Custom overhead console switch plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MESO, Jun 20, 2018.
  1. Jan 29, 2019 at 12:48 PM
    #421
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    I could do a writeup when I have more time, but here's the basic info:
    One 15 foot Cat7 cable is all you need for up to 8 switches. Two 15 foot Cat7 cables gives you the option of expanding up to 16 switches. You can get a constant +12v, an ignition switched +12v, and a ground from the stock overhead console wiring harness so you don't need to use the Cat7 for those.
    I cut a small 1-foot piece of Cat7 (with RJ45 terminated end) and spliced my switch output wires into it. Then I ran the other 14 foot piece through the headliner and down the A-pillar, behind the glove box and out into the engine bay through an existing stock hole in the firewall there. The other RJ45 connector was left on the end hanging out of my overhead console area, with the cut end in my engine bay which I spliced to my relays. For my relays I use Deutsch connectors (waterproof plugs) and the Cat7 wire is too small for them, so I had to splice each Cat7 wire first to 18 AWG GXL wire and then to a Deutsch connector. I sealed it all with marine heatshrink.
    Now you have a male RJ45 (ethernet) plug hanging off your overhead console and another male RJ45 plug hanging off the Cat7 out of your headliner. Just use a Female to Female RJ45 adapter to connect them. You could skip this and just splice the Cat7 straight to your switches without any RJ45 connectors, but this allows you to disconnect the overhead console and pull it off if you ever want to. I like things to be modular.
    Here's a few pics. Sorry for the poor quality, some were taken at night with amber lights on in the background.
  2. Jan 29, 2019 at 1:10 PM
    #422
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Is that a furled side curtain airbag that you ziptied around?
    Blackouts[QUOTED] and Fleabag like this.
  3. Jan 29, 2019 at 1:11 PM
    #423
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    I would suggest taking those zip ties off your side curtain airbags may cause issues if you ever need them to deploy.
    Louisd75 and Blackouts[QUOTED] like this.
  4. Jan 29, 2019 at 1:43 PM
    #424
    Blackouts
    Las Vegas, NV
    :eek: you're right thanks.
  5. Jan 29, 2019 at 2:05 PM
    #425
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Wanting one to mount President Bill or similar small cb. Maybe a blank that could he custom cut.
  6. Jan 29, 2019 at 2:25 PM
    #426
    Little Bruiser
    Little Bruiser Well-Known Member
    Jon
    Salt Lake City
    2014 tacoma TRD
    I did the same thing for about a month until it dawned on me what I did.
  7. Jan 29, 2019 at 2:37 PM
    #427
    Fleabag
    Uriah
    Vancouver, WA
    I took all my airbag stuff down to dynomat my cab so when I saw that I was wondering if you knew.
  8. Feb 1, 2019 at 1:07 PM
    #428
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  9. Feb 1, 2019 at 2:47 PM
    #429
    Shearboy2005
    Ky
    Looking good! Wish mine was that far along.
  10. Feb 10, 2019 at 9:03 AM
    #430
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    So I’m trying to figure out the best attachment method - don’t want to remove material that maybe needed.
    Here’s the inside of the sunglasses holder:
    Do you think I need to pry the “slow drop” gear out?
    Other pictures
  11. Feb 10, 2019 at 9:21 AM
    #431
    Little Bruiser
    Jon
    Salt Lake City
    2014 tacoma TRD
    I removed the gear and cut out this plastic piece as well. I started with a small drill bit to try to guess the exact hole, which failed. So I kept sizing up the drill bit and then secured with a washer on both sides to make sure doesn't move in the future, if you do this just a heads up what happened to me. On the gear side the drill bit kept wanting to wander and separate where the gear was. So I just used a clamp to keep the 2 pieces of plastic as tight as I could which helped the bit
  12. Feb 10, 2019 at 9:23 AM
    #432
    Little Bruiser
    Jon
    Salt Lake City
    2014 tacoma TRD
    Waiting on 3 of my other switches to show up, I'll have 1 blank to figure out in the future
    Here is my view with it up, (I'm 5'8) without moving the mirror, doesn't block anything
  13. Feb 10, 2019 at 11:22 AM
    #433
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    So a few things if you do this with the tall Toyota style switches from CH4x4.com...they are long and extend past the back
    So when you cut out, you have to cut past the press tabs so the edge switches will fully seat
    But the end result I’m pleased with
    Here’s how I attached the console....I set it, drilled from the inside out through the hole and screwed from the inside out.
  14. Feb 10, 2019 at 6:50 PM
    #434
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I will add that the switches are MUCH easier to activate in the upper console
    Than I previously had them in front of the cup holders using the Izzy switch plate.
    MESO[OP] likes this.
  15. Feb 10, 2019 at 7:22 PM
    #435
    Little Bruiser
    Jon
    Salt Lake City
    2014 tacoma TRD
    I have both, way to many items to turn on
  16. Feb 11, 2019 at 4:53 PM
    #436
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    Started to install mine. Used JB Weld Plastic Weld to hold the panel in place I plan on drilling two smaller holes in the side mount tabs and use 1/16" rivets as well. Made a "T" out of plastic to assist in holding the panel in place where I wanted it.
  17. Feb 14, 2019 at 1:02 PM
    #437
    jcloer1
    jcloer1 Well-Known Member
    Jim
    McMinnville, OR
    2019 White AC TRD OR
    TBD
    Do you find the switch lights to be a distraction when driving at night?
  18. Feb 14, 2019 at 1:13 PM
    #438
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Not terribly but I wished their brightness matched the other dimmable dash lights.
    Contemplating researching about resistors and seeing if adding one would help match better. But honestly it’s not thus far bothering me too much.
  19. Feb 14, 2019 at 1:21 PM
    #439
    jcloer1
    Jim
    McMinnville, OR
    TBD
    Good to know. Thanks for the quick response!
    I was thinking about tapping the switch light wires into the dash lights after the dimmer for them. I always keep my dash lights fairly well dimmed anyway. Might as well do those switches the same way if I can. :)
    I have so much wiring to catch up with on my already purchased but as yet not installed accessories (12 circuit panel, 2LO kit, winch power to the rear hitch, seat heaters, bed lights, under hood light....), I think I'm going to have to buy a car off Craigslist to use as my daily driver while I do the wiring! lol
  20. Feb 14, 2019 at 1:50 PM
    #440
    Little Bruiser
    Jon
    Salt Lake City
    2014 tacoma TRD
    I was out of spots on the left side after adding a USB power for my phone, so I extended the lines for my fog lights which uses the power for all my switches. So my dimmer affects the 6 switches on top now. I have the iggy switch on the lower panel and those I cant dim which sucks. So I put tint on the inside of the switch which helped
