Custom overhead console switch plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MESO, Jun 20, 2018.
  1. Dec 11, 2018 at 8:02 AM
    #361
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    perfect. i just wasnt sure if the blanks were for the toyota style switches or the carling type.
  2. Dec 11, 2018 at 8:05 AM
    #362
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Oh I gotcha, I’d assume they will both work since I’m almost positive the hole dimensions are the same (carling & long Toyota...not the short ones). But if it’s anything like on my truck in the factory locations a little help with a file made sure the fit was perfect.
  3. Dec 11, 2018 at 8:08 AM
    #363
    Gaunt596
    Matthew
    Central Maryland
    i remembered i have an ottraw/carling switch right after i posted that, it will need some help with a file, they dont drop in.
  4. Dec 11, 2018 at 8:13 AM
    #364
    AugustaTaco
    Josh
    Augusta, GA
    Seems like everything needs help with a file when modding lol
  5. Dec 13, 2018 at 9:42 AM
    #365
    Gaunt596
    Matthew
    Central Maryland
    on a related note, is there a vendor somehwer that makes a Normally closed toyota style switch? been looking for one for my ABS/VSC delete, but cant seem to find one.
  6. Dec 13, 2018 at 11:02 PM
    #366
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Might be able to swap in a NC switch to the pcb inside the switch housing. What you are calling a switch is really a case with an activating button that encloses a printed circuit board that has the actual switch soldered to it.
  7. Dec 14, 2018 at 4:55 AM
    #367
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    You could use a relay. Commodity automotive relays have a contact for relaxed open or relaxed closed. It toggles the other way when energized.
  8. Dec 14, 2018 at 6:42 AM
    #368
    Gaunt596
    Matthew
    Central Maryland
    thats what im thinking. should make the switch wiring a tad easier as well
  9. Dec 15, 2018 at 12:19 PM
    #369
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, a 5-pin relay would be easiest. The switch can either close or open the circuit depending on whether you use pin 87 or 87A.
  10. Dec 15, 2018 at 4:26 PM
    #370
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Any updates on when 2nd gen 6 hole version will be available?
    Need one bad so I can repurpose lower cubby for radio
  11. Dec 17, 2018 at 9:00 AM
    #371
    Gaunt596
    Matthew
    Central Maryland
    they are (or were) available on his website for sale just a week or two ago, not sure if theres any left in stock right now though
  12. Dec 20, 2018 at 6:26 AM
    #372
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    2nd gen overhead panels are up :yay:
    Echodawg likes this.
  13. Dec 20, 2018 at 7:09 AM
    #373
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    Only the switch pro from what I see.... unless others sold out that quickly.
  14. Dec 20, 2018 at 7:12 AM
    #374
    Shearboy2005
    Ky
    I see that now.. I must have got lucky. Got a 6 switch panel.
  15. Dec 20, 2018 at 7:39 AM
    #375
    griffin407c
    Upstate NY
    Been waiting for the return of the 6 switch panel. I signed up for email notification, but never got anything. Luck was on your side.
  16. Dec 20, 2018 at 7:51 AM
    #376
    Shearboy2005
    Ky
    I never got a notification either. Just by chance decided to check.
  17. Dec 20, 2018 at 7:52 AM
    #377
    griffin407c
    Upstate NY
    I've been checking as well, but always seems to be at the wrong time. Round 3 of waiting begins.
  18. Dec 20, 2018 at 10:31 AM
    #378
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    @mesojdm does the email when available button work on the purchase site?
  19. Dec 20, 2018 at 10:34 AM
    #379
    Shearboy2005
    Ky
    I didn't get a notification they were restocked. First time I had checked in couple of weeks and got lucky enough to place order.
  20. Dec 20, 2018 at 10:35 AM
    #380
    Shearboy2005
    Ky
    Were can I find the blanks to any unused holes?
