Custom recovery points?
Discussion in '1st Gen. Tacomas (1995-2004)' started by glauver, Mar 19, 2025.
  1. Mar 19, 2025 at 7:17 PM
    glauver
    glauver [OP] New Member
    Gabe
    2004 tacoma
    34s bed exit exhaust 2.5in suspension lift
    Hey, i’ve got a 2004 extended cab and i’m hoping to fabricate some custom recovery points for my rear. If anybody has done this or has any input on good locations that would be appreciated. Thanks:)
  2. Mar 19, 2025 at 9:57 PM
    Glamisman
    Glamisman Well-Known Member
    This is a tough one... how bad do you think you will get stuck? The frames on these arent the strongest so any single point pull from a bad place might be a problem. I am thinking a receiver on the back that ties to frame together better than the factory bumper would be a good starting point. I have not had the front bumper off an 04 so I dont know how it all ties together up front. I know there is a huge difference from 96 to 98 but after that I dont know. Crawl under the front and look to see how the factory bumper mounts. Are there crush boxes or hydraulic cylinders or ?
  3. Mar 19, 2025 at 10:01 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    My hitch has recovered 4 door jeeps and f250s stuffed in snow banks. Just make it easy and bolt an oem hitch on
    tsab916 and oldgreg like this.
  4. Mar 19, 2025 at 10:02 PM
    oldgreg
    oldgreg Well-Known Member
    Greg
    2001 2.7 reg cab 4x4
    He’s asking about the rear, in which case I’d just get a hitch receiver shackle block. The strongest points on the frame will be where the hitch mounts anyway
  5. Mar 19, 2025 at 10:20 PM
    undisider
    undisider Member
    Nathaniel
    2x 99 tacos
    one "stock" TRD one lifted/locked, supercharged SR5
    I'll second a receiver hitch there is not much else of structure there and if you do build something it will end up looking like a full bumper or a hitch to get something strong enough.
    Wulf likes this.
  6. Mar 20, 2025 at 9:26 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    as already mentioned, receiver hitch is cheap and will do the job. Aftermarket bumpers can give you additional recovery point options but at a much greater cost
