Custom Rocker Switch Group Buy - Limited Time! - Ships NOW! - Blitzpro
Discussion in 'Group Buys' started by Blitzpro, Aug 18, 2014.
Thread Status:
Not open for further replies.
  1. Aug 29, 2014 at 12:21 PM
    #61
    Blitzpro
    Blitzpro [OP] Well-Known Member
    I'll work on some this weekend and post them on Monday.
    Last nights and this mornings orders already completed and out the door! Thanks guys.
  2. Aug 31, 2014 at 9:27 AM
    #62
    c2one
    c2one Well-Known Member
    Texas
    '13 Classic Silver SR5 4Runner
    This would be :sick: !!
    Sub'd for pre-wired 6 switch panels. Now I need to find/buy 6 things to have a switch for. :D
  3. Sep 3, 2014 at 2:15 PM
    #63
    Blitzpro
    Labor Day weekend was a bit chaotic with orders, but working on the panels kits for you guys. It'll use flag terminals to cut down on the clutter back there. The space is pretty cramped! You guys will definitely need to do some drilling to get the harness to cleanly run through to that spot on the sun glass holder.
  4. Sep 3, 2014 at 5:32 PM
    #64
    Tovar28
    Tovar28 Well-Known Member
    David
    Chino,California
    05 prerunner TRD sport
    bilstien 5100s in front @ 1.75 bilstien 5160 in rear,general HD 4 leaf pack, 20% tint in front 5% rear, 40 inch led bar ,Kc daylighters , Aries bully bar , aries side steps ,black housing headlights ,factory roof racks ,snugtop camper shell, plastidip rims, bfg ko2 tires
    Soo..... how do we order the tacoma shilutte?:D
  5. Sep 3, 2014 at 5:53 PM
    #65
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Anything for halos? Also waiting on tacoma silhouette. What color is everyone getting for the second gen to match the dash lights? Amber or red?
  6. Sep 3, 2014 at 6:00 PM
    #66
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    WOOHOO!!! sounds fantastic! thanks for doin this Blitzpro guy! (Ty) :p
    ... do i get the first one? :p
    think we could get a rundown on how the wiring is when you get closer to the end? for example, are all the grounds/power linked together so that we only need one wire each coming into the switch panel.
    I'm just thinking out loud here.. but for my setup, I will have atleast 4 things right off the bat I will want switches for. will be installing over the next couple weeks:
    rock lights
    LED bar
    Dust lights
    Reverse lights
    im wanting to get all the wiring up to the switch portion complete, so that when they are ready, all i will have to do is install the panel and connect the wires. so, with that being said, It would be nice to know what all needs to be ran up to that spot as far as wires. if that makes sense.
    I cant wait!!
    amber for mine ^^ definitely amber.
  7. Sep 8, 2014 at 8:55 AM
    #67
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    ^^ X2. I'm ready to pull the trigger on a couple of switches but would a Tacoma silhouette for a roof-mounted light bar and hood ditch lights would be awesome!
  8. Sep 8, 2014 at 11:10 AM
    #68
    Blitzpro
    Still working on the kit! I'll have some pictures shortly.
    Some sketches to hold you guys over. Still tweaking it as I'm not 100% with it. Two sketches I'm toying with, feedback?
  9. Sep 8, 2014 at 11:59 AM
    #69
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    sounds good! and those look awesome!
  10. Sep 8, 2014 at 1:59 PM
    #70
    TacoSurfer
    TacoSurfer Well-Known Member
    Central Cali
    07 Access 6-Speed 4.0L 4x4
    How about a Offroad Light Switch? Tacoma profile with lights in or in front of the grille? Definitely interested in one for my behind the grille off road lights and one for my LED pod that I use for extra light for in reverse.
  11. Sep 8, 2014 at 5:06 PM
    #71
    Tovar28
    David
    Chino,California
    Those look nice!!
  12. Sep 10, 2014 at 12:27 PM
    #72
    f1scher81
    f1scher81 New Member
    Are these switches smaller than the OTTRATTW switches which do not fit into the OEM Toyota switch openings?
  13. Sep 10, 2014 at 7:10 PM
    #73
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    06 A-Cab TRD Off-Road 4x4
    i'm about to wire up some driving lights. any chance you have a switch that is the design of the "fog lights"switch, but with horizontal rays emitting from the lamp shape.
    i'd be interested in the text saying DRIVING LIGHTS or OFF-ROAD LIGHTS like the OTRATTW's. i can't make up my mind though :/ The lights will be 7" hids behind the grille. so if you have a recommendation...
  14. Sep 11, 2014 at 4:33 AM
    #74
    DiRtYtAc0
    DiRtYtAc0 Member
    New Hampshire
    2013 tacoma single cab
    3" toytec lift , 18" mot ometal mo969
    I want to order the Tacoma Roof LED Light Bar switch, does the truck part light up as well? if so can I get them two different colors. I'm looking to get a switch that mounts in the slots above the mirror control.
  15. Sep 11, 2014 at 11:06 AM
    #75
    Blitzpro
    The ones in our group buy fit in certain panels on OEM Toyota switch openings if the inner tabs of the panel opening are filed down. The OEM switches are push type, while the ones we produce are rocker type.
    The switch spots on the left side of the dash on 1st and 2nd gen Tacoma's are usually compatible with our switches if you file the inner tabs down. Your OEM switches will not fit as snug anymore after you file the tabs down.
    The switch openings below the climate control on 2nd gen Tacoma's are slightly shorter. We're still experimenting with a few switch bodies to fit this spot.
    Yes, we can modify the "FOG LIGHT" switch graphic for you. Custom text is fine as well. Just state that in the "Note to seller" section before you check out. I'd choose the "FOG LIGHT" icon and add your special instructions. Let me know if any of the above work for you.
    Yes, the entire icon will light up, not just the light bar portion of the Tacoma silhouette. I'm not super familiar with the spot your talking about, but if you if the opening is anywhere close to 1.45" x .830" then you're good to go! :thumbsup:
  16. Sep 11, 2014 at 12:22 PM
    #76
    DiRtYtAc0
    DiRtYtAc0 Member
    New Hampshire
    I wanted one for the switches above the one in the picture, I don't have my truck with me so I can't measure it.
  17. Sep 11, 2014 at 12:27 PM
    #77
    Blitzpro
    I'm 98% sure those are the same dimensions as the openings below.
  18. Sep 11, 2014 at 12:30 PM
    #78
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
  19. Sep 11, 2014 at 1:01 PM
    #79
    DiRtYtAc0
    DiRtYtAc0 Member
    New Hampshire
    Thanks for the quick reply
  20. Sep 11, 2014 at 4:46 PM
    #80
    DiRtYtAc0
    DiRtYtAc0 Member
    New Hampshire
    Just ordered two switches can't wait till they come in
Thread Status:
