Custom Spare Tire Lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rusty White Taco, Jul 6, 2011.
  1. Jul 6, 2011 at 7:20 PM
    Rusty White Taco
    Rusty White Taco [OP] Active Member
    Central Coast, CA
    04 4x4 Xtra Cab TRD Offroad SR5
    Debadged, Front 5100s at 2.5, 1" rear shackle lift, 5125s in the rear, trimmed exhaust pipe
    I searched and searched, but couldn’t find what I consider to be a good solution for a spare tire lock. It seems as though Winchlock was the closest to a “good” solution that I could find, but they appear to have gone out of business and their products are no longer available. With that in mind, and knowing that I have a $200 tire and a $200 wheel free for the taking, I set out to make a “good” spare tire lock on my own. Here’s what I came up with:
    I bought a MasterLock 5/8” hitch receiver lock.
    I took some scrap steel (some flat bar and some angle iron) I had laying around and made a U-shaped bracket, with two mounting holes in the legs of the “U” (for bolting to the frame cross member) and a 11/16” hole in the bottom of the “U” (for putting the shaft of the hitch receiver lock through). I welded it all together (including welding the hitch receiver lock shaft to the bottom of the “U”), gave it a coat of paint, drilled the appropriate holes in the frame, and bolted it up. Here are the results:
    View from passenger’s side, without the tire pulled up (obviously):
    View from the driver’s side, without the tire pulled up (obviously):
    View of the tire pulled up (notice the lock shaft sitting nicely through the lug hole):
    View of the lock actually locked:
    This was a $12.50 solution ($12 of which was the lock, $0.50 was scrap steel) and works as good as, if not better than, any other solution out there (i.e. a cable lock, which can be cut, etc.). I tried to get the spare tire off without unlocking the lock and it’s virtually impossible (extreme exceptions aside). I hope this helps someone do the same.
  2. Jul 6, 2011 at 7:25 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Great idea!
    Very innovative!
  3. Jul 6, 2011 at 7:41 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    That's an awesome solution!! Wanna build one for me?? I'd be willing to pay for that!
  4. Jul 6, 2011 at 7:55 PM
    Rusty White Taco
    Central Coast, CA
    Thanks man! I appreciate the feedback.
    Yeah, we can build one. We can have a wrenching day and we'll make one for a 2nd gen and post that build...
  5. Jul 6, 2011 at 8:42 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    This is what the forum is about...nice to see someone taking action and not whining.....great job and points for sure
  6. Jul 7, 2011 at 9:13 AM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Awesome! I'm in!!!
  7. Jul 7, 2011 at 1:36 PM
    Rusty White Taco
    Central Coast, CA
    Thanks!!!
  8. Sep 9, 2011 at 5:48 PM
    jiveturkee
    jiveturkee Active Member
    Jake
    Tacoma, Wa
    '11 T|X Pro
    TRD short shift Pelfrey built front bumper
    A great solution to a common problem. I wish I seen this thread before my spare was stolen. If you are down to make these I'm interested in buying one before my replacement spare gets lifted too. How much would you want to make one for me?
  9. Sep 22, 2011 at 10:19 AM
    Rusty White Taco
    Central Coast, CA
    I won't have access to a 2nd gen until November. Once I make that one, I'll let you know if I would be able to make some and, if so, how much it would cost. Stay tuned...
  10. Oct 7, 2011 at 7:52 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    sub'd i might be in for one too depending on price, btw awesome job
  11. Jan 8, 2012 at 12:04 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Subd Definetely interested. Was about to buy the factory lock Toyota has came up with.
  12. Jan 31, 2012 at 4:29 PM
    jiveturkee
    Jake
    Tacoma, Wa
    '11 T|X Pro
    Did you ever get your hands on a second gen?
  13. Jan 31, 2012 at 8:38 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Good idea if you are going to steal a spare off a Tacoma you need the crank, I don't know if there all interchangeable or not, why not bolt a chain to the frame where the bracket is bolted in the first picture let the chain it fall thru a hole in the wheel, as you crank the spare up, loop it thru the wheel again and padlock it.
  14. Feb 1, 2012 at 7:30 AM
    Madjik_Man
    Colorado Front Range
    I love this website and community
  15. Feb 1, 2012 at 7:48 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nicw that's a great idea and good write up
  16. Feb 1, 2012 at 7:50 AM
    Manwithoutaplan
    ID
  17. Feb 1, 2012 at 8:22 AM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    I actually work for Master Lock, and I think this is a great idea!! Glad to see our products at work in new and extremely useful ways.
    Professor likes this.
  18. Mar 19, 2012 at 4:22 PM
    tractng
    tractng Well-Known Member
    Would a cable with a lock work? I got a set from walmart but never look down on the tacoma. I am basing on the past car I had. I am thinking of wrapping the cable around the spare tire and chaining it to the "chain" (the one that hoists the spare up and down) that comes with the truck.
    Any feedback on this?
  19. Jan 6, 2013 at 8:02 AM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    I just build this for my wife 4runner..!
  20. Jan 6, 2013 at 9:03 AM
    BAMFTACO
    Juan
    Kings bruh
    That's a neat little idea. It will probably look better once you grind the welds and paint it
