Custom Rocker Switch Group Buy - Limited Time! - Ships NOW! - Blitzpro
Discussion in 'Group Buys' started by Blitzpro, Aug 18, 2014.
Thread Status:
Not open for further replies.
  1. Aug 22, 2014 at 3:47 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I need that two switch holder. And measurements. wanting to do in cab winch controls.
  2. Aug 22, 2014 at 3:50 PM
    Blitzpro
    Blitzpro [OP] Well-Known Member
    We can make it in any dimensions your want. PM me what you'd like and we can get started. :cool:
  3. Aug 22, 2014 at 5:23 PM
    ALBtacoma
    ALBtacoma Well-Known Member
    Pete
    Red deer AB, Canada
    07 trail limo trd sport
    What if you need a different picture than what you have. I installed under hood LEDs and would like to run the switch inside
  4. Aug 22, 2014 at 6:08 PM
    Blitzpro
    That's not a problem. We can draw a custom icon for you. If we think there may be others that could use the icon, we won't charge you for the artwork. I recall there's anothe vendor..(Anti Dark I think?) on TW that is selling engine bay hood lights. PM me and we'll work something out.
    And just as a side note, we welcome new icon ideas. If you need custom icons, just email or PM us. We're always available to work on new ideas. :headbang:
  5. Aug 23, 2014 at 10:37 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    How do I add the removal tool to my order? It's not an option on the group buy link, want to replace my sPOD covers.
  6. Aug 23, 2014 at 11:04 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I need it to fit beside the cup holder near my shifter. I want to put winch power and in / out switches in it.
  7. Aug 25, 2014 at 2:33 PM
    Blitzpro
    Sorry, forgot to add it to the item category. Here's the link if you'd like to order the actuator removal tool:
    http://mkt.com/bpgb/actuator-removal-tool
  8. Aug 25, 2014 at 3:01 PM
    Blitzpro
    I have made fairly slim 2 slot panel that measures 66mm x 56mm (~2.6"x2.24"). Has 4mm holes for mounting. The mount holes are spaced 62.4mm (2.44") apart. This about the slimmest bezel we cut for 2 slot panels.
  9. Aug 26, 2014 at 9:17 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Do you offer any switches that will fit into the blanks that are located under the HVAC controls in the center of the dash? They are just a bit smaller than the switches that you have listed in the group buy.
  10. Aug 26, 2014 at 11:18 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Will these work for the first gen rear diff button too? Same way?
  11. Aug 26, 2014 at 5:16 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Aug 26, 2014 at 8:00 PM
    Blitzpro
    I think you're talking about the slots above. Unfortunately, we don't have those available at the moment. If there is enough interest, we can produce a small batch. If you're really interested, we could gauge interest in another thread.
    Yes, I believe if you pop out the bezel, the opening is approximately the correct dimensions. You may need to file down the tabs in order to snap in the switch, but I do believe it will be a snug fit.
    All of todays order have been packed and shipped! Thanks guys!
  13. Aug 26, 2014 at 8:01 PM
    a.smo
    Aaron
    PHX, Az
    Awesome! Thanks
  14. Aug 26, 2014 at 9:47 PM
    ACEkraut
    Aaron
    Durham, Maine
    I am looking to set up some hood lights and some bed lights and those are the only two switch blanks I have available. Out of curiosity, about how much would it cost to special order two switches?
    For what it is worth, I have seen more than a few posts from people who have expressed interest in switches that fit that location. So it might be worthwhile to gauge interest with another thread. If you own the TRD Off-Road those will probably be the only blank spots most owners will have to put a switch(s).
  15. Aug 26, 2014 at 10:52 PM
    #35
    99civ
    99civ Well-Known Member
    Edmonton
    06 TRD Sport
    OME 885x w/Dakars - HIDs - Husky Mudflaps - LED Dome/Map/Reverse Lights - Illuminated 4x4 switch
    ship to Canada?
  16. Aug 27, 2014 at 9:26 AM
    #36
    Blitzpro
    Yes we do, however, it's $17.50 for a flat rate USPS padded envelope anywhere in Canada. So it would be the same shipping cost for 1 switch or 16 switches in one envelope. Maybe gather a few buddies and put in one order to save on shipping?
    I have fit 16 switches comfortably in a flat rate envelope, however I think I can do 22 switches with proper padding.
  17. Aug 27, 2014 at 9:53 AM
    #37
    catattacksdog
    catattacksdog Well-Known Member
    Not Steve
    Not Kentucky
    07 dc
    Is it possible to do custom writing on a switch? I want a switch to disengage my ABS. The top of the switch would say "ABS OFF" and light up when the switch is ON, maybe a symbol or something in the middle, and no writing on the bottom
  18. Aug 27, 2014 at 9:58 AM
    #38
    Blitzpro
    We do have a switch body that will fit that slot. The top of the rocker only illuminates when the switch is in the ON position. I'll take a look if we have stock of any of those bodies and rockers right now. Will keep you posted.
  19. Aug 27, 2014 at 10:11 AM
    #39
    Blitzpro
    Yes! We are all about making your switch fit your application. We can definitely do that. Let me know if the above fits your needs.
  20. Aug 27, 2014 at 10:31 AM
    #40
    Blitzpro
    Out of curiosity, how does the circuit work for disengaging the ABS? Are you going to be grounding a signal to disengage ABS? Or will you be switching a positive signal?
Thread Status:
