Custom Overland Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CanadianTaco89, Jul 6, 2019.
  1. Nov 28, 2019 at 7:39 AM
    CanadianTaco89
    CanadianTaco89 [OP] Off road camping rig.
    https://www.tacomaworld.com/threads/overland-build-custom-metal-work-and-diys-to-save-money.597975/
    You can check out my other forum.
    “Custom” meaning I built and there’s no other that is the same.
    1. 2012 4.0L in a 2008 Tacoma
    2. 2014 face swap
    3. “Custom” built grill
    4. Custom Front bumper (designed and fabricated by me)
    5.Custom Rear bumper (designed and fabricated by me)
    6.Custom roof rack (designed and fabricated by me)
    7.Custom Bed rack (designed and fabricated by me)
    8. Custom Flat steel inner tailgate (very simple)
    that’s just part of the exterior, if you still don’t believe it’s “custom”, feel free to post pictures of your Custom Tacoma for all to see.
  2. Nov 28, 2019 at 11:18 AM
    Sparky.
    Sparky. Bought, built, totaled
    Dawson
    Enumclaw Washington
    ‘14 AC 6MT -R.I.P, ‘08 cummins
    Did he claim to have a a custom taco? I must have missed that
    20somethingwidataco likes this.
  3. Nov 28, 2019 at 11:53 AM
    CanadianTaco89
    He builds retrofit headlights if you check out his page.
  4. Nov 28, 2019 at 12:15 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    That’s an aggressive front bumper
    CanadianTaco89[OP] likes this.
  5. Nov 28, 2019 at 1:25 PM
    81Trekker
    La Jolla SD
    Around here people that live out of their vehicles long term are considered homeless :)
  6. Nov 28, 2019 at 2:25 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    We call it a road trip.
    Apparently nowadays it is called an Adventure Overland “Expedition”.
    But hey, homeless also means no rent or utilities. More money for fun things :D
  7. Nov 28, 2019 at 2:36 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Looks good OP. I highly recommend something different for the hi lift. It will get dirty and dusty where it's at, and that doesn't bode well for proper operation when you need it. Which when you need it you will REALLY need it to work perfectly. Here's what I did to keep it nice and out of the way without monopolizing the bed rails: https://www.tacomaworld.com/threads/my-take-on-a-hi-lift-jack-mount.497315/
    Ideally it's not something you need all that often so it's okay to tuck it away pretty well. Keep a can of this handyhttps://www.amazon.com/DuPont-Non-S...4?keywords=teflon+spray&qid=1574980770&sr=8-4 and jack your truck up with it once a year while dousing the shaft with the spray to make sure it's ready when you need it.
    Skyway likes this.
  8. Nov 28, 2019 at 2:50 PM
    CanadianTaco89
    I like the idea, I do maintain my jack but I need a location that’s easily accessible in situations where I’m stuck, when I’m out overlanding or going out for a weekend my box if full of gear, food extra and all covered by my tonneau cover so it would make removing the jack lots of work and getting all my gear and food exposed to the mud. Located on my rack I easily remove it and re install it without compromising my other gear. Don’t worry I wash it when I get home and lube it up
    Skyway likes this.
  9. Nov 28, 2019 at 6:26 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Nice FAB work. :cheers:
  10. Nov 28, 2019 at 10:54 PM
    Sparky.
    Dawson
    Enumclaw Washington
    Sure seems like a lot of your messages are missing?:ballchain:
    did you decide to retract them? Or did OP do that for you?
  11. Nov 28, 2019 at 11:02 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    The bed rack lights are super neat!
  12. Nov 29, 2019 at 1:47 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Don’t know haha just called a punk a punk.
    Who poo poos another man’s build thread with invalid douchery? Contrarian children with poor upbringing usually haha.
    This is all really simple. A man said “custom” in the title and some punk saw that, clicked on it, didn’t read, and immediately declared it wasn’t “custom” enough for them haha!
    I’ve had canines with significantly more impulse control
    This is all quite entertaining to me
  13. Nov 29, 2019 at 5:17 AM
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    Its not Overland bro without a snorkel, Skottle, and a Yeti! :p
  14. Dec 1, 2019 at 9:30 PM
    CanadianTaco89
    Snorkel is on its way, I have a yeti and an Engel and I much prefer cooking over the fire and I got a Colman stove if that isn’t possible.
    Casper66 likes this.
  15. Dec 2, 2019 at 5:36 AM
    #35
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Two worlds of thought here. The first is that he's not using them for grips so much as for storage of paracord and resting his hands on longer drives. Second is that in most aggressive driving classes (including in the police academy) they teach that 9 and 3 are better than 10 and 2 for actual control. :D
  16. Dec 2, 2019 at 6:10 PM
    #36
    CanadianTaco89
    Lol you thought that through, it’s #1 actually lol I like to have some rope in in case I really need and that’s where I grab the wheel on long flat drives lol
  17. Dec 2, 2019 at 6:29 PM
    #37
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Cool build Sir. As some one who does fab work i can appreciate all the work you have invested in this. The HUD is something I've not seen before and is just flat cool. I'm much more a function over form person and have just built as I needed. I wish I coulda done more on the truck for myself but lacking some of the tooling for the home shop. I have reserved most of the fab work for our tiny camper. That's most of the joy in it for me finding something we need and making it. The planning and execution to build it and make it function as you need it to. :cheers:
  18. Dec 2, 2019 at 6:33 PM
    #38
    CanadianTaco89
    That’s right up my alley of thinking! Im in the automotive trade and work in a shop so all the tools I need are always accessible along with the space and comfort of a warm shop!
    Casper66[QUOTED] likes this.
  19. Dec 2, 2019 at 6:39 PM
    #39
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Well that certainly must be really nice. i did autobody/paint/ welding and fab work for 30+ years. Pretty much all fleet work and never really allowed to do much for myself. I've got a couple of welders and a plasma here at home so I can get a bit done I really need to build a seperate shop and invest in a good metal brake and tubing bender but at this point in life who knows. Hell I'd probably never come in the house. So, I really enjoy reading threads like this and seeing the creativity used by others
  20. Dec 3, 2019 at 1:55 AM
    #40
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    @CanadianTaco89's reply in Canadian accent "sorry".
