Custom PID transmission temp
Discussion in 'Technical Chat' started by Freediver223, Aug 12, 2019.
  1. Aug 12, 2019 at 5:09 AM
    Freediver223
    Freediver223 [OP] Member
    2009 Tacoma 2WD regular cab
    I got the ELM327 bluetooth adapter for my truck and downloaded the Torque app. In order to get it to read the transmission temp I had to program in a custom PID. After alot of online searching and trial and error I think I have it reading the trans temp but I'm not 100% sure. I used the following inputs:
    21d9
    unit type: *F
    equation: ((((E*256)+F)*(7/100)-400)/10)
    Driving around for 15 miles with just me in the truck the reading I was getting went up to 160 degrees. I'm gonna try towing something today and see what it goes up to.
    Are these the correct inputs for a 2009 4 cylinder ? It could be some random reading I'm getting but 160 sounds about right to me.
  2. Aug 12, 2019 at 5:13 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get or borrow a Scangauge or equal. That will be your standard.
  3. Aug 12, 2019 at 5:24 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    These are the codes that I use
  4. Aug 12, 2019 at 5:26 AM
    buckmaster243
    Buck
    Washington
    160 sounds rights. What was the temp outside and what was the type of driving?
  5. Aug 12, 2019 at 10:34 AM
    Freediver223
    Outside temp was about 70. Country roads going 35-60 mph.
  6. Aug 12, 2019 at 10:36 AM
    Freediver223
    What do the letters in the equation correspond to ?
    It seems if I try the 2182 code no matter what letters I use it gives an error message.
  7. Aug 18, 2019 at 7:41 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Here's what worked for me:
    Once in Torque for the first time, setup your vehicle profile, which will enable you to start using the app.
    From the main screen, hit your menu button, then choose "Manage extra PIDs/Sensors"
    Hit the menu button again, and choose "Add custom PID"
    Hit "OK"
    Under the first item called "OBD2 Mode and PID" enter "21d9"
    Under "long name" choose whatever you want. I typed in "Trans Custom"
    Under "short name" choose whatever you want. I typed in "Trans"
    Under "minimum value" leave it at "0" or type in "0"
    Under "maximum value" type in "300"
    Under "scale factor" leave it as "x1" or type in "x1"
    Under "unit type" type in "F"
    Here's the tricky part - under "equation" type this in, EXACTLY, without any spaces:
    (((((G*256)+H)*(7/100))-400)/10)
    That's *five* parentheses at the beginning! Just be sure that there are six total parentheses facing to the right, and six total to the left.
    Leave the rest blank and hit "OK"
    Now when you want to add a gauge to the display, you should see "Trans custom" or "Trans" or whatever you named it at the beginning.
    Larzzzz likes this.
  8. Aug 23, 2019 at 8:26 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I use basically the same formula, but A and B are my variables. Can anyone explain why it works, though?
    Like what is the significance of (7% less 400) divided by 10? What is that factor?
  9. Aug 23, 2019 at 8:31 AM
    TheDevilYouLove
    Marylandistan
    And wouldn’t multiplying by -39.993 work just as well and be easier to type than ((7/100) -400)/10?
  10. Aug 26, 2019 at 11:16 AM
    Fullboogie
    Dave
    Houston
    I have no idea man. I took that setup from someone who knows a whole lot more than me. There's gotta be some science-types on here that can explain it.
  11. Jul 25, 2020 at 2:01 PM
    Woodyphi
    Woodyphi New Member
    Jerry
    Tacoma07V6
    I think you must use G and H for variables, not A and B. I believe that these are words used by 21d9 PID for the AT converter temp sensor. Use same equation with variables E and F for pan temperature sensor. This seems to be working for me with temperatures starting at ambient air. Need to road test on Horton the friendly elephant, 2007 V6 4L 4x4.
  12. Aug 15, 2020 at 5:19 AM
    blbowers
    blbowers Member
    Brian
    2011 Toyota Tacoma
    So using this PID, when I change the transmission fluid I no longer have to put the truck in Check Temp Mode?
    Also, for transmission fluid maintenance, do I use the AT converter temp sensor reading or the pan temperature reading?
  13. Apr 24, 2023 at 1:12 PM
    Yooper30
    Yooper30 Member
    14' Tacoma dc sb
    not sure...
    could you tell me the difference between them 2 codes in your pic.? are they different sensors? so far i have found 3 codes for Transmission temp. they all give me a different reading. (In pic)20230424_154426.jpg
  14. Apr 25, 2023 at 6:48 AM
    buckmaster243
    Buck
    Washington
    My understanding is that one is converter fluid temp and the other is pan fluid temp. Also this app doesn’t work on my phone anymore so if anyone has an updated version that works I’d love to get it working again.
  15. Apr 25, 2023 at 6:43 PM
    Yooper30
    Yooper30 Member
    14' Tacoma dc sb
    not sure...
    Yeah im not sure.. What do you mean has an updated version? what kind of phone you got?
  16. Apr 26, 2023 at 12:20 PM
    plncrzy
    plncrzy Member
    2011 tacoma spcb 4x4
    I got the same results and I assume that the only "reliable" trans temp value is the one you added as above.
    Maybe the second gen has only 1 trans temp sensor?
    I also wish that someone could verify that the formula is accurate.
    I am about to change the oil before a long drive with a truck camper. I would like to monitor the trans temp.
  17. Apr 30, 2023 at 12:56 PM
    Yooper30
    Yooper30 Member
    14' Tacoma dc sb
    not sure...
    So after running around with it only 2 of them 3 work proper. (bottom and right one are more accurate... i think) the top left one never fluctuated even from a cold start it was reading 130 whatever. the other 2 moved around alot. not in a bad way. they never read the same but if it is two different sensors... i guess it makes sense. I still didn't trust it to do the atf drain and refill. the obd wire jump is the route i went for the tempo check.
  18. May 9, 2023 at 11:54 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have an IR gun, you can use that to ID the pan temp reading. I have an UltraGuage that reads pan and torque temps. My IR gun reading on the pan is within 1-3 degrees on my UG reading for the pan. At idle, the pan and torque readings are very close.
