Custom Rear axle, VSS and Tcase issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kombi, Jan 6, 2023.
  1. Jan 6, 2023 at 6:00 PM
    Kombi
    Kombi [OP] Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    Has anyone swapped a Worm gear into a newer manual transfer case?
    I am running a 2016 4runner manual shift transfer case in my 2008 AT Tacoma. I have a full float rear axle and need to figure out a VSS as the tone rings dot not work from an older land cruiser like I used.
    I pulled apart a spare bastard transfercase i was given that is a Manual FJ with an Automatic input shaft installed.. but the splines on it were longer vs the 4runner.. I have not checked my old factory case but assumed the worm gear is the same and the splines are shorter..
    I think i am out of luck and need to just find a FJ case and replace the 4runner one im using... sucks as its already modded for my twin sticks and only has maybe 6k on it now.
