Custom Switch Panels
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 12, 2018.
  1. Mar 3, 2019 at 2:34 PM
    #1121
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Do you happen to know if you will be making any more LSP7 models or should i just ditch my cig lighter and go with a LSP8?
    TIA
  2. Mar 8, 2019 at 2:13 PM
    #1122
    VirusCage
    Bruce
    Allison Park, PA
    @mesojdm , not trying to be a pain the ass, but any thoughts on eta of lsp7 or the window switch hole accepting standard switches? If I am just better off with an 8 switch panel, I could do that too.. TIA
  3. Mar 8, 2019 at 6:56 PM
    #1123
    Jblake329
    Jblake329 Active Member
    Justin
    MA
    2017 Inferno Tacoma TRD Offroad
    @mesojdm I dont see the switch blanks for sale on your store? How do I order some of the SBS small version ones?
  4. Mar 9, 2019 at 5:17 PM
    #1124
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Anyone know if there is space in the custom layout for bbbbb on top and ebbb on bottom?
    Looking to pack as many small toyotT switches as I can
  5. Mar 9, 2019 at 5:58 PM
    #1125
    VirusCage
    Bruce
    Allison Park, PA
    Orders the 8 today...convinced myself to ditch the cig lighter
  6. Mar 10, 2019 at 5:57 AM
    #1126
    DRETACO
    DRETACO Well-Known Member
    17' TRD V6 DCOR AT
    Trying to install the panel today but ran into a snag. Looks too wide. Am I doing this wrong?
  7. Mar 10, 2019 at 9:01 AM
    #1127
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Pm’d You
  8. Mar 13, 2019 at 9:31 AM
    #1128
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    @mesojdm Any updates on the next batch of LSP7?
  9. Mar 14, 2019 at 7:49 AM
    #1129
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Hey @mesojdm would it be possible to make a cubby panel with 4 large push switches up top and 3 large push switches on the bottom with a cab light? It would be kinda like the OEM one that has the auto high beams like in the picture.IMG_20190311_180005.jpg
  10. Mar 14, 2019 at 8:30 AM
    #1130
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    MESO[OP] likes this.
  11. Mar 14, 2019 at 8:32 AM
    #1131
    MESO
    State of Jefferson
    Yes. I’ve done it before let me see if I can dig it up
  12. Mar 14, 2019 at 8:34 AM
    #1132
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    This may help you find your answer here
    With the custom panel you can play with different configuration options to your hearts content till you find the ONE that is right for you.
  13. Mar 14, 2019 at 8:41 AM
    #1133
    CttAznRanger
    Brandon
    Boston, MA
    Yup, I did see those, only problem is the original idea I had was for the bottom portion to be short switches which would total 134mm, where it shows 130mm on the site. I may have to squeeze the tall switches in there instead to make it fit better.
  14. Mar 14, 2019 at 8:43 AM
    #1134
    CttAznRanger
    Brandon
    Boston, MA
    Would you happen to have done the same config but with the 3 small switches on the bottom instead of the 3 large ones? It would make it a bit oversized though.
  15. Mar 14, 2019 at 8:47 AM
    #1135
    MESO
    State of Jefferson
    Here are just some samples of the custom ones I've done. Possibilities are endless.
    tonered likes this.
  16. Mar 14, 2019 at 8:49 AM
    #1136
    CttAznRanger
    Brandon
    Boston, MA
    Sweet, I see parts I like, I'll probably be taking half from one design and half from another, thanks Meso!
    MESO[QUOTED][OP] likes this.
  17. Mar 14, 2019 at 8:54 AM
    #1137
    CttAznRanger
    Brandon
    Boston, MA
    @mesojdm two more questions if you don't mind.
    1) can we order switch caps/blanks from you?
    2) would you happen to have/sell wiring harnesses/extensions for the small switches so I can reroute them to the lower dash?
  18. Mar 14, 2019 at 8:58 AM
    #1138
    MESO
    State of Jefferson
    1)I do have some switch covers, but I don't list them because it basically costs me as much to 3D print then I'm selling them for. If someone purchases a switch panel, I can offer them blanks though.
    2)Every OEM button has a different connector. Unfortunately I don't know every part number for each button
  19. Mar 14, 2019 at 9:02 AM
    #1139
    CttAznRanger
    Brandon
    Boston, MA
    Is there a difference between the covers and blanks? I'm just looking to get something to cover the holes while I fill them. I'm totally ok with buying them from you for a higher price so you can make profit.
    Also, if you could find/source those connectors, I am also willing to pay for R&D time on those. I just don't want to split/splice any OEM wiring.
  20. Mar 16, 2019 at 10:56 AM
    #1140
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Is it possible to get a cubby panel that supports one or more 19mm rotary switches (like this one: https://www.aliexpress.com/item/19m...pm=a2g0s.13010208.99999999.262.ce733c00SujIcZ) and some small rockers (like these: https://www.aliexpress.com/item/Hzy...lgo_pvid=1dac66d4-f6a5-4788-913a-dbc1f32cb63f)? The rest of the available space could be occupied with B or C style switch holes.
    If those parts can't be directly supported, how feasible do you think it'd be to drill into a blank switch instead? Anyone know the part number for the B (smaller) switch blank? I see the larger one linked in the product discussion area for this thread.
