Custom sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, May 9, 2010.
  1. May 9, 2010 at 11:43 PM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    So i want to see what everyone thinks. This set is for TacomaTSP4 and i am going to make a set for myself. All made out of 2"x3" 1/8" wall tube.
  2. May 9, 2010 at 11:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Cool. You're going to add gussets on the mounting plates right?
  3. May 9, 2010 at 11:54 PM
    tacomakid89
    tacomakid89 Awesome Member
    William
    SoCal, CA
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime
    They dont look too bad.
  4. May 9, 2010 at 11:56 PM
    Chachie
    Justin
    Nor Cal
    Ya, and i still have to fill and cap everything.
  5. May 9, 2010 at 11:58 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Whats up, where in NorCal are you and how much do you charge? :D
  6. May 10, 2010 at 12:00 AM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Mmmmmmmmmmmmmmmmmmmmmmmm? Its different!
  7. May 10, 2010 at 12:01 AM
    Chachie
    Justin
    Nor Cal
    Haha im in the santa rosa area. Idk if im going to make another set after ours, these took me about 5 months just cause ive been so busy. But if i make any more they would probably be quicker because i dont have to do all of the fabing. But if you want i can try and draw up a number for you and let you know.
  8. May 10, 2010 at 12:02 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    waaaaay too close to the body and lower door line. The cab and chassis flex when offroad, these look like they're definitely gonna be hitting something.
  9. May 10, 2010 at 12:04 AM
    Chachie
    Justin
    Nor Cal
    Oh i know i noticed that too, but they are not nearly as close to the door jamb as they look and the and that is close to the body is going to be cut off at a 45 so that it clears better and follows the body lines better.
  10. May 10, 2010 at 6:42 AM
    PreRunner
    PreRunner Well-Known Member
    looks good from ground level. looks like anus from eye level. round = better. too close to door edge.
  11. May 10, 2010 at 6:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yea, they look like they are already touching the front fender. other than being to close They look pretty good
  12. May 10, 2010 at 7:36 AM
    Chachie
    Justin
    Nor Cal
    Thanks for all the input guys (good and bad). That's exactly the reason I posted this up here. The outside rails and risers are only tack welded on so it would be extremely easy to change the angle and come out a little more and have a little more clearance. That is at about 43 degrees. I was thinking about going to 33 or 30. Either way they are going to be on a truck by Saturday morning. Hmm I see some long nights ahead.
  13. May 10, 2010 at 7:40 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    If a rock catches the front of the box tubing you are stuck. You might want to incorporate some angles to help the slider ride over obstacles at the front of the truck. I like the idea though.
  14. May 10, 2010 at 7:41 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    are you going to add any cross pieces at the ends of the 2 long bars?
    i think you called them risers
    id add 2 more of those before you finish...1 at each end
  15. May 10, 2010 at 7:44 AM
    Chachie
    Justin
    Nor Cal
    As for the angles, I planned on cutting the ends off at a 45. And I was thinking that about the cross bars/risers too.
  16. May 10, 2010 at 7:49 AM
    JDMcQ
    Sounds good.
  17. May 10, 2010 at 7:50 AM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    i second this, they look like the doors are hardly gonna clear and when the frame twists they are gonna hit somthin. hope you never bump into anything :p
