Custom weld on slider install question
Discussion in 'Armor' started by Sand_In_My_Taco, Apr 9, 2024.
  1. Apr 9, 2024 at 4:19 PM
    Sand_In_My_Taco
    Sand_In_My_Taco [OP] Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    Finishing up my slider build!
    I have the sliders built, but I haven't cut or attached the posts to the frame/sliders.
    My questions are....
    Installing on third gen access cab
    I'm assuming I want this as close to the pinch weld as possible, then tilt it upwards until it hits the door. Back off 1/2 from open door and tac into place.
    I'm also assuming I want it sticking out far enough that it is the "widest" part of the body. Doesn't need to be by much, but it needs to be slightly out. Is this correct? Or should I stick out further?
    If anyone had measurements for how far from the frame they extend I'd love to know to get an idea how I want to line mine up!
    I'll post some pics soon
  2. Apr 9, 2024 at 5:20 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    85 inches end to end
    01tacoruben likes this.
  3. Apr 9, 2024 at 5:28 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Something like this is what I'm thinking, just need to snug it up to the body before measuring angle/distance to frame and cutting the supports
  4. Apr 9, 2024 at 5:38 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Second option is to sit just outside the pinchweld like this, then angle upward.
  5. Apr 11, 2024 at 7:43 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    I'll get some pics and measurements of my westcott designs bolt on sliders to give you some references. Should have them tomorrow afternoon if the weather eases up. You want to give your sliders enough clearance to allow for some frame and body mount flex, 1/2" may or may not be enough.
    Sand_In_My_Taco[OP] likes this.
  6. Apr 11, 2024 at 7:57 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    Awesome thanks!
  7. Apr 19, 2024 at 2:49 PM
    Toy_Runner
    99 4Runner SR5
    Shit- weather stopped me the other day and I completelt forgot. Will have pictures and measurements this evening. Sorry dude.
  8. Apr 19, 2024 at 2:57 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    No worries!
  9. Apr 19, 2024 at 6:24 PM
    Toy_Runner
    99 4Runner SR5
    Measured about 3/4" of space between the height of the inner rail and the pinch weld. Slight variation along the length of the rai. The inner/main tube is spaced just outside the pinch weld.
    Again, apologies for the massive delay.
  10. Apr 19, 2024 at 7:41 PM
    Sand_In_My_Taco
    NOR*CAL
    2019 TRD-OR AC
    That's perfect, thanks!
    I think I'm going to try and source a bolt-on style plate from a local fabricator, bolt it up, then weld mine to the plate.
    Toy_Runner[QUOTED] likes this.
  11. Oct 4, 2024 at 8:19 PM
    01tacoruben
    01tacoruben Active Member
    Ruben
    Ontario, California
    01 white tacoma extra cab 3.4 manual 4x4
    6inch Fabtech lift. 33 inch tires
    What kind of tubing did you use?
    How thick was the tube?
  12. Nov 23, 2024 at 5:27 PM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    bolt + weld, this is the way.
