The exhaust on the other hand does not have a way to regulate back pressure. So you have to manually compensate for it.
    Lots of high performance engines now have exhaust vales on them to adjust back pressure for different driving conditions. But that's only on bikes and high end cars as of now.
    Scottyd[QUOTED][OP] likes this.
  17. Dec 1, 2015 at 6:54 AM
    gsxxr
    No its not!!! It for back pressure to make low range torque.
    Where did you come up with that?
  18. Dec 1, 2015 at 7:00 AM
    gsxxr
    The term back pressure is being used in exhausted gas regulations. That will change air fuel ratio.
  19. Dec 1, 2015 at 7:14 AM
    gsxxr
    In the 90' they had no idea about volume vs volatilit. Everything was big and wide open intake ports exhausted port and exhaust. Now a days technology has made many advances. Bigger is not always better.
  20. Dec 1, 2015 at 7:36 AM
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    Lmmfao...never knew the valves in my vette mufflers reduced back pressure..things you "learn" on TW
