Custom Oil Pan
Discussion in 'X-Runners' started by Coupe, Sep 30, 2011.
  1. Oct 11, 2011 at 10:35 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    O rly? :rolleyes:
  2. Oct 11, 2011 at 10:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah! lisa asked for it to be made into one lol
    :sandwich: 's for everyone:D
  3. Oct 11, 2011 at 8:04 PM
    Coupe
    Coupe [OP] Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I had it made. I took some measurements off the stock pan and the crossmember. I made some drawings and had a machine shop carve it out of a solid piece of aluminum.
  4. Oct 11, 2011 at 8:42 PM
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    U are the creator of this good idea.
    But, I would choose to loose that qt. to get that drain plug up & out of the way. Any crash bar U put on will only lower the ground clearence more , causeing more bottom drags.
    How much do U want for that 1st one? Big O
  5. Oct 12, 2011 at 5:16 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    If you go look at the pics again, you will notice the lower a frame pin points are lower than the oil pan. Also the two long axis structural members are about (not quite) the same depth as the oil pan. You do not need much to protect the oil pan from a front hit. Even as it sits, it will clear a standard 4" curb.
  6. Oct 12, 2011 at 5:23 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    i have to ask, is that a corvette trunk mat?
    i saw it and thought "what the heck?"
  7. Oct 12, 2011 at 5:35 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    My wife drives a Z06. This is the mat that goes in the hatch portion. Sun fades them pretty fast. I get the old ones and use them for working under the vehicles.
  8. Oct 12, 2011 at 5:43 AM
    crazyengineer
    patrick
    Bristol, TN
    sounds like a good use to me
    nice car by the way
  9. Oct 12, 2011 at 5:53 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Here is a pic of it.
  10. Oct 12, 2011 at 5:58 AM
    crazyengineer
    patrick
    Bristol, TN
    i would kill myself within an hour....
  11. Nov 7, 2011 at 7:01 PM
    thelostrican
    thelostrican boricua
    borinquen
    2008 silver taco
    bonestock@10psi:)
    i can tell you guys without a doubt that coupes oil pan, is great, i installed mine about a week ago...and its better in person than in pics...
    came in with all the hardware etc...
    i will say this, removing the studs that hold the pick up tube was a little bit tedious, removing the ones (2) that hold the oil pan...was a @$%^...obiously i didnt have the right tool for it....49 bucks later its was all good....although in the process i broke one of the outside studs...so my oil pan is being hold with one less screw....ill probably have to remove the oil pan again to take that one out....
  12. Feb 4, 2012 at 8:52 AM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    Crap!
    I'm at work and this company computer blocks the pictures
    :mad:
  13. Feb 4, 2012 at 9:42 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have a couple left, if anyone wants one.
  14. Feb 4, 2012 at 9:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How much are you selling them for?
  15. Feb 5, 2012 at 7:08 AM
    #35
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    These sell for $1100 shipped to the lower 48. It comes with new stainless hardware, trap doors installed, gaskets, Toyota FIPG, and a strong magnetic drain plug.
