Custom Overhead Console Switch Panels - Updated 6/26/2017 Now availalbe!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacitos, Feb 5, 2017.
  1. Oct 7, 2019 at 2:43 PM
    #241
    jz123
    jz123 Well-Known Member
    j
    11' tacoma
    Nice they look good
  2. Jan 6, 2020 at 1:37 PM
    #242
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Super awesome! Need this in my rig!
  3. Jan 6, 2020 at 1:44 PM
    #243
    ChiefTRDSport
    ChiefTRDSport Chief
    New Jersey
    2016 Tacoma Sport 3.5 DC 4x4 w/6sp manual
    TRD CAI and cat back, bug shield, rear step, and Black Horse bull bar.
    Have had mine in awhile now. Love the overhead setup. D9A8750D-C4D5-4B9F-9473-CC77BEE85F80.jpg
    Kevinpd325 likes this.
  4. Jan 7, 2020 at 11:57 AM
    #244
    Kevinpd325
    Kevin
    San Diego
    Interesting setup you have there. I see a USB cable running in front of your console. I assume that's to the gopro mount?
  5. Jan 9, 2020 at 6:44 PM
    #245
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    If I want the 4 slots, I need to order 3 different parts (driver / center / passenger), right? Or is there a single piece that combines all of them that I've overlooked?
    Just want to be 100% sure.
    ChiefTRDSport likes this.
  6. Jan 9, 2020 at 8:35 PM
    #246
    ChiefTRDSport
    ChiefTRDSport Chief
    New Jersey
    There are three separate parts. Driver’s side (1 switch), Center (2 switches), & Passenger side (1 switch). Center switches were the easiest.
    Kevin8se7en[QUOTED] likes this.
  7. Feb 5, 2020 at 6:22 AM
    #247
    Tacomabond007
    Tacomabond007 New Member
    Hey can you make me a custom panel ?
  8. Feb 12, 2020 at 7:27 PM
    #248
    PinoyTaco27
    PinoyTaco27 Well-Known Member
    East Stroudsburg, PA
    2018 TRD Sport Double Cab
    @tacitos any progress on the sunglasses mount switch panel for Toyota OEM small style switches?
  9. Apr 5, 2020 at 5:34 PM
    #249
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    I used @tacitos' switch panel for my @MESO puddle lights switch and it was a factory finish. Switch shown was a prototype (bottom spot now states AUTO). Thanks for coming up with great part ideas!
    corgimas likes this.
  10. Apr 14, 2020 at 6:57 AM
    #250
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Just ordered my ceiling button panel! looking forward to pulling and popping!
  11. Aug 7, 2020 at 12:24 PM
    #251
    TACAHOLIC
    TACAHOLIC Well-Known Member
    20 Cement DCSB TRD SPT
    @ For Anyone that has a TRD OR, that had the OEM center panel that holds 1 switch (like the locker switch), and you replaced the center panel with one that holds multiple switches...
    I'm looking for the OEM single switch hole center panel. Hoping like hell that someone on here kept there old one and would like to get rid of it. Thanks in advance!!! Please PM me if you happened to hang on to your old one.
  12. Aug 7, 2020 at 12:26 PM
    #252
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I should have one laying on the floor in my garage... give me a second to find it.
  13. Aug 7, 2020 at 12:31 PM
    #253
    5nahalf
    Erik
    Minnesota
    These are what I have (3rd panel blank that also works as the sunroof switch is broken)
  14. Aug 7, 2020 at 12:38 PM
    #254
    TACAHOLIC
    @5nahalf Thank you!
  15. Aug 7, 2020 at 12:39 PM
    #255
    TACAHOLIC
    I need the center panel with one hole. Would you sell it to me?
  16. Aug 7, 2020 at 12:41 PM
    #256
    5nahalf
    Erik
    Minnesota
    Yeah, PM me your address and Ill send it over to you. Its garbage for me that I should of thrown out long ago.
  17. Aug 7, 2020 at 12:44 PM
    #257
    TACAHOLIC
    Hope I sent you a PM
  18. Sep 11, 2020 at 2:11 PM
    #258
    captain_beefheart14
    captain_beefheart14 Well-Known Member
    2019 Cement Off Road
    Prinsu racks, cab and top, light bar, rear and side roof rack lights, ARE Camper shell, blackout, TRD Grille, Anytime front and rear cameras, Truck bed box (DIY) Bilstein 5100 front, OME 2885 Coils, Ikon Stage 2 Rear AAL
    @MESO what is your timeline on getting the overhead mounts back in stock? I would like to give you some of my folding money, sir!
  19. Nov 30, 2020 at 3:59 PM
    #259
    The Pirate
    The Pirate Takoyaki Takoma
    I ask this in another thread too, so I apologize for the redundancy. But I was wondering is anyone has successfully removed their S.O.S. switch? I have both the S.O.S and Sunroof controls on the overhead panel. I would like to get rid of the S.O.S. and swap in the MESO 4-SUN 4 button panel so that I can co-locate: Traction Control, Rear Locker, A-Trac, and 2 WD Low to the same panel.
    How big of a pain in the ass do you think doing this would be?
  20. Nov 30, 2020 at 6:36 PM
    #260
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Will the overheads work with crawl control on an off road?
    I lost track, the 2Lo is plug n play?
