Custom Switch Panels
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 12, 2018.
  1. May 19, 2018 at 3:04 PM
    #481
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    As long as you have a unit without the side wing/mounting tabs you are fine.
    RandyRiot[QUOTED] likes this.
  2. May 20, 2018 at 2:12 AM
    #482
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    @mesojdm hey I'm very curious in this picture of your custom switch panel, did you coat the panel or paint it with a texture? I've been testing and testing different textures and paints and can't find anything I really like. Thank you for any information on it!
  3. May 20, 2018 at 7:34 PM
    #483
    PeterMN
    PeterMN Well-Known Member
    Fort Bragg, NC
    2018 ORD DCSB Cement
    I installed panels on the left and center and am trying to relocate some switches from the left side to the center. I need to lengthen the wires and I am just curious, what gauge and type of wires did ya'll use to relocate your switches?
  4. May 21, 2018 at 6:52 AM
    #484
    bCaff
    bCaff Well-Known Member
    Brian
    2017 Tacoma TRD OR DCSB
    I've been curious about the same thing. If the wire gauge size works out (which I think would be ok for most switches), thermostat wire from your local hardware store may be a good idea. It's nice because it comes with (8) 18-guage wires individually color coded and wrapped in a single bundle. This would make it easier to relocate multiple wires from one side of the steering column to the other. You can also get 5 wire thermostat wire since most switches are only 4 or 5 connections, but the (8) wire version is not that much more expensive.
    https://www.homedepot.com/p/Southwi...AjQjEALw_wcB&dclid=CPLzo5L5ltsCFRDH4wcdmbsBrg
  5. May 21, 2018 at 9:09 AM
    #485
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    18 gauge is more than enough for switch wiring.
    bCaff[QUOTED] likes this.
  6. May 22, 2018 at 8:10 AM
    #486
    cratagus
    cratagus Well-Known Member
    coquitlam BC
    2017 double cab TRD
    speaker upgrade, toytec lift SCS wheels ( ray 10), magnaflow exhaust, 285 BFG Ko2
    Me-so! Im trying to buy some blanks to go with my 7 switch but cant figure out how to order them... help me out?
  7. May 23, 2018 at 11:42 AM
    #487
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    More panels in stock ready to rock.
    I have the following;
    Lower panels:
    LSP7
    LSP6W
    LSP5.1
    Cubby's:
    CPSP
    CP8
    CP4P
    CP6.1W
    and SWITCH BLANKS too:)
    AZROTTI and mcharfauros like this.
  8. May 23, 2018 at 10:07 PM
    #488
    justhaag
    justhaag Well-Known Member
    Mesa, AZ
    2017 Quiksand Tacoma TRD Off-road 4x4
    Do you know when you’ll be making more cpspw’s?
  9. May 23, 2018 at 10:17 PM
    #489
    MESO
    State of Jefferson
    They were supposed to be in this batch but somehow did not get added. I’ll run them next print
    justhaag[QUOTED] likes this.
  10. May 23, 2018 at 10:51 PM
    #490
    justhaag
    Mesa, AZ
    Awesome! I’m in when they come out!
  11. May 24, 2018 at 4:13 AM
    #491
    shacol
    shacol Well-Known Member
    Florida
    2018 Offroad DCSB
    Hey @mesojdm - Any chance you'll have a flush mount switch pro panel for this? I didn't see that option on page 1.
  12. May 26, 2018 at 12:32 AM
    #492
    fordhammer
    fordhammer Member
    Rod
    Rincon (Savannahish), GA
    2017 TRD OR
    Must have missed the CP6.1W again. Waiting on the next batch!
  13. May 26, 2018 at 9:16 PM
    #493
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Installed my new CP6.1w yesterday as well as moved some switches around. I really hated where the usb port is so I moved it to the left of the steering wheel as well as the ect switch.
    2 things I noticed when installing it in my 2017 is that it's a super snug fit and I noticed that the behind the upper far left switch opening is the mounting location for the factory one so I couldn't install an actual switch there as the back would hit. I need to get a picture of this to make more sense, but here's a picture of what I have right now.
  14. May 26, 2018 at 9:26 PM
    #494
    MESO
    State of Jefferson
    Running 4 switches on top where there wasn’t meant to be any, I knew some minor trimming behind the dash would be needed. Also, I did make it on the tighter side on purpose, I hate loose/ratteling panels.
  15. May 27, 2018 at 6:48 AM
    #495
    shacol
    Florida
    2018 Offroad DCSB
    Ahh, I didn't realize that! Thanks very much! Just ordered the cpsp! Appreciate the help.
    Shannon
    CANYONERO likes this.
  16. May 27, 2018 at 2:49 PM
    #496
    YachterSteve
    YachterSteve Well-Known Member
    Multiple Time Zones
    2017 white Tacoma Limited
    TRD exhaust, CA intake, TRD skid plate. ARB lockers front and back, toytec shocks front and rear, factory Bed liner, weather tech floor mats front and rear, interior led lights and tag lights,SSO front bumper with led light and remote winch, old man emu back leaf springs, Lasfit led low beams and fogs
    @mesojdm the CP6.1W.....what are the actual switch cut outs size on the upper row of 4 holes. I can’t deal with this anymore. I’m looking at the air onboard 32.5mm by 22mm is this the correct switch to fit your panel. Thanks for the helpD7C5EE0B-56AD-4F22-B680-7DDCCC169820.jpg
    mcharfauros likes this.
  17. May 27, 2018 at 3:00 PM
    #497
    MESO
    State of Jefferson
    Upper 4 holes are the same size as your 400w power inverter button.
    JoeWillie likes this.
  18. May 27, 2018 at 7:01 PM
    #498
    ratcityrain
    Seattle, WA
    For the record I want to make sure you and everyone else knows that I am not bitchin at all, just wanted to report just in case others come across it
    I am happy with the fit and like that its snug and I can live with that switch location having something behind it because that is where my bass knob will probably ended up
    Overall i am super happy with it and no regrets purchasing and installing it.
  19. May 27, 2018 at 11:15 PM
    #499
    AZROTTI
    AZROTTI What's all the fuss about?
    Az
    2019 Quicksand TRD 4X4 OR LB
    Some stuff n always adding more stuff . Ceramic window tint, Suntek film, weather tech floor mats, Bottle pro adapter, Schosche mag mount, AJT fob case, vinyl decal dash blackout kit, Meso overhead rack, red dome n map lights, gashole, turn signals, coin bin, dash blackout panel, rims blackout kit, door hinge covers, seat risers, bpf front grill, Hondo nobs, glovebox n console organizer.
    Wow, those went fast I guess I'll have to wait for the next batch of cubbies. At least I got the 6 switch with rear window n some blanks. Thanks again Meso your the best :)
    :spending::spending::spending:
  20. May 28, 2018 at 7:47 AM
    #500
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    @mesojdm will the power inverter and the clutch disable switch fit in the 6.1w?
