custom turbo setup !
Discussion in 'Performance and Tuning' started by rexrunner, May 19, 2009.
  1. Sep 25, 2016 at 7:34 PM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Graduated from taco to fire breathing cummins. Question: Saw the EGT sensor downstream of the turbo? Why? Better temp reading compared to drive pressure upstream of the turbine. What turbo is this? I guess it would have to be a pretty small turbo to spool with an already anemic taco 6 cylinder? Having owned 4 different tacomas over the years, I know about that...
    These compounded twins are Garrett water-cooled ball bearing GT3782R secondary over GT4202R primary. Tial 44mm. Steed manifold. Currently at 450 hp / 960 ft/lbs on tow tune. Max race at 710 hp / 1490 ft/lbs. That with stock CP3 fuel into BBi Stg1 injectors. (90 hp). Twins sized for towing and drivetrain longevity. I thought about a 4715 primary but that would have had me pushing 900 hp with these injectors and well over 1000 hp with serious fuel. My transmission is rated for 650 hp so the overall goal was for around 500 hp mainly for towing and DD etc. Must be careful going from a taco to a truck that will get sideways on dry pavement... that $h*t gets real addictive real fast. =)
  2. Sep 27, 2016 at 8:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Boosted until the engine went. Sold the kit. Swapped in an LS. Still has the truck.
    Nickel likes this.
  3. Oct 9, 2016 at 1:25 PM
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    any more pictures of the set up?
  4. Oct 9, 2016 at 1:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There were on XRU. The site might still be down though.
