Custom switch illumination harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lapoltba, Jul 17, 2019.
What Options do you want? (You can select more than one)
  1. PNP for a single switch
    47 vote(s)
    25.7%
  2. PNP with ability to "daisy-chain" more switches.
    125 vote(s)
    68.3%
  3. Left of steering wheel.
    88 vote(s)
    48.1%
  4. Right of Steering wheel
    73 vote(s)
    39.9%
  5. no
    1 vote(s)
    0.5%
  6. Overhead console
    25 vote(s)
    13.7%
Multiple votes are allowed.
  1. Mar 1, 2020 at 5:52 PM
    #101
    SevenXL
    SevenXL Well-Known Member
    MA
    18 TRD DCSB 6MT
    Finally :spending:
  2. Mar 1, 2020 at 6:05 PM
    #102
    GBR
    GBR Well-Known Member
    19 TRD OR
    Awesome! Glad to hear this is happening. I'll be a for sure buy. My 2 lo switch is in the center console. You did a fantastic job on the plug n play 2 lo mod!
  3. Mar 1, 2020 at 6:11 PM
    #103
    Taco16LB
    Taco16LB Well-Known Member
    left of steering wheel here . happily standing by .
  4. Mar 1, 2020 at 6:14 PM
    #104
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I am in
  5. Mar 1, 2020 at 7:03 PM
    #105
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I think I've said this before, but I'll be in for a daisy chain right (center) harness to use with my 2LM. Should be getting my 2020 in a couple months so this will hopefully be good timing to put it in there at the same time!
  6. Mar 1, 2020 at 7:07 PM
    #106
    lapoltba
    lapoltba [OP] Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    If you (or anyone else that has posted their interest) haven't already, use the poll in the first post. That is what I am roughly basing my quantities on.
    I would hate to place an order and then run out. I'm not sure this will actually be as big a seller as the 2lm was so doing a group buy in the future would probably take a while.
  7. Mar 1, 2020 at 7:11 PM
    #107
    deusxanime
    MN
    I went to check and it gave me the option to change my vote, so I must have done it already in the past! ;)
    :spending:
    lapoltba[QUOTED][OP] likes this.
  8. Mar 1, 2020 at 7:17 PM
    #108
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I went back and changed my vote... trying to get all my 'traction stuff' in the overhead. Looks like I'm the only one looking for this solution. I'm sure I could mod whatever comes out, but I might be in for two before it's all said and done.
  9. Mar 1, 2020 at 7:22 PM
    #109
    lapoltba
    CT - 06076
    The basic switch harness will be usable for you, but if I can't get enough people for the overhead console I may be able to offer it (made by me) for a bit higher cost. It all comes down to what my vendor can do and what the minimum qty is going to be.
    deusxanime likes this.
  10. Mar 1, 2020 at 7:25 PM
    #110
    RushT
    North Texas
    Separate extension cables in 24" and 60"?
  11. Mar 1, 2020 at 7:29 PM
    #111
    lapoltba
    CT - 06076
    The daisy chain is going to be accomplished by using insulated spade or bullet terminals. I haven't found/decided on what yet, but I plan to order a bunch extra with the harnesses. I planned to include one set with each "kit", but can also do pre-crimped wire sets for a few extra $$.
  12. Mar 2, 2020 at 7:26 AM
    #112
    itsmike
    itsmike Well-Known Member
    SoCal
    For the left side, would the daisy chain option work differently than the single wire option?
    Can multiple switches not be tapped into the one cargo light wire?
  13. Mar 2, 2020 at 7:37 AM
    #113
    lapoltba
    CT - 06076
    I'm not sure I understand what you mean? For the left side you would need the left side harness and the main PnP harness. You will be able to daisy chain off that.
  14. Mar 2, 2020 at 8:08 AM
    #114
    itsmike
    SoCal
    Basically asking if a daisy chain is needed for multiple switches. (instead of just splicing multiple switches all to one wire)
  15. Mar 2, 2020 at 8:10 AM
    #115
    lapoltba
    CT - 06076
    Daisy chain is the default (only) option. You can use it or not without affecting the function of the switch. Of course you can cut and solder/splice instead if you wanted. Once I get some samples I think it will be a bit more clear. If the lead time on that is going to be too long I'll order the connectors and make them myself to show everyone.
    deusxanime and itsmike[QUOTED] like this.
  16. Mar 4, 2020 at 11:26 AM
    #116
    jakeworthy
    jakeworthy Well-Known Member
    Jake
    HB
    2019 DCLB
  17. Mar 9, 2020 at 9:41 AM
    #117
    lapoltba
    CT - 06076
    Got pricing back from the vendor and it looks pretty good. I had to fix an error on my drawing and I am checking to see if I can get samples of each made.
  18. Mar 9, 2020 at 8:20 PM
    #118
    Kyle B
    Kyle B Member
    Kyle
    Bremerton, WA
    Sold 2017 DCSB TRD OFFROAD 6SP MANUAL
    Revtec 3"
    Im interested in this as well to go with my 2lo kit. Center dash below hvac controls is where my switch is going
    RushT likes this.
  19. Mar 9, 2020 at 8:23 PM
    #119
    RushT
    North Texas
    Me too, 2lo switch going in the overhead!
  20. Mar 10, 2020 at 4:38 AM
    #120
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Left side for me.
