Custom overhead console switch plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MESO, Jun 20, 2018.
  1. Jun 28, 2018 at 3:55 PM
    #101
    oni06
    oni06 Well-Known Member
    Cool I will send over dimensions soon as I can.
    The_Black_Pearl likes this.
  2. Jun 28, 2018 at 3:56 PM
    #102
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    Same! Take my money now! That’s EXACTLY what I am lookin for.
  3. Jun 28, 2018 at 3:59 PM
    #103
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I want the one with 12 slots!!! Unpainted. I got the color matched paint to my truck!
  4. Jun 28, 2018 at 4:01 PM
    #104
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    I like that. That design is perfect. Will block the map light from blinding me while the wife has it on at night. I'm 6'8" and the light is almost in my line of sight.
  5. Jun 28, 2018 at 4:24 PM
    #105
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    @mesojdm
    So how do you install that and screw in the preexisting screw that goes to the little plastic insert up in the ceiling? I guess you just don’t?
    I run a console switch panel and that little screw does quite a bit for extra security and snugging it up the the roof rather than just relying on the 3 plastic retention pieces that go toward the dome light and the 2 metal prong clips.
  6. Jun 28, 2018 at 4:45 PM
    #106
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Good question. What I would do:
    1)Mount my new panel to the OEM overhead
    2)Route all wires and plug in all switches except for the middle one(leave the connector hanging out the hole)
    3)With a long screwdriver and screw attached, go up through the empty switch hole and mount
    4)Snap last button/switch in
    For the most parts, the ceiling mounting hole is a straight shot:
    4x4Taco09 and Bebop like this.
  7. Jun 28, 2018 at 4:49 PM
    #107
    oni06
    Removal could be a bit difficult.
    Bebop likes this.
  8. Jun 28, 2018 at 4:51 PM
    #108
    MESO
    State of Jefferson
    Would just need to pop the single switch directly over the mounting screw out.
    The switch pro housing on the other hand would be difficult as it mounts from the backside..
    Bebop likes this.
  9. Jun 28, 2018 at 4:53 PM
    #109
    Bebop
    Nick
    Sounds easy to me. I’m sure the switch could pop out with some plastic trim pry bars with ease
  10. Jun 28, 2018 at 4:59 PM
    #110
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    You're killing me right now!
  11. Jun 28, 2018 at 5:02 PM
    #111
    oni06
    @mesojdm
    Here are the sPod Touch Screen dimensions
    3-3/4w X 2-7/8h X 5/8 thick
    And a photo of the back.
  12. Jun 28, 2018 at 5:19 PM
    #112
    AlbertaSparky
    AlbertaSparky Self Made Hundredaire
    Cam
    Sundre, AB, Canada
    '08 BSP DCSB Sport
    Meso, you're a genius. On a side note, those map light leds. Is that a switch to change them from red to white as well? I forsee money coming your way for multiple things soon.
  13. Jun 28, 2018 at 5:22 PM
    #113
    MESO
    State of Jefferson
    good eye;)
    oni06 likes this.
  14. Jun 28, 2018 at 5:28 PM
    #114
    oni06
    Need
  15. Jun 28, 2018 at 5:34 PM
    #115
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    envious of your 3d printer and creativeness :cheers:
    MESO[OP] likes this.
  16. Jun 28, 2018 at 5:46 PM
    #116
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    I want to buy this!
  17. Jun 28, 2018 at 5:46 PM
    #117
    AlbertaSparky
    Cam
    Sundre, AB, Canada
    '08 BSP DCSB Sport
    Are these going to be included tomorrow if you release the other 2nd Gen lights? Second question would be are they going to be on the same page as the 3rd Gen ones or are you making a seperate thread in the 2nd Gen classifieds?
  18. Jun 28, 2018 at 5:49 PM
    #118
    MESO
    State of Jefferson
    Only 3rd gen stuff tomorrow sorry:\
    2nd gen stuff pushed to next week(a lot of assembly!) I will have ultimate maps, domes, and a limited amount of dual color.
    They will be in a new thread in the 2nd Gen section.
    Back to switch panels!:D
    Halffast555 likes this.
  19. Jun 28, 2018 at 5:51 PM
    #119
    AlbertaSparky
    Cam
    Sundre, AB, Canada
    '08 BSP DCSB Sport
    100% because I want one of them too!
  20. Jun 28, 2018 at 5:52 PM
    #120
    Fleabag
    Uriah
    Vancouver, WA
    So is it first click first served or is there a waiting-list that one can get on for a number of your innovative products?
